Hi, I'm trying to connect an external I2C device to the nrf9160DK and read some registers. I'm using NCS v1.9.1.
I have my file nrf9160dk_nrf9160_ns.overlay defined like this
&i2c1 {
status = "okay";
sda-pin = <30>;
scl-pin = <31>;
clock-frequency = <I2C_BITRATE_STANDARD>;
To see if the I2C bus is beeing initialize correctly I created my main function as
#define I2C_DEV DT_LABEL(DT_NODELABEL(i2c1))
void main(void) {
const struct device *i2c_dev;
uint8_t data[16];
int i, ret;
struct i2c_msg msg;
i2c_dev = device_get_binding(I2C_DEV);
if (!i2c_dev) {
printk("I2C: Device driver not found.\n");
return;
uint8_t error = 0u;
i2c_configure(i2c_dev, I2C_SPEED_SET(I2C_SPEED_STANDARD));
printk("Value of NRF_TWIM1_NS->PSEL.SCL: %ld \n", NRF_TWIM1_NS->PSEL.SCL);
printk("Value of NRF_TWIM1_NS->PSEL.SDA: %ld \n", NRF_TWIM1_NS->PSEL.SDA);
printk("Value of NRF_TWIM1_NS->FREQUENCY: %ld \n", NRF_TWIM1_NS->FREQUENCY);
printk("26738688 -> 100k\n");
In the PSEL.SCL and PSEL.SDA prints I should be seeing 31 & 30, is that correct?
What I am actuallly seeing is:
Value of NRF_TWIM1_NS->PSEL.SCL: 14 Value of NRF_TWIM1_NS->PSEL.SDA: 1 Value of NRF_TWIM1_NS->FREQUENCY: 26738688 26738688 -> 100k
Do I need to add other configuration steps?
