Dear support
I am developing my application based on central_multilink example and have a few questions:
1. in call back function connected() , I wonder why conn_connecting is set to NULL even there is no failure on connection, I am thinking of calling disconnect function to disconnect it if I need to, but if it is set to NULL, then, it is not possible, right? Also, may I create multiple connection reference variables like conn_connecting ? as I need to create multiple connections same time and freely disconnect them any time.
2. Following code in init_central() function in while (true) {} loop is ever be called? I put a breakpoint there, and it never reach there. I wonder how does the program disconnect the connected multiple devices. Any more complete examples please? how do I refer the multiple connection if I need to disconnect them?
iterations--; printk("Iterations remaining: %u\n", iterations); printk("Disconnecting all...\n"); is_disconnecting = true; bt_conn_foreach(BT_CONN_TYPE_LE, disconnect, NULL); //never goes here?
Thank you for your attention. Any example to handle multiple connection will be helpful. I would like to connect and disconnect any of them freely, is this possible?
Ping
