Issue with compiler and debug in VS Code with nRF Connect
I/my admin  installed the SDK and visual studio though the nRF connect tool chain manager.
When i open visual studio through the toolchain manager it prompts me
to "Select a kit for..."
with the two option
Scan for kits (...compilers...)
unspecified
When I try to debug it gives me the message
Unable to start debugging: Unable to find J-Link directory to find JLinkGDBServerCL executable. Please make sure that J-Link is installed and that the 'HKEY_LOCAL_MACHINE\Software\SEGGER\J-Link' registry key is defined correctly.
This is installed on a admin controlled machine where I just have a user profile.
Any insight you can provide into how to resolve this would be appreciated.
I will need to pass on the fix to my administrator as I have no control over the installation.
Is there an issue with installing as an administrator and running as a user?
Issues with Debugging using VScode with nRF connect and nrf sdk2.docx
When I select scan for kits nothing happens
When i select unspecified:
[variant] Loaded new set of variants
[kit] Successfully loaded 0 kits from C:\Users\deirdre.hackett\AppData\Local\CMakeTools\cmake-tools-kits.json
[main] Configuring folder: hello_world_test5
Support:
As it is not related to original topic of the ticket, you should register a new ticket. That said, the "select a kit for..." message is not related to the nRF Connect for VS Code extension but another extension in VS Code I believe. It is unfortunately misleading, and it can be ignored.
In you case, you should check what devices are connected under "Connected devices" in the nRF Connect extension
I will forward your feedback to our VS code extension team, as this is valuable information in regards to user experience.
Support:
What debug button are you clicking? Make sure to use the one in our extension:
 Yes I am definitely pressing the debug button in the nRF Connect extension.
My admin installed everything in his admin profile other than VS code that he installed as a network device.
Let me know if there other information you need to see.
Is this an issue with an environment variable or registry key.
  • IMPORTANT: The data below could contain sensitive or confidential information about your environment.
    For help and support, visit the Nordic DevZone at devzone.nordicsemi.com/.
    "platform": {
    "os": "win32",
    "osVersion": "Windows 10 Pro",
    "osKernel": "10.0.19044",
    "vscode": "1.67.2",
    "electron": "17.4.1",
    "node": "v16.13.0"
    "system": {
    "date": "2022-05-25T14:27:48.146Z",
    "vscodeRoot": "c:\\Program Files\\Microsoft VS Code\\resources\\app",
    "vscodeUptime": "00:00:25",
    "osUptime": "24:30:10",
    "cpu": {
    "model": "11th Gen Intel(R) Core(TM) i5-1145G7 @ 2.60GHz",
    "speed": "1498 MHz",
    "count": 4
    "memory": {
    "total": "15.73 GB",
    "free": "8.26 GB"
    "workspace": {
    "name": null,
    "workspaceFile": null,
    "folders": []
    "extensions": {
    "internal": {
    "version": "2022.4.219",
    "path": "c:\\Users\\anon\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2022.4.219",
    "isActive": true
    "version": "2022.4.61",
    "path": "c:\\Users\\anon\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2022.4.61",
    "isActive": true
    "nordic-semiconductor.devicetree": null,
    "nordic-semiconductor.kconfig": null
    "external": {
    "marus25.cortex-debug": "1.4.4",
    "ms-vscode.cpptools": "1.9.8",
    "ms-vscode-remote.remote-wsl-recommender": "0.0.15",
    "ms-vscode.js-debug": "1.67.2",
    "ms-vscode.js-debug-companion": "1.0.18",
    "ms-vscode.references-view": "0.0.89",
    "ms-vscode.vscode-js-profile-table": "1.0.1",
    "cschlosser.doxdocgen": "1.4.0",
    "jeff-hykin.better-cpp-syntax": "1.15.14",
    "ms-vscode.cmake-tools": "1.10.5",
    "ms-vscode.cpptools-extension-pack": "1.2.0",
    "ms-vscode.cpptools-themes": "1.0.0",
    "redhat.vscode-yaml": "1.7.0",
    "twxs.cmake": "0.0.17"
    "tools": {
    "C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.15.4",
    "nrfutil": "Not found",
    "c:\\Users\\anon\\nordsc\\v1.9.1\\toolchain\\opt\\bin\\cmake.exe": "3.20.5",
    "c:\\Users\\anon\\nordsc\\v1.9.1\\toolchain\\opt\\bin\\Scripts\\west.exe": "0.12.0",
    "c:\\Users\\anon\\nordsc\\v1.9.1\\toolchain\\opt\\bin\\python.exe": "3.8.2",
    "c:\\Users\\anon\\nordsc\\v1.9.1\\toolchain\\opt\\bin\\ninja.exe": "1.9.0",
    "c:\\Users\\anon\\nordsc\\v1.9.1\\toolchain\\opt\\bin\\gperf.exe": "3.1",
    "c:\\Users\\anon\\nordsc\\v1.9.1\\toolchain\\opt\\bin\\dtc.exe": "1.4.7",
    "c:\\Users\\anon\\nordsc\\v1.9.1\\toolchain\\opt\\bin\\arm-none-eabi-gcc.exe": "9-2019-q4-major",
    "c:\\Users\\anon\\nordsc\\v1.9.1\\toolchain\\opt\\bin\\gn.exe": "1977",
    "c:\\Users\\anon\\nordsc\\v1.9.1\\toolchain\\mingw64\\bin\\git.exe": "2.26.2.windows.1"
    "sdks": [],
    "toolchains": [],
    "connectedDevices": [],
    "deviceProviders": [
    "nrfjprog"
    "config": {
    "topdir": "c:\\Users\\anon\\nordsc\\v1.9.1",
    "toolchain": {
    "path": "c:\\Users\\anon\\nordsc\\v1.9.1\\toolchain"
    "ozonePath": "",
    "applications": [],
    "applicationOptions": {},
    "kconfig": {
    "interface": "kconfig"
    "welcome": {
    "showOnStartup": false
    "west": {
    "env": {
    "$base": "terminal"
    "boardRoots": [],
    "enableTelemetry": true
    "terminalMode": "character"
    "nordic-semiconductor.devicetree": {
    "modules": [
    "${zephyrBase}",
    "${zephyrBase}/../nrf",
    "zephyr": "",
    "ctxFile": "",
    "defaultBoard": ""
    "nordic-semiconductor.kconfig": {
    "root": "",
    "env": {},
    "cfiles": true,
    "disable": false,
    "zephyr": {
    "base": ""
    "python": "C:\\Program Files\\Python36\\python.exe",
    "liveValue": true
    "marus25.cortex-debug": {
    "armToolchainPath": null,
    "armToolchainPrefix": "arm-none-eabi",
    "gdbPath": null,
    "objdumpPath": null,
    "JLinkGDBServerPath": null,
    "openocdPath": null,
    "pyocdPath": null,
    "PEGDBServerPath": null,
    "stutilPath": null,
    "stlinkPath": null,
    "stm32cubeprogrammer": null,
    "enableTelemetry": true,
    "flattenAnonymous": false,
    "registerUseNaturalFormat": true,
    "variableUseNaturalFormat": true,
    "dbgServerLogfile": null,
    "showRTOS": false,
    "showDevDebugOutput": "none"
    "environment": {
    "westExe": "c:\\Users\\anon\\nordsc\\v1.9.1\\toolchain\\opt\\bin\\Scripts\\west.exe",
    "westEnv": {
    "ELECTRON_RUN_AS_NODE": "1",
    "HOME": "C:\\Users\\anon",
    "HOMEDRIVE": "C:",
    "HOMEPATH": "\\Users\\anon",
    "Path": "c:\\Users\\anon\\nordsc\\v1.9.1\\toolchain\\mingw64\\bin;c:\\Users\\anon\\nordsc\\v1.9.1\\toolchain\\mingw64\\libexec\\git-core;c:\\Users\\anon\\nordsc\\v1.9.1\\toolchain\\opt\\bin;c:\\Users\\anon\\nordsc\\v1.9.1\\toolchain\\opt\\bin\\Scripts;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files\\Wolfram Research\\WolframScript\\;C:\\Program Files\\MATLAB\\R2020b\\runtime\\win64;C:\\Program Files\\MATLAB\\R2020b\\bin;C:\\Program Files\\PuTTY\\;C:\\Program Files\\nodejs\\;C:\\Program Files\\Git\\cmd;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files\\Microsoft VS Code\\bin;C:\\Users\\anon\\AppData\\Local\\Microsoft\\WindowsApps;",
    "ZEPHYR_BASE": "c:\\Users\\anon\\nordsc\\v1.9.1\\zephyr",
    "GNUARMEMB_TOOLCHAIN_PATH": "c:\\Users\\anon\\nordsc\\v1.9.1\\toolchain\\opt",
    "ZEPHYR_TOOLCHAIN_VARIANT": "gnuarmemb",
    "PYTHONPATH": "c:\\Users\\anon\\nordsc\\v1.9.1\\toolchain\\opt\\bin;c:\\Users\\anon\\nordsc\\v1.9.1\\toolchain\\opt\\bin\\Lib;c:\\Users\\anon\\nordsc\\v1.9.1\\toolchain\\opt\\bin\\Lib\\site-packages",
    "Python3_ROOT": "c:\\Users\\anon\\nordsc\\v1.9.1\\toolchain\\opt\\bin"
    "toolchainPath": "c:\\Users\\anon\\nordsc\\v1.9.1\\toolchain",
    "toolchainBinPath": "c:\\Users\\anon\\nordsc\\v1.9.1\\toolchain\\opt\\bin",
    "toolchainVersion": "1.9.1"
    "terminal": {
    "shell": null,
    "defaultProfile": null
  • Thanks Oyvind. I appreciate the prompt and efficient handling of this issue.
    Deirdre
  • Hello again Deirdre, sorry for the late reply.
    I've discussed the issue with our VS Code team and it seems that this boils down to missing JLink drivers. These should have been installed when installing nRF Connect for Desktop.
    Can you please try installing the nRF Command Line Tools?
    Thanks!
    Øyvind
    It was definitely installed before the nRF connect was installed.
