BMD-300 EvK with ublox BMD-360 module and nRF52811 power off consumption higher than expected
Hello I'm trying to get the lower consumption with this EvK in power off mode. I was expecting around 0.5uA but the minimum I get is 1.8uA ~ 2uA.
The measure has been done with a nRF Power Profiler and an SMU Keithley 2450.
I've used the "ram_retention" example. (nRF5_SDK_17.1.0_ddde560) but modifying the main function to go directly to power off mode:
    bsp_board_led_on(READY_PIN_NUMBER);
    nrf_delay_ms(1000);
    // Enter System OFF and wait for wake up from GPIO detect signal.
    NRF_POWER->SYSTEMOFF = 0x1;
    // Use data synchronization barrier and a delay to ensure that no failure
    // indication occurs before System OFF is actually entered.
    __DSB();
    __NOP();
    // This code will only be reached if System OFF did not work and will trigger a hard-fault which will
    // be handled in HardFault_Handler(). If wake the up condition is already active while System OFF is triggered,
    // then the system will go to System OFF and wake up immediately with a System RESET.
    display_failure();
I've tested using Keil uVision, without softdevice using these ROM, RAM addresses and directives :
  • IROM1: Start: 0x0 / Size: 0x30000  //  IRAM1: Start: 0x20000000 / Size: 0x6000
  • BOARD_PCA10040 BSP_DEFINES_ONLY CONFIG_GPIO_AS_PINRESET FLOAT_ABI_SOFT NRF52 NRF52811_XXAA NRF52_PAN_74 __HEAP_SIZE=8192 __STACK_SIZE=8192
  •  --cpreproc_opts=-DBOARD_PCA10040,-DBSP_DEFINES_ONLY,-DCONFIG_GPIO_AS_PINRESET,-DFLOAT_ABI_SOFT,-DNRF52,-DNRF52811_XXAA,-DNRF52_PAN_74,-D__HEAP_SIZE=8192,-D__STACK_SIZE=8192
I've also tested with a softdevice (s112 - 7.2.0) using these ROM, RAM addresses and directives :
  • IROM1: Start: 0x19000 / Size: 0x17000 //  IRAM1: Start: 0x20001A50 / Size: 0x45B0
  • BOARD_PCA10040 BSP_DEFINES_ONLY CONFIG_GPIO_AS_PINRESET FLOAT_ABI_SOFT NRF52 NRF52811_XXAA NRF52_PAN_74 NRF_SD_BLE_API_VERSION=7 S112 SOFTDEVICE_PRESENT __HEAP_SIZE=2048 __STACK_SIZE=2048
  •  --cpreproc_opts=-DBOARD_PCA10040,-DBSP_DEFINES_ONLY,-DCONFIG_GPIO_AS_PINRESET,-DFLOAT_ABI_SOFT,-DNRF52,-DNRF52811_XXAA,-DNRF52_PAN_74,-D__HEAP_SIZE=2048,-D__STACK_SIZE=2048
Here some screenshots from the Power Profiler Kit:
Thanks in advance Slight smile
  • Hi there,
    I discussed your plots along with my own measurements with a colleague, and we suspect that the extra current might be consumed by the peripheral power domain.
    In short, you can try 2 things:
    1. Disable UART by setting NRF_LOG_ENABLED = 0 in your sdk_config.h file.
    2. Modify the code in main.c so that it uses GPIO PORT event instead of GPIO IN_EVENT. See this thread.
    Enabling logging or using GPIO IN_EVENT will turn on the peripheral power domain which seems to be consuming the extra current. Could you try to implement these suggestions?
    regards
    Jared
  • Hello Jared,
    Sorry for the late answer I was on holidays.
    I finally had the opportunity to test your solution and it does work ! I have now decreased the idle consumption below 1µA, which is great as it leads to a connection interval happening every 7.5 seconds (high slave latency). Thank you so much !
    BTW both UART debug and IN_EVENT must be disabled for the peripheral power domain to be switched off, which makes sense.
    I checked and the MCU does wake up with .hi_accuracy set to false so it seems to be going well.
    Thanks a lot !
    Best regards
    Eric
