performance issue with multi threadn in ncs with nrf52832
hello Nordic
i am working with nrf52832, with zephyr, ncs v1.7.1,
the device has a sensor that sample at 26khz each sample is 3 channels of 2 bytes data. the sensor use spi1 and has high thread priority (cooperative) the samples are then stream via a double buffer to the flash which uses spi2.
when tying to write a page (256 bytes) to the flash at a test in the beginning of the app it take 1ms to write that page but when trying to write within the app, while the other sensor is sampling, it takes 3ms and also i get a BUS FAULT. here is the log:
[00000018] <err> os: ***** BUS FAULT *****
[00000018] <err> os:   Unstacking error
[00000018] <err> os: ***** HARD FAULT *****
[00000018] [1;31m<err> os:   Fault escalation (see below)
[00000018] <err> os:   Precise data bus error
[00000018] <err> os:   BFAR Address: 0xfe80fec0
[00000018] <err> os: r0/a1:  0x2000bef0  r1/a2:  0xfe80fec0  r2/a3:  0xfe80ff28
[00000018] <err> os: r3/a4:  0x2000beef r12/ip:  0xfa000000 r14/lr:  0x00016d79
[00000018] <err> os:  xpsr:  0x81000005
[00000018] <err> os: s[ 0]:  0x00000000  s[ 1]:  0x00000000  s[ 2]:  0x00000000  s[ 3]:  0x00000000
[00000018] <err> os: s[ 4]:  0x00000000  s[ 5]:  0x00000000  s[ 6]:  0x00000000  s[ 7]:  0x00000000
[00000018] <err> os: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0x00000000
[00000018] <err> os: s[12]:  0x00000000  s[13]:  0x00000000  s[14]:  0x00000000  s[15]:  0x00000000
[00000018] <err> os: fpscr:  0x20001d78
[00000018] <err> os: Faulting instruction address (r15/pc): 0x0003ef10
[00000018] <err> os: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0
[00000018] <err> os: Fault during interrupt handling
[00000018] <err> os: Current thread: 0x20003210 (unknown)
[00000018] <err> fatal_error: Resetting system
*** Booting Zephyr OS build v2.6.99-ncs1-1  ***
now i do have in the app another driver that uses spi (at the same time (getting samples and writing samples to flash), but it uses a different instance of spi so i don't see why it shell create such a delay .. here is my complete .dts file:
// Copyright (c) 2022 Nordic Semiconductor ASA
// SPDX-License-Identifier: Apache-2.0
/dts-v1/;
#include <nordic/nrf52832_qfaa.dtsi>
	model = "halo_ep2";
	compatible = "halo-ep2";
	chosen {
		zephyr,sram = &sram0;
		zephyr,flash = &flash0;
		zephyr,code-partition = &slot0_partition;
		nordic,pm-ext-flash = &augu_flash_is25lp128;
	sensors_on: sensors_on_node {
		compatible = "augury,gpio-power";
		power_gpios = <&gpio0 22 GPIO_ACTIVE_LOW>;
		label = "SENSORS_ON";
		status = "okay";
		#power_resource-cells = <0>;
	flash_on: flash_on_node {
		power_gpios = <&gpio0 23 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
		label = "FLASH_ON";
		status = "okay";
    leds {
        compatible = "gpio-leds";
        led0_red: led_0 {
            gpios = <&gpio0 25 GPIO_ACTIVE_HIGH>;
            label = "RED_LED_0";
        led1_orange: led_1 {
            gpios = <&gpio0 26 GPIO_ACTIVE_HIGH>;
            label = "ORANGE_LED_1";
        led2_green: led_2 {
            gpios = <&gpio0 27 GPIO_ACTIVE_HIGH>;
            label = "GREEN_LED_2";
	aliases {
		led0-red = &led0_red;
		led1-orange = &led1_orange;
		led2-green = &led2_green;
	&adc {
		status ="okay";
	&gpiote {
		status ="okay";
	&gpio0 {
		status ="okay";
	&spi1 {
		status = "okay";
		sck-pin = <20>;
		mosi-pin = <14>;    // p0.14
		miso-pin = <16>;    // p0.16
		cs-gpios = <&gpio0 13 GPIO_ACTIVE_LOW>;
		iis3dwb@0 {
			compatible = "st,iis3dwb";
			reg = <0>;
			int1_gpios = <&gpio0 11 (GPIO_ACTIVE_HIGH | GPIO_PULL_DOWN)>;
			int2_gpios = <&gpio0 12 (GPIO_ACTIVE_HIGH | GPIO_PULL_DOWN)>;
			label = "IIS3DWB";
			power_resources = <&sensors_on>;
			spi-max-frequency = <8000000>;
	&spi2 {
		status = "okay";
		sck-pin = <5>; // gpio 0 pin 5
		mosi-pin = <4>; // gpio 0 pin 4
		miso-pin = <2>; // gpio 0 pin 2
		compatible = "nordic,nrf-spi";
		cs-gpios = <&gpio0 3 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
		augu_flash_is25lp128: augu_flash_is25lp128@0 {
			compatible = "issi,augu_flash_is25lp128";
			reg = <0>;
			label = "AUGU_FLASH_IS25LP128";
			power_resources = <&flash_on>;
			jedec_id = [9d 60 18];
			spi-max-frequency = <8000000>; //<133000000>;
			page_size = <256>;
			block_size = <65536>;
			size = <0x8000000>;
	&flash0 {
		partitions {
			#address-cells = <1>;
			#size-cells = <1>;
			mbr_partition: partition@0 {
				label = "mbr";
				reg = <0x00000000 0x00001000>;
			boot_partition: partition@1000 {
				label = "mcuboot";
				reg = <0x1000 0xc000>;
			slot0_partition: partition@d000 {
				label = "image-0";
				reg = <0xd000 0x6c800>;
			slot1_partition: partition@79800 {
				label = "image-1";
				reg = <0x79800 0x800>;
			storage_partition: partition@7a000 {
				label = "storage";
				reg = <0x7a000 0x6000>;
(running the app on another board with nrd52840, with nand flash that writes 2k each time, works well, so i don't know if it is a performance issue or something else.. i will also mention that the RAM take on the nrf52832 with zephyr and all is high:
[567/572] Linking C executable zephyr/zephyr.elf
           FLASH:      253604 B     419328 B     60.48%
            SRAM:       60282 B        64 KB     91.98%
        IDT_LIST:          0 GB         2 KB      0.00%
[568/572] Generating zephyr/mcuboot_primary_app.hex
[569/572] Generating zephyr/mcuboot_primary.hex
[570/572] Generating ../../zephyr/app_update.bin, ../../zephyr/app_signed.hex, ../../zephyr/app_test_update.hex, ../../zephyr/app_moved_test_update.hex
[571/572] Generating ../../zephyr/dfu_application.zip
[572/572] Generating zephyr/merged.hex
any idea why i get the BUS FAULT ?
p.s. i don't know if it has any affect but the page data is saved in a heap section previously allocated like so
K_HEAP_DEFINE(my_heap, 3072);   // 256*3*2 = 1536 + safe buffer
int mem_heap_alloc(int size, struct k_mem_block *block)
    block->data = NULL;
    block->data = k_heap_alloc(&my_heap, size, K_NO_WAIT);
    if (block->data == NULL)
        return -ENOMEM;
    return 0;
void mem_heap_free(struct k_mem_block *block)
    k_heap_free(&my_heap, block->data);
and the call is for
mem_heap_alloc(with 2 page size)
like a double buffer for steaming the
data collected to flash, one page gets
fill with samples while the other is written to flash, in theaory
the other question i will leave for now it is also regarding a try to improve the current spi_nor_write function but anyhow it will not solve the 3ms issue and if it will remain on 1ms per page write as seen in the first test then we will be ok
we think it is a performance issue (which we don't see when the same code runs on nrf52840 with a nand flash, which also writes 2k each time and not 256 pages)
one of the possible solutions is to change the api of the sensor driver so instead of using many time fetch and get, to get one api for fetching a pointer to a buffer of the samples stored in the driver, another idea is to have the driver use easy dma to put the samples to a buffer in memory with an interrupt after reaching 256 bytes, and then write to flash from this buffer. any idea if there is some support for one of this operations in zephyr/ncs ?,
any ideas as for which is better ?
any ideas of beast way to do preferred one ?
hope to read from you soon
best regards
Ziv
  • Hi Ziv
    You mean to say that both the sensor and the flash is accessed without using DMA?
    If so it will make quite a big impact on CPU usage, especially when you want to send a large transaction to the flash device.
    I would strongly recommend integrating DMA, and rather applying the workaround code if you encounter 1 byte transactions. Can you let me know in which file you found the problematic structure with the 1 byte buffer length?
    Regarding the MPU fault, could you try to run your program with the MPU stack guard enabled, and see if you spot the stack overflow quicker?
    CONFIG_MPU_STACK_GUARD=y
    If the issue occurs more often when RAM consumption is higher it could be a stack overflow issue that isn't detected until the stack overflows into other variables.
    Best regards
    Torbjørn
  • hi Torbjørn
    no, the sensor uses ppi and spim (->uses DMA)
    NCS v1.7.1, in the  zephyr/drivers/flash/spi_nor.c , in the implementation of spi_nor_access(...)
    static int spi_nor_access(const struct device *const dev,
    			  uint8_t opcode, unsigned int access,
    			  off_t addr, void *data, size_t length)
    	const struct spi_nor_config *const driver_cfg = dev->config;
    	struct spi_nor_data *const driver_data = dev->data;
    	bool is_addressed = (access & NOR_ACCESS_ADDRESSED) != 0U;
    	bool is_write = (access & NOR_ACCESS_WRITE) != 0U;
    	uint8_t buf[5] = { 0 };
    	struct spi_buf spi_buf[2] = {
    			.buf = buf,
    			.len = 1,
    			.buf = data,
    			.len = length
    when calling the command WREN (write enable) it sends only one byte, also when checking for is flash ready it sends one chunk with length 1 and then the data chunk so in the 1 byte sending it fails.
    i think to avoid this i will just use the nrfx_spim directly from my flash driver make it more efficient as well
    i tested the CONFIG_MPU_STACK_GUARD=y
    not sure what kind of extra information i was supposed to get  ???
    but this is how the MPU FAULT looks like:
    [00000022] 1m<err> os: ***** MPU FAULT *****
    [00000022] <err> os:   Stacking error (context area might be not valid)
    [00000022] [1;31m<err> os: r0/a1:  0xbc1c16a8  r1/a2:  0x7cb9b13d  r2/a3:  0x803faa2e
    [00000022] <err> os: r3/a4:  0x03ff41f3 r12/ip:  0x00000001 r14/lr:  0x00000000
    [00000022] <err> os:  xpsr:  0x81000000
    [00000022] <err> os: s[ 0]:  0x00000000  s[ 1]:  0x00000000  s[ 2]:  0x00000000  s[ 3]:  0xffffffff
    [00000022] <err> os: s[ 4]:  0x00000000  s[ 5]:  0x00000000  s[ 6]:  0x00000000  s[ 7]:  0x00000000
    [00000022] [1;31m<err> os: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0x00000000
    [00000022] <err> os: s[12]:  0x00000000  s[13]:  0x00000000  s[14]:  0x00000000  s[15]:  0xffffffff
    [00000022] <err> os: fpscr:  0x00000000
    [00000022] <err> os: Faulting instruction address (r15/pc): 0x0003e540
    [00000022] <err> os: >>> ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0
    [00000022] <err> os: Current thread: 0x20003228 (unknown)
    [00000023] <err> fatal_error: Resetting system
    also there is still some delays in the app that i don't know where they come from, any tool you can recommend for better understanding that (tried CONFIG_THREAD_ANALIZE it just gives thread stack take and not in real time)  ?
    best regards
    Ziv
  • Hi Ziv
    I am very sorry for the slow response, I was out in holiday for the last 4 weeks.
    Have you had any progress on your end?
    If not I will set aside some time this week to try and reproduce the issue.
    Best regards
    Torbjørn
  • hi Torbjørn
    i actually had a lot of progress, i freed some time from a high priority thread that enable some other things to work better, i changed the nor_spi driver to work with spim and created my own spim layer.
    still there are some issues that i can not figure out, the MPU FAULT i don't understand how to read all the log under it and how can it help me to figure out where the problem is, it sometimes happen and sometimes not, also i can find a tool that will show in real time what tasks/threads are running and when do they context switch and how long does this switching takes
    beside the occasional MPU FAULTS,  when i want to check if flash is ready and loop on it but not all the time but with some delay, i set 50 microsecond between each call to read the flash register but for some reason, as i saw with a picoscop there is a delay of more then 200 microsecond and i don't know why ..
    the blue line is a toggle in the following code section:
    the yello/orange line is the spi clock
    the red line is a function running on a higher priority thread
    static int augu_nor_flash_wait_until_ready(augu_spi_data_t *spi_data, int polling_interval_usec)
    	int ret = 0;
    	int count = 0;
    	uint8_t status_reg[2] = { 0, 1 }; // INITIATED WITH BUSY STATE
    	uint8_t cmd_buf[1] = { SPI_NOR_CMD_RDSR };
    	const struct device *gpio_dev_blue = device_get_binding("GPIO_0");
    	gpio_pin_toggle(gpio_dev_blue, 27);
    	ret = augu_spi_xfer(spi_data, cmd_buf, RDSR_CMD_LENGTH, status_reg, sizeof(status_reg));
    	// gpio_pin_set(gpio_dev_blue, 27, 0);
    	while (!ret && (status_reg[1] & SPI_NOR_WIP_BIT))
    		k_sleep(K_USEC(polling_interval_usec));
    		if(BUSY_CHECKS_COUNTS <= ++count )
    			LOG_ERR("wait for flash busy timed out!!!");
    			return -ETIMEDOUT;
    	return ret;
    so, i need some help to better understand how to extract some info for the MPU FAULTS description (like the once i posted before in this thread and i add more here, maybe they are all the same), the environment what is working and what is happening underneath
     <inf> AUGU_SPI: nrfx_ppi_channel_alloc for spi: chan = 2
    [00000010] <err> os: ***** MPU FAULT *****
    [00000010] <err> os:   Stacking error (context area might be not valid)
    [00000010] <err> os: r0/a1:  0x974b1c56  r1/a2:  0xa9037e23  r2/a3:  0xfd7b35b1
    [00000010] <err> os: r3/a4:  0x04365cc4 r12/ip:  0x00000001 r14/lr:  0x00000000
    [00000010] <err> os:  xpsr:  0x81000000
    [00000010] [1;31m<err> os: s[ 0]:  0x00000000  s[ 1]:  0x00000000  s[ 2]:  0x00000000  s[ 3]:  0x00000000
    [00000010] <err> os: s[ 4]:  0x00000000  s[ 5]:  0x00000000  s[ 6]:  0x00000000  s[ 7]:  0x00000000
    [00000010] <err> os: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0xffffffff
    [00000010] [1;31m<err> os: s[12]:  0x00000000  s[13]:  0x00000000  s[14]:  0x00000000  s[15]:  0xffffffff
    [00000010] <err> os: fpscr:  0x00000000[0m
    [00000010] <err> os: Faulting instruction address (r15/pc): 0x0003febc
    [00000010] <err> os: >>> ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0
    [00000010] <err> os: Current thread: 0x20003200 (unknown)
    [00000011] <err> fatal_error: Resetting system
    [00000016] <inf> AUGU_SPI: nrfx_ppi_channel_alloc for spi: chan = 2
    [00000017] <err> os: ***** MPU FAULT *****
    [00000017] <err> os:   Stacking error (context area might be not valid)
    [00000017] <err> os: r0/a1:  0xfd7b35b1  r1/a2:  0x04365cc4  r2/a3:  0x00000001
    [00000017] <err> os: r3/a4:  0x00000000 r12/ip:  0x00000000 r14/lr:  0xe000ed00
    [00000017] <err> os:  xpsr:  0x81000000[0m
    [00000017] <err> os: s[ 0]:  0x00000000  s[ 1]:  0x00000000  s[ 2]:  0x00000000  s[ 3]:  0x00000000
    [00000017] <err> os: s[ 4]:  0x00000000  s[ 5]:  0x00000000  s[ 6]:  0x00000000  s[ 7]:  0x00000000
    [00000017] <err> os: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0x00000000
    [00000017] <err> os: s[12]:  0x00000000  s[13]:  0xffffffff  s[14]:  0x00000000  s[15]:  0x00000000
    [00000017] [1;31m<err> os: fpscr:  0x00000000
    [00000017] <err> os: Faulting instruction address (r15/pc): 0x000321b8[0m
    [00000017] <err> os: >>> ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0
    [00000017] <err> os: Current thread: 0x20003200 (unknown)
    [00000017] <err> fatal_error: Resetting system
    [00000008] <inf> AUGU_SPI: nrfx_ppi_channel_alloc for spi: chan = 2
    [00000009] <err> os: ***** MPU FAULT *****
    [00000009] <err> os:   Stacking error (context area might be not valid)
    [00000009] <err> os: r0/a1:  0x974b1c56  r1/a2:  0xa9037e23  r2/a3:  0xfd7b35b1
    [00000009] <err> os: r3/a4:  0x04365cc4 r12/ip:  0x20007742 r14/lr:  0x200073e0
    [00000009] <err> os:  xpsr:  0x81000000
    [00000009] <err> os: s[ 0]:  0x00000000  s[ 1]:  0x00000000  s[ 2]:  0x00000000  s[ 3]:  0x00000000
    [00000009] <err> os: s[ 4]:  0x00000000  s[ 5]:  0x00000000  s[ 6]:  0x00000000  s[ 7]:  0x00000000
    [00000009] <err> os: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0x00000000
    [00000009] [1;31m<err> os: s[12]:  0x00000000  s[13]:  0x00000000  s[14]:  0x00000000  s[15]:  0xffffffff
    [00000009] <err> os: fpscr:  0x00000000
    [00000009] <err> os: Faulting instruction address (r15/pc): 0x0003feb2
    [00000009] <err> os: >>> ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0m
    [00000009] <err> os: Current thread: 0x20003200 (unknown)
    [00000010] <err> fatal_error: Resetting system
    [00000009] [1;31m<err> os: r0/a1:  0x974b1c56  r1/a2:  0xa9037e23  r2/a3:  0xfd7b35b1
    [00000009] <err> os: r3/a4:  0x04365cc4 r12/ip:  0x00000001 r14/lr:  0x00000000
    [00000009] <err> os: s[ 0]:  0x00000000  s[ 1]:  0x00000000  s[ 2]:  0x00000000  s[ 3]:  0xffffffff
    [00000009] [1;31m<err> os: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0x00000000
    [00000009] <err> os: s[12]:  0x00000000  s[13]:  0x00000000  s[14]:  0x00000000  s[15]:  0xffffffff
    [00000009] [1;31m<err> os: Current thread: 0x20003200 (unknown)
    [00000017] <inf> AUGU_SPI: nrfx_ppi_channel_alloc for spi: chan = 2
    [00000018] <err> os: ***** MPU FAULT *****
    [00000018] <err> os:   Stacking error (context area might be not valid)
    [00000018] <err> os: r0/a1:  0x974b1c56  r1/a2:  0xa9037e23  r2/a3:  0xfd7b35b1
    [00000018] <err> os: r3/a4:  0x04365cc4 r12/ip:  0x00000001 r14/lr:  0x00000000
    [00000018] <err> os:  xpsr:  0x81000000
    [00000018] <err> os: s[12]:  0x00000000  s[13]:  0x00000000  s[14]:  0x00000000  s[15]:  0xffffffff
    [00000018] <err> os: fpscr:  0x00000000
    [00000018] <err> os: Faulting instruction address (r15/pc): 0x0003feb2
    [00000018] <err> os: >>> ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0
    [00000018] <err> os: Current thread: 0x20003200 (unknown)
    # at restart
    [00000000] <inf> COMM_MNG: Bluetooth advertising started! duration = 30000
    [00000000] <err> os: ***** MPU FAULT *****
    [00000000] <err> os:   Stacking error (context area might be not valid)
    [00000000] <err> os: r0/a1:  0xfd7b35b1  r1/a2:  0x04365cc4  r2/a3:  0x00000001
    [00000000] <err> os: r3/a4:  0x00000000 r12/ip:  0x20003200 r14/lr:  0x00000000
    [00000000] <err> os:  xpsr:  0x81000000
    [00000000] <err> os: s[ 0]:  0x00000000  s[ 1]:  0x00000000  s[ 2]:  0x00000000  s[ 3]:  0x00000000
    [00000000] <err> os: s[ 4]:  0x00000000  s[ 5]:  0x00000000  s[ 6]:  0x00000000  s[ 7]:  0x00000000
    [00000000] <err> os: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0x00000000
    [00000000] <err> os: s[12]:  0x00000000  s[13]:  0x00000000  s[14]:  0x00000000  s[15]:  0xffffffff
    [00000000] <err> os: fpscr:  0x00000000
    [00000000] <err> os: Faulting instruction address (r15/pc): 0x0003feb2
    [00000000] <err> os: >>> ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0
    [00000000] <err> os: Current thread: 0x20003200 (unknown)
    [00000002] <err> fatal_error: Resetting system
    best regards
    Ziv
  • Hi Ziv,
    It seems that you have stack issues, most likely related to the stack size of the current thread running.
    To backtrack a fault, you can use arm-none-eabi-addr2line with the faulting address as an input:
    arm-none-eabi-addr2line -e build-folder/zephyr/zephyr.elf 0x0003febc
    In this case, you probably want to check which thread faulted, which you can check by opening your .map file in build-folder/zephyr/zephyr.map, and find which thread is running on "0x20003200", and then increase the stack for this specific thread.
    If that is the main thread, you can increase it by adjusting "CONFIG_MAIN_STACK_SIZE" in your prj.conf.
    Håkon
