FOTA doesn't work on nrf5340-DK
I am using an nrf5340-DK board and the SDK 1.9.0.
I want integrate the FOTA functionality into the example which was provided by Nordic Semi:
nRF Connect SDK Bluetooth Low Energy tutorial part 1: Custom Service in Peripheral role - Getting Started - nRF Connect SDK guides - Nordic DevZone (nordicsemi.com)
I  made 3 modifications according to "FOTA over Blutooth LE" from here:
https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/ug_nrf5340.html?highlight=over%20air#id25
Modification 1 (main.c)
#include <img_mgmt/img_mgmt.h>
#include <os_mgmt/os_mgmt.h>
#include <mgmt/mcumgr/smp_bt.h>
Modificationn 2 (main.c)
os_mgmt_register_group();
img_mgmt_register_group();
smp_bt_register();
Modification 3 (prj.conf)
CONFIG_MCUMGR=y
CONFIG_MCUMGR_CMD_OS_MGMT=y
CONFIG_MCUMGR_CMD_IMG_MGMT=y
CONFIG_MCUMGR_SMP_BT=y
CONFIG_BOOTLOADER_MCUBOOT=y
Then I create a simple second program which based on "hello_world" example. This program let the LED1 on nrf5340 Board blink let's call it "blinky".
The "blinky" program (app_update.bin) was transfered to the smartphone.
Now the nRF Connect App on the smartphone was started:
DFU was started with "app_update.bin" (blinky) and "Test and Confirm" was selected:
Then I see this for 20 seconds without any progress and "blinky" was not programmed.
I see some similar problems in the DevZone but didn't find the solution for the problem.
What do I have to do to get the FOTA run ?
    If you swipe to the right in your nRF Connect app you should possibly see some log output. Do you get any information in that? Do you have logging or UART output in your application? Do you get any output here which can give an indication on what is failing?
    Thanks.
    Øyvind
  • Hello Øyvind,
    sorry for the delayed answer, I was a few days out of office.
    Here is some additional information:
    1. Wireshark logging
    2. Nrf Connect logging
    Fota.pcapng
    nRF Connect, 2022-06-20
    My_Device (F3:AD:40:4F:4C:4C)
    V	09:56:28.189	Connecting to F3:AD:40:4F:4C:4C...
    D	09:56:28.189	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
    D	09:56:28.719	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
    I	09:56:28.719	Connected to F3:AD:40:4F:4C:4C
    D	09:56:28.719	wait(1600ms)
    D	09:56:28.726	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
    I	09:56:29.165	Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
    I	09:56:29.274	PHY updated (TX: LE 2M, RX: LE 2M)
    I	09:56:29.704	Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 5000ms)
    V	09:56:30.321	Discovering services...
    D	09:56:30.321	gatt.discoverServices()
    D	09:56:30.332	[Callback] Services discovered with status: 0
    I	09:56:30.332	Services discovered
    V	09:56:30.353	Generic Attribute (0x1801)
    - Service Changed [I] (0x2A05)
       Client Characteristic Configuration (0x2902)
    - Client Supported Features [R W] (0x2B29)
    - Database Hash [R] (0x2B2A)
    Generic Access (0x1800)
    - Device Name [R] (0x2A00)
    - Appearance [R] (0x2A01)
    - Peripheral Preferred Connection Parameters [R] (0x2A04)
    Unknown Service (75c276c3-8f97-20bc-a143-b354244886d4)
    - Unknown Characteristic [W WNR] (6acf4f08-cc9d-d495-6b41-aa7e60c4e8a6)
    - Unknown Characteristic [N] (d3d46a35-4394-e9aa-5a43-e7921120aaed)
    SMP Service (8d53dc1d-1db7-4cd3-868b-8a527460aa84)
    - SMP Characteristic [N WNR] (da2e7828-fbce-4e01-ae9e-261174997c48)
    D	09:56:30.353	gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
    D	09:56:30.355	gatt.setCharacteristicNotification(d3d46a35-4394-e9aa-5a43-e7921120aaed, true)
    D	09:56:30.357	gatt.setCharacteristicNotification(d3d46a35-4394-e9aa-5a43-e7921120aaed, true)
    I	09:56:33.934	Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 420ms)
    V	09:56:34.799	[McuMgr] Connecting...
    D	09:56:34.804	[McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M)
    D	09:56:34.836	[McuMgr] [Callback] Connection state changed with status: 0 and new state: 2 (CONNECTED)
    I	09:56:34.839	[McuMgr] Connected to F3:AD:40:4F:4C:4C
    D	09:56:34.843	[McuMgr] wait(1600)
    V	09:56:36.453	[McuMgr] Discovering services...
    D	09:56:36.462	[McuMgr] gatt.discoverServices()
    I	09:56:36.470	[McuMgr] Services discovered
    V	09:56:36.475	[McuMgr] Primary service found
    V	09:56:36.481	[McuMgr] Requesting new MTU...
    D	09:56:36.485	[McuMgr] gatt.requestMtu(498)
    I	09:56:36.544	[McuMgr] MTU changed to: 247
    A	09:56:36.551	[McuMgr] Sending (10 bytes) Header (Op: 0, Flags: 0, Len: 2, Group: 1, Seq: 0, Command: 0) CBOR {}
    V	09:56:36.555	[McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND)
    D	09:56:36.559	[McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48)
    I	09:56:36.568	[McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 00-00-00-02-00-01-00-00-BF-FF
    V	09:57:06.583	[McuMgr] Disconnecting...
    D	09:57:06.590	[McuMgr] gatt.disconnect()
    D	09:57:06.597	[McuMgr] [Callback] Connection state changed with status: 0 and new state: 0 (DISCONNECTED)
    I	09:57:06.603	[McuMgr] Disconnected
    D	09:57:06.610	[McuMgr] gatt.close()
    Is there a example  for the nrf5340 available with running FOTA functionality ?
    Georg
  • Hi Georg! Thanks for providing this information. I will need some time to look into it.
    No sample comes to my mind at the moment. Have you seen the chapter on FOTA upgrades in the nRF5340 DK user guide?
    Øyvind
