Debugging my nrf5sdk code using vs code via make file
I want to use this command nrfjprog --program .\nrf52840_xxaa.hex --sectorerase
and I had this error any idea about how to fix this?
Parsing image file.
WARNING: A programming operation has been performed without --verify.
WARNING: Programming can fail without error.
    Q1: Are you using SoftDevice timeslot API in your application?
    Q2: Are you disabling/enabling global interrupts in your application?
    Håkon
  • I'am using bleutooth and an interruption based on a timer
    maby this code can help
    static void imutimerhandler(void *p_context) {
      //idle_state_handle();
      //greenledon();
      //nrf_delay_ms(10000);
      //greenledoff();
      //  senduart(Pressure_Temperature);
      nrfx_rtc_counter_clear(&rtc);
      nrf_delay_ms(1);
      timer = nrfx_rtc_counter_get(&rtc);
      if (gyroAvailable()) // alias IMU.gyroscopeAvailable
        readGyro(&gx, &gy, &gz);
        NRF_LOG_INFO("Gyroscope Information ");
       NRF_LOG_FLUSH();
        NRF_LOG_RAW_INFO(" gx: " NRF_LOG_FLOAT_MARKER , NRF_LOG_FLOAT(gx));
        NRF_LOG_RAW_INFO(" gy: " NRF_LOG_FLOAT_MARKER , NRF_LOG_FLOAT(gy));
        NRF_LOG_RAW_INFO(" gz: " NRF_LOG_FLOAT_MARKER , NRF_LOG_FLOAT(gz));
        while (go<6){
       ghw[go+3]=ax;
      ghw[go+4]=ay;
      ghw[go+5]=az;
      go=go+4;}
        NRF_LOG_FLUSH();
      if (accelAvailable()) // alias IMU.accelerationAvailable in library version 1.01
        readAccel(&ax, &ay, &az);
        NRF_LOG_INFO("Acceleration Information ");
        NRF_LOG_FLUSH();
        NRF_LOG_RAW_INFO(" ax: " NRF_LOG_FLOAT_MARKER, NRF_LOG_FLOAT(ax));
        NRF_LOG_RAW_INFO(" ay: " NRF_LOG_FLOAT_MARKER, NRF_LOG_FLOAT(ay));
        NRF_LOG_RAW_INFO(" az: " NRF_LOG_FLOAT_MARKER, NRF_LOG_FLOAT(az));
         while (go<6)
        ghw[go]=ax;
      ghw[go+1]=ay;
      ghw[go+2]=az;
      ghw[go+3]=ax;
      go=go+4;}
      if (go>5){for (i=0;i<6;i++)
          NRF_LOG_RAW_INFO("table:" NRF_LOG_FLOAT_MARKER,NRF_LOG_FLOAT(ghw[i]));}
        MotionVariable = (uint16_t)((ax * ax + ay * ay + az * az) * 1000);
        NRF_LOG_INFO("Motion Variable : %d ,", MotionVariable);
        NRF_LOG_FLUSH();
        NRF_LOG_FLUSH();
      if (magnetAvailable()) // alias IMU.magneticFieldAvailable in library version 1.01
        //readMagnet(&mx, &my, &mz);
        //NRF_LOG_INFO("Magnet Information ");
        //NRF_LOG_FLUSH();
        //NRF_LOG_RAW_INFO(" mx: " NRF_LOG_FLOAT_MARKER , NRF_LOG_FLOAT(mx));
        //NRF_LOG_RAW_INFO(" my: " NRF_LOG_FLOAT_MARKER , NRF_LOG_FLOAT(my));
        //NRF_LOG_RAW_INFO(" mz: " NRF_LOG_FLOAT_MARKER , NRF_LOG_FLOAT(mz));
        //NRF_LOG_RAW_INFO("\n\r");
        //NRF_LOG_FLUSH();
      update(-gx, -gy, -gz, ax, ay, az, -mx, my, mz); //EVEN WITH this combination you have to add a - to the pitch to match the previous HAKIM
      computeAngles();
      //NRF_LOG_RAW_INFO(" yaw: " NRF_LOG_FLOAT_MARKER , NRF_LOG_FLOAT(yaw));
      //NRF_LOG_RAW_INFO(" pitch: " NRF_LOG_FLOAT_MARKER , NRF_LOG_FLOAT(pitch));
      //NRF_LOG_RAW_INFO(" roll: " NRF_LOG_FLOAT_MARKER , NRF_LOG_FLOAT(roll));
      position.alpha = (int16_t)roll;
      position.beta = (int16_t)pitch;
      position.gamma = (int16_t)yaw;
      //NRF_LOG_INFO(" alpha : %d  | Beta : %d , ", position.alpha, position.beta);
      //NRF_LOG_INFO("");
      //NRF_LOG_RAW_INFO(" q0: " NRF_LOG_FLOAT_MARKER , NRF_LOG_FLOAT(q0));
      //NRF_LOG_RAW_INFO(" q1: " NRF_LOG_FLOAT_MARKER , NRF_LOG_FLOAT(q1));
      //NRF_LOG_RAW_INFO(" q2: " NRF_LOG_FLOAT_MARKER , NRF_LOG_FLOAT(q2));
      //NRF_LOG_RAW_INFO(" q3: " NRF_LOG_FLOAT_MARKER , NRF_LOG_FLOAT(q3));
      hakim.position = position;
      hakim.body_long = globalDistance;
      CalculPosition_from_mpu(&position);
      Hakim_calcul_distance_to_nose();
      finalDepth = initpressure(&Temp);
      if (initialKalman == 0) {
        Xe = finalDepth;
        initialDepthForKalman = finalDepth;
        initialKalman = 1;
      Pc = Pk + varProcess;
      G = Pc / (Pc + varVolt); // kalman gain
      Pk = (1 - G) * Pc;
      Xp = Xe;
      Zp = Xp;
      Xe = G * (finalDepth - Zp) + Xp; // Result = Gain * ( Variable - ZP ) + Xp
      kalmanFilteredPressure = (uint64_t)Xe;
      CalibratedKalman = kalmanFilteredPressure - initialDepthForKalman;
      BeforeKalman = (uint64_t)finalDepth - initialDepthForKalman;
      // NRF_LOG_INFO("Kalman : %d ", kalmanFilteredPressure);
      if (CalibratedKalman < 0) {
        AffichageBeforeKalman = 0;
      if (BeforeKalman < 0) {
        AffichageAfterKalman = 0;
      if (CalibratedKalman >= 0) {
        AffichageBeforeKalman = BeforeKalman;
      if (BeforeKalman >= 0) {
        AffichageAfterKalman = CalibratedKalman;
      if (Kalmancounter < 10) {
        Kalmancounter = Kalmancounter + 1;
        initialDepthForKalman = kalmanFilteredPressure;
      timer = timer * 125;
      float hz1;
      hz1 = 1000000 / (float)timer;
      Watertonose = hakim.distance_to_nose - CalibratedKalman;
      NRF_LOG_INFO(" Water-Nose distance : %d cm |Nose : %d cm | Depth: %d cm | (Unfiltered : %d)| Position :%x | Time  %d ms ", Watertonose, hakim.distance_to_nose, CalibratedKalman, BeforeKalman, hakim.position.new_position, timer);
      NRF_LOG_FLUSH();
      if (Watertonose < 0) {
        Underwatertimer = Underwatertimer + 100;
        Abovewatertimer = 0;
      if (Watertonose > 0) {
        Abovewatertimer = Abovewatertimer + 100;
        if (Abovewatertimer > 700) {
          Underwatertimer = 0;
      if (Underwatertimer > globalTime*1000) {
        yellowledon();
        NRF_LOG_INFO("Danger !! stayed underwater more than Underwater Time.");
        NRF_LOG_FLUSH();
        DANGER = 0;
      NRF_LOG_INFO("Under:%d | Above: %d | Maximum Time: %d ", Underwatertimer, Abovewatertimer, globalTime*1000);
      NRF_LOG_FLUSH();
      //initial min /max
      if (initialminmax == 0) {
        min = CalibratedKalman - Margin;
        max = CalibratedKalman + Margin;
        initialminmax = 1;
      //up & down detection :
      if (CalibratedKalman > max) {
        changed = 1;
        goingdown = 1;
      if (CalibratedKalman < min) {
        changed = 1;
        goingup = 1;
      if (goingup == 1) {
        // NRF_LOG_INFO("UP");
        greenledon();
        //   redledoff();
      if (goingdown == 1) {
        //NRF_LOG_INFO("Down");
        //  greenledoff();
        redledon();
      if (stable == 1) {
        //NRF_LOG_INFO("unchanged");
        greenledoff();
        redledoff();
      if (changed == 1) {
        stable = 0;
        changed = 0;
        changedtimer = 0;
        starttimer = 1;
      if (starttimer == 1) {
        changedtimer = changedtimer + 100;
        if (changedtimer > 1000) {
          stable = 1;
          goingup = 0;
          goingdown = 0;
      if (stable == 0) {
        unstabletimer = unstabletimer + 100;
        if (unstabletimer == 20000) {
          DANGER = 1;
      if (stable == 1){
    unstabletimer =0;
      NRF_LOG_INFO("changedtimer: %d , unstabletimer %d , Danger %d ",changedtimer,unstabletimer,DANGER);
      NRF_LOG_FLUSH();
      if (DANGER == 1){
      //Rescue();
    If you are still seeing the same assert message, ie. PC=0x15a98, then the issue is related to the application preventing the softdevice to execute interrupts, thus the events occur at a later point and the softdevice detects and asserts due to this.
    Similar issue is described in this thread:  RE: S140 7.2.0 softdevice panic at 0x1786A
    You should check your interrupt priorities and see if certain code in your application disables global interrupts at any point in time.
    Håkon
