Build error
I'm getting an error when building the example program blinky that says: ".text is larger than specified size" and ".rodata is larger than specified size".
I'm using version 17.1.0 of the nRF5 SDK, and version 6.32 of SES for ARM (64 bit).
  • This error typically means your code or constants exceed the allocated flash or RAM memory sizes in the linker script or SES configuration. Check and adjust the memory regions in your project's .ld file or in the SES flappy dunk project settings to match your microcontroller's specifications.
  • I am updating this thread to give you a script to update the flash_placement.xml to work with newer SES versions.
    For example for updating the UART peripheral sample flash_placement file you just need to run something like this
    python3 ses_unlimit_text_rodata.py examples/peripheral/uart/pca10100e/blank/ses/flash_placement.xml
    If you want to do a dry run fist then you can do
    python3 tools/ses_unlimit_text_rodata.py --dry-run examples/peripheral/uart/pca10100e/blank/ses/flash_placement.xml
    #!/usr/bin/env python3
    import argparse
    import difflib
    from pathlib import Path
    import re
    import sys
    def _strip_size_attr(xml_text, section_name):
        name = re.escape(section_name)
        # Case: name appears before size attribute.
        pattern_before = re.compile(
            r'(<ProgramSection\b[^>]*\bname="' + name + r'"[^>]*?)\s+size="[^"]+"'
        xml_text = pattern_before.sub(r"\1", xml_text)
        # Case: size attribute appears before name.
        pattern_after = re.compile(
            r'(<ProgramSection\b[^>]*?)\s+size="[^"]+"([^>]*\bname="' + name + r'"[^>]*>)'
        xml_text = pattern_after.sub(r"\1\2", xml_text)
        return xml_text
    def _iter_flash_placements(paths):
        for path in paths:
            if path.is_file():
                if path.name == "flash_placement.xml":
                    yield path
                continue
            if not path.is_dir():
                continue
            for xml_path in path.rglob("flash_placement.xml"):
                if "ses" not in xml_path.parts:
                    continue
                yield xml_path
    def main(argv):
        parser = argparse.ArgumentParser(
            description="Remove size limits from .text/.rodata in SES flash_placement.xml files."
        parser.add_argument(
            "paths",
            nargs="*",
            help="Files or directories to scan (default: current directory).",
            "--dry-run",
            action="store_true",
            help="Print files that would be modified without writing.",
        args = parser.parse_args(argv)
        roots = [Path(p) for p in args.paths] if args.paths else [Path.cwd()]
        modified = []
        for xml_path in _iter_flash_placements(roots):
            try:
                xml_text = xml_path.read_text(encoding="utf-8")
            except OSError:
                continue
            updated = _strip_size_attr(xml_text, ".text")
            updated = _strip_size_attr(updated, ".rodata")
            if updated != xml_text:
                modified.append(xml_path)
                if not args.dry_run:
                    xml_path.write_text(updated, encoding="utf-8")
        if args.dry_run:
            if modified:
                for path in modified:
                    original = path.read_text(encoding="utf-8")
                    updated = _strip_size_attr(original, ".text")
                    diff = difflib.unified_diff(
                        original.splitlines(keepends=True),
                        updated.splitlines(keepends=True),
                        fromfile=str(path),
                        tofile=str(path),
                    sys.stdout.writelines(diff)
            else:
                print("no changes needed")
        else:
            if modified:
                print("updated {} file(s)".format(len(modified)))
            else:
        return 0
    if __name__ == "__main__":
        raise SystemExit(main(sys.argv[1:]))
