I have previously used the ESP8266 WiFi module and it has worked great. Since I have updated to the latest SDK, I am now seeing problems. I'm guessing something has changed in the config settings?
I build my code using the following
cmake -GNinja -DBOARD=nrf52840dongle_nrf52840 -DCONF_FILE="prj.conf" .. -DSHIELD=esp_8266
My proj file looks like this
CONFIG_BOARD_HAS_NRF5_BOOTLOADER=n CONFIG_STDOUT_CONSOLE=y CONFIG_PRINTK=y CONFIG_UART_CONSOLE=y CONFIG_GPIO=y CONFIG_WIFI=y CONFIG_EARLY_CONSOLE=y CONFIG_NETWORKING=y CONFIG_NET_TX_STACK_SIZE=2048 CONFIG_NET_RX_STACK_SIZE=2048 CONFIG_NET_PKT_RX_COUNT=10 CONFIG_NET_PKT_TX_COUNT=10 CONFIG_NET_BUF_RX_COUNT=20 CONFIG_NET_BUF_TX_COUNT=20 CONFIG_NET_MAX_CONTEXTS=10 CONFIG_NET_IPV4=y CONFIG_NET_IPV6=n CONFIG_NET_TCP=y CONFIG_NET_LOG=y CONFIG_INIT_STACKS=y CONFIG_NET_SHELL=y CONFIG_NET_STATISTICS=y CONFIG_NET_STATISTICS_PERIODIC_OUTPUT=n CONFIG_WIFI_LOG_LEVEL_ERR=y CONFIG_NET_L2_WIFI_SHELL=y
and my overlay file is this
&uart0 {
compatible = "nordic,nrf-uart";
status = "okay";
current-speed = <115200>;
tx-pin = <24>;
rx-pin = <22>;
&uart1 {
status = "okay";
tx-pin = <45>;
rx-pin = <47>;
esp8266{
compatible = "espressif,esp-at";
label = "esp8266";
status = "okay";
However, I now get the following errors
[5/276] Generating include/generated/driver-validation.h
/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/scripts/gen_kobject_list.py:66: DeprecationWarning: distutils Version classes are deprecated. Use packaging.version instead.
if LooseVersion(elftools.__version__) < LooseVersion('0.24'):
[6/276] Generating include/generated/k...r.h, include/generated/otype-to-size.h
[266/276] Building C object zephyr/CMa.../zephyr.dir/drivers/wifi/esp/esp.c.obj
FAILED: zephyr/CMakeFiles/zephyr.dir/drivers/wifi/esp/esp.c.obj
ccache /opt/nordic/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DBUILD_VERSION=zephyr-v2.5.0-2316-g36d96d2cd9b9 -DKERNEL -DNRF52840_XXAA -D_FORTIFY_SOURCE=2 -D__PROGRAM_START -D__ZEPHYR__=1 -I/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/kernel/include -I/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/arch/arm/include -I/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/drivers/modem -I/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/include -Izephyr/include/generated -I/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/soc/arm/nordic_nrf/nrf52 -I/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/lib/util/fnmatch/. -I/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/modules/hal/cmsis/CMSIS/Core/Include -I/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/modules/hal/nordic/nrfx -I/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/modules/hal/nordic/nrfx/drivers/include -I/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/modules/hal/nordic/nrfx/mdk -I/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/modules/hal_nordic/nrfx/. -isystem /Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/lib/libc/minimal/include -isystem /opt/nordic/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/include -isystem /opt/nordic/ncs/toolchains/v2.0.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/include-fixed -Os -imacros /Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/New_Code/ESP8266/build/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -mcpu=cortex-m4 -mthumb -mabi=aapcs -imacros /Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/include/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-address-of-packed-member -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/New_Code/ESP8266=CMAKE_SOURCE_DIR -fmacro-prefix-map=/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT zephyr/CMakeFiles/zephyr.dir/drivers/wifi/esp/esp.c.obj -MF zephyr/CMakeFiles/zephyr.dir/drivers/wifi/esp/esp.c.obj.d -o zephyr/CMakeFiles/zephyr.dir/drivers/wifi/esp/esp.c.obj -c /Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/drivers/wifi/esp/esp.c
In file included from /Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/include/arch/arm/aarch32/arch.h:20,
from /Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/include/arch/cpu.h:19,
from /Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/include/kernel_includes.h:33,
from /Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/include/kernel.h:17,
from /Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/drivers/wifi/esp/esp.c:13:
/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/drivers/wifi/esp/esp.c: In function 'esp_init':
/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/include/devicetree.h:300:40: error: 'DT_N_INST_0_espressif_esp_BUS_P_hw_flow_control' undeclared (first use in this function)
300 | #define DT_INST(inst, compat) UTIL_CAT(DT_N_INST, DT_DASH(inst, compat))
/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/include/devicetree.h:2251:24: note: in definition of macro 'DT_CAT'
2251 | #define DT_CAT(a1, a2) a1 ## a2
/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/drivers/wifi/esp/esp.c:1124:37: note: in expansion of macro 'DT_PROP'
1124 | data->iface_data.hw_flow_control = DT_PROP(ESP_BUS, hw_flow_control);
/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/include/devicetree.h:1694:25: note: in expansion of macro 'DT_CAT'
1694 | #define DT_BUS(node_id) DT_CAT(node_id, _BUS)
/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/drivers/wifi/esp/esp.h:62:17: note: in expansion of macro 'DT_BUS'
62 | #define ESP_BUS DT_BUS(DT_DRV_INST(0))
/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/include/sys/util_internal.h:84:26: note: in expansion of macro 'UTIL_PRIMITIVE_CAT'
84 | #define UTIL_CAT(a, ...) UTIL_PRIMITIVE_CAT(a, __VA_ARGS__)
/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/include/devicetree.h:300:31: note: in expansion of macro 'UTIL_CAT'
/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/include/devicetree.h:1745:27: note: in expansion of macro 'DT_INST'
1745 | #define DT_DRV_INST(inst) DT_INST(inst, DT_DRV_COMPAT)
/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/drivers/wifi/esp/esp.h:62:24: note: in expansion of macro 'DT_DRV_INST'
/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/drivers/wifi/esp/esp.c:1124:45: note: in expansion of macro 'ESP_BUS'
/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/include/devicetree.h:300:40: note: each undeclared identifier is reported only once for each function it appears in
/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/include/devicetree.h:300:40: error: 'DT_N_INST_0_espressif_esp_BUS_P_label' undeclared (first use in this function); did you mean 'DT_N_INST_0_espressif_esp_at'?
/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/include/devicetree.h:1701:31: note: in expansion of macro 'DT_PROP'
1701 | #define DT_BUS_LABEL(node_id) DT_PROP(DT_BUS(node_id), label)
/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/include/devicetree.h:1701:39: note: in expansion of macro 'DT_BUS'
/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/include/devicetree.h:2047:33: note: in expansion of macro 'DT_BUS_LABEL'
2047 | #define DT_INST_BUS_LABEL(inst) DT_BUS_LABEL(DT_DRV_INST(inst))
/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/include/devicetree.h:2047:46: note: in expansion of macro 'DT_DRV_INST'
/Users/Watt/Documents/ZEPHYR_Code/nRF52840_Dongle/zephyr/drivers/wifi/esp/esp.c:1128:9: note: in expansion of macro 'DT_INST_BUS_LABEL'
1128 | DT_INST_BUS_LABEL(0));
[267/276] Linking C static library zephyr/kernel/libkernel.a
Parsing image file.
Look forward to your comments,
Rod
