Bootloader Update with new size over BLE DFU service
Hi
Is there a possibility to update the bootloader himself over the BLE DFU?
I have a new bootloader with a bigger size (MemoryMap changed) and I am wondering if I can upload old boards with the small bootloader over BLE DFU with the Nordic nrf Connect App, because there is under SelectFileType (Bootloader). Is this possible only if the size and memory map is equal or even if the size is bigger?
I checked if I can download te new Ditribution Packet (ZIP) on the old device with the old small bootloader, and yes, its possible. The application is new but the bootloader is still the old one. Even after Powereset the application is running wit the old bootloader, this makes me a little bit confusing, ow is this possible?
See: https://devzone.nordicsemi.com/f/nordic-q-a/89328/ota-dfu-bootloader-memory-map-increasing-size-in-pca10056_s140_ble
Regards, Dominik
  • I don't understand the use case precisely. Is the bootloader that is on the device built with a timeout enabled, and what is that timeout? Can you test with a debug bootloader with RTT logging and check the log?
    A last point: If your WH is using a LFRC instead of an LFXO and WDT, then you may be seeing a bug in the bootloader where the LFCLK is not beng properly started after a soft reset, which prevents the inactivity timer from working. The fix for this is to modify this part of timer_init() in components\libraries\bootloader\nrf_bootloader_dfu_timers.c:
            if (!nrf_clock_lf_is_running())
                nrf_clock_task_trigger(NRF_CLOCK_TASK_LFCLKSTART);
    and reduce it to this:
  • The time is ok. I had the default time of 120s on my old bootloader. This is working correctly. Then I flash with the nrf connect app the new zip file with the new bootloader merged with 30s.
    Now If I do a DFU OTA with a corrupted (wrong private key) zip file, the DFU is starting, dects the wrong key and disconnect BLE. all correct. Then the bootloder start the inactive delay and switch back to application after time x. But this time is still 120s instead of 30s. An Update to 30s is only happening if I flash the nRF over the cable with nrfjprog.
    Or do I have to do a power on Reset after OTA manually (which is happening with the nrfjprog of course)
  • Hm, that does not make sense to me. The timer is all handled in SW, so if the new bootloader with 30 s timeout is what is running, the timeout should be 30 s. Did you successfully update to the new bootloader with 30s timeout (via DFU) before you tested updating to an image with invalid key that should fail? Or is it still the old bootloader that is running on the device? If it is the old, this is as expected. As this seems really odd, I suggest you verify that the new bootloader is running when this happens. For instance by adding different log string in the two versions, or toggling different GPIO's, or some other method you can use to easily see which bootloader version is actually running on the device.
    Power-on reset is not needed. (A bootloader-update involves a soft reset reset as the MBR is responsible for copying the bootloader and that runs first, but this is part of the update procedure, and as long as it is successful all is good).
  • I will test again, yes t really sounds strange but I will check this again. Thanks
  • Hi
    Coming back to this topic. I found the "Bug". The generated zip package with the line:
    nrfutil pkg generate --hw-version 52 ...
    only contained the hex file from the application. If I do the same for the bootloader, I can update only the bootloader over OTA:
    nrfutil pkg generate --hw-version 52 --sd-req 0x0100 --bootloader-version 1 --bootloader boot_test.hex --key-file private.key G3_bootloader.zip
    and its working.
    Is there a possibility to create a zip package which includes the app and bootloader?
    Here they are discussing the same "Problem" and is the only solution 2 zip packages? is there no other solution?
    https://devzone.nordicsemi.com/f/nordic-q-a/63895/how-to-generate-a-bootloader-softdevice-application-zip-for-ota-updates-dfu/261014
    Thanks for any inputs
