Hi there,
I think that I am seeing the repercussions of errata item 136 in my application. I abruptly turn on/off power several times to my board, and every once in a while the device will boot with a watchdog timer reset reason. I am using SDK 14.2.0 with SD 5.1.0
I do see in the errata documentation that a workaround has been implemented in MDK 8.13.0 and later, and in newer versions (8.44.0) of the MDK I see the workaround present in system_nrf52.c. However, in my project (which is using MDK 8.15.0) I do not see this workaround present in system_nrf52.c. Can you verify that this fix is indeed in MDK 8.15.0, and if it is, where does the fix reside?
Best,
Matthew
