nrf52840 S140 Central DFU Bluetooth Zephyr 2.0.0 nrf52840 peripheral
We have nrf52840 S140 BLE Central device that currently connects to TI based sensors. I have implemented code that can upgrade those TI sensors' firmware using the TI BLE protocol.
Now we are developing our own BLE peripheral sensors also based on the nrf52840 but now using the newly supported Zephyr 2.0.0. RF connect stuff. I can update the sensors using the Nordic Android program (unauthenticated for now) and now need to implement upgrading BLE DFU using our central device which connects to a cellular gateway.
I do not want to reinvent the wheel, writing existing code, like I had to do with the TI sensors.
Could you point me to code that allows a Central device to update a peripheral device BLE DFU?
If not where can I look to reinvent another wheel?
Thanks David
  • Thanks for your help.
    After thinking I was advancing on the DFU, I must have changed something in the central or the sensor since I can't seem to upload now.  I created two images with just my date changed that I wanted to test between them. I do not get a reply from my first packet. My images are not built with the imgtool .
    The cellular nRFConnect app behaves differently each time.
    Connecting,Starting DFU,Upload,Validating (long time) & Disconnect.
    Sometimes there is no Upload.
    Very frustrating...
    Probably not my place to ask, but:
    Do you use git?
    It would make it easier to track your changes and figure out what changed since last time.
    Most people use git, so I assume you do. Just had to check in case not.
    However, know that it can definitively be frustrating even with git, especially when I (usually) forget to make commits as frequently as I maybe should.
    Sigurd Hellesvik
  • You are most likely correct that i should use git as now I take a zip snap-shot once or twice a day.
    I found that I had recompiled my sensor code deleting my manual BLE image transfer code since I am hoping to get the SMP stuff working and that was causing the problem. Most likely a proj.confg define that I had added for manual BLE image transfer, but I will figure out that later on.
    Now I tried without the image tool to upload, list, test & reset and the reset command does not work.
    Do I need a special define for It?
    01-09 13:08 09/01/2023 11:08:42 |  09/01/2023 13:09:09[.ami_vibe.c:1885] CentralStatusReply OnLine:0F
    01-09 13:08 09/01/2023 11:08:42 |  09/01/2023 13:09:09[.ami_vibe.c:1941] ...[ami_smp.c: 683] DFU:369200/372827
    01-09 13:08 09/01/2023 11:08:42 |  09/01/2023 13:09:09[.ami_vibe.c:1941] ...[ami_smp.c: 683] DFU:369600/372827
    01-09 13:08 09/01/2023 11:08:42 |  09/01/2023 13:09:09[.ami_vibe.c:1941] ...[ami_smp.c: 683] DFU:370000/372827
    01-09 13:08 09/01/2023 11:08:42 |  09/01/2023 13:09:09[.ami_vibe.c:1941] ...[ami_smp.c: 683] DFU:370400/372827
    01-09 13:08 09/01/2023 11:08:42 |  09/01/2023 13:09:09[.ami_vibe.c:1941] ...[ami_smp.c: 683] DFU:370800/372827
    01-09 13:08 09/01/2023 11:08:42 |  09/01/2023 13:09:09[.ami_vibe.c:1941] ...[ami_smp.c: 683] DFU:371200/372827
    01-09 13:08 09/01/2023 11:08:42 |  09/01/2023 13:09:09[.ami_vibe.c:1941] ...[ami_smp.c: 683] DFU:371600/372827
    01-09 13:08 09/01/2023 11:08:42 |  09/01/2023 13:09:09[.ami_vibe.c:1941] ...[ami_smp.c: 683] DFU:372000/372827
    01-09 13:08 09/01/2023 11:08:42 |  09/01/2023 13:09:10[.ami_vibe.c:1941] ...[ami_smp.c: 683] DFU:372400/372827
    01-09 13:08 09/01/2023 11:08:42 |  09/01/2023 13:09:10[.ami_vibe.c:1941] ...[ami_smp.c: 683] DFU:372800/372827
    01-09 13:08 09/01/2023 11:08:43 |  09/01/2023 13:09:10[.ami_vibe.c:1941] ...[ami_smp.c: 843] SMP UploadOK
    01-09 13:08 09/01/2023 11:08:43 |  09/01/2023 13:09:10[.ami_vibe.c:1941] ...[ami_smp.c:1127] ImageList
    01-09 13:08 09/01/2023 11:08:43 |  09/01/2023 13:09:10[.ami_vibe.c:1941] ...[ami_smp.c:1130] ImageTest
    01-09 13:08 09/01/2023 11:08:43 |  09/01/2023 13:09:11[.ami_vibe.c:1941] ...[ami_smp.c:1133] ImageReset
    Now I tried without the image tool to upload, list & test and after manually resetting the sensor, the uploaded image was not running.
    01-09 13:18 09/01/2023 11:18:36 |  09/01/2023 13:19:04[.ami_vibe.c:1941] ...[ami_smp.c: 683] DFU:370800/372827
    01-09 13:18 09/01/2023 11:18:37 |  09/01/2023 13:19:04[.ami_vibe.c:1941] ...[ami_smp.c: 683] DFU:371200/372827
    01-09 13:18 09/01/2023 11:18:37 |  09/01/2023 13:19:04[.ami_vibe.c:1941] ...[ami_smp.c: 683] DFU:371600/372827
    01-09 13:18 09/01/2023 11:18:37 |  09/01/2023 13:19:04[.ami_vibe.c:1941] ...[ami_smp.c: 683] DFU:372000/372827
    01-09 13:18 09/01/2023 11:18:37 |  09/01/2023 13:19:04[.ami_vibe.c:1941] ...[ami_smp.c: 683] DFU:372400/372827
    01-09 13:18 09/01/2023 11:18:37 |  09/01/2023 13:19:04[.ami_vibe.c:1941] ...[ami_smp.c: 683] DFU:372800/372827
    01-09 13:18 09/01/2023 11:18:37 |  09/01/2023 13:19:04[.ami_vibe.c:1941] ...[ami_smp.c: 843] SMP UploadOK
    01-09 13:18 09/01/2023 11:18:37 |  09/01/2023 13:19:04[.ami_vibe.c:1941] ...[ami_smp.c:1127] ImageList
    01-09 13:18 09/01/2023 11:18:37 |  09/01/2023 13:19:04[.ami_vibe.c:1941] ...[ami_smp.c:1130] ImageTest
    01-09 13:18 09/01/2023 11:18:38 |  09/01/2023 13:19:05[.ami_vibe.c:1941] ...[ami_ble.c:2561] DFUConnectFinishedErr:0
    I was able to get the image to update at some point yesterday.
    I guess I can try the image tool but I would like to get the SMP reset to work also.
    I run the tool after I build with VSCode?
    static int send_smp_reset(struct bt_dfu_smp *dfu_smp,const char *string)
    	static struct smp_buffer smp_cmd;
    	zcbor_state_t zse[CBOR_ENCODER_STATE_NUM];
    	size_t payload_len;
    	zcbor_new_encode_state(zse, ARRAY_SIZE(zse), smp_cmd.payload,
    			       sizeof(smp_cmd.payload), 0);
    	/* Stop encoding on the error. */
    	zse->constant_state->stop_on_error = true;
    	zcbor_map_start_encode(zse, CBOR_MAP_MAX_ELEMENT_CNT);
    	zcbor_tstr_put_lit(zse, "d");
    	zcbor_tstr_put_term(zse, string);
    	zcbor_map_end_encode(zse, CBOR_MAP_MAX_ELEMENT_CNT);
    	if (!zcbor_check_error(zse)) {
    		d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Failed to encode SMP reset packet, err: %d", zcbor_pop_error(zse));
    		return -EFAULT;
    	payload_len = (size_t)(zse->payload - smp_cmd.payload);
    	smp_cmd.header.op = 2; /* Write */
    	smp_cmd.header.flags = 0;
    	smp_cmd.header.len_h8 = 0;
    	smp_cmd.header.len_l8 = 0;
    	smp_cmd.header.group_h8 = 0;
    	smp_cmd.header.group_l8 = 0; /* OS */
    	smp_cmd.header.seq = 0;
    	smp_cmd.header.id  = 5; /* RESET */
    	return bt_dfu_smp_command(dfu_smp, smp_reset_rsp_proc,
    				  sizeof(smp_cmd.header) + payload_len,
    				  &smp_cmd);
    } // send_smp_reset
    Thanks David
  • OK.
    I flashed by the programmer a sensor with new code.
    I then uploaded successfully an unsigned image or at least  smp_upload_rsp_proc() finished without error.
    When I performed a list the central again crashed. I disconnected in the code again the sensor and saw yet another place there was an array overflow:
    			//decoding version value
    			char version_value[16]; // ?!? len=5 was [5]
    			ok = zcbor_tstr_decode(zsd, &value);
    I also saw that the Listed second slot (10 was not listed so its hash_value_secondary_slot was not retrieved. It is used in both Test and confirm!
    I could dynamically check every array value.len before copying or just increase all.
    How do I know that tomorrow I will not overflow somewhere?
    Another image that I also programmed never returned from the first upload packet.
    I need to have bullet proof BLE DFU with maybe oe or two retries.
    That is the reason that I put on hold my own image BLE image transfer and write mechanism.
    It worked sometimes 2/3 of the time.
    Tomorow I may try the signed image, but it does not look trivial to set up.
    I may need to work on other projects.
    On this project, I am left just with BLE DFU upgrades.
     1) SMP reset did not work.
     2) List gave only slot zero so could not use test or confirm.
    Thanks David
  • This morning I tried to upload to DFU and got stuck after the first block. My sensor flashes its led when connected and it did not keep flashing.
     I changed my sensor proj.cong file to have all of the defines as in the smp_srv example.
    I added the --pad in the proj
    CONFIG_REBOOT=y
    CONFIG_MCUBOOT_EXTRA_IMGTOOL_ARGS="--pad"
    #stCount
    # Copyright (c) 2018 Nordic Semiconductor
    # smp_srv proj.confg below:
    # Enable mcumgr.
    CONFIG_MCUMGR=y
    # Some command handlers require a large stack.
    # ?!? remarked 10-01-2023 CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2304
    CONFIG_MAIN_STACK_SIZE=2048
    # Ensure an MCUboot-compatible binary is generated.
    CONFIG_BOOTLOADER_MCUBOOT=y
    # Enable flash operations.
    CONFIG_FLASH=y
    # Required by the `taskstat` command.
    CONFIG_THREAD_MONITOR=y
    # Support for taskstat command
    CONFIG_OS_MGMT_TASKSTAT=y
    # Enable statistics and statistic names.
    CONFIG_STATS=y
    CONFIG_STATS_NAMES=y
    # Enable most core commands.
    CONFIG_MCUMGR_CMD_IMG_MGMT=y
    CONFIG_MCUMGR_CMD_OS_MGMT=y
    CONFIG_MCUMGR_CMD_STAT_MGMT=y
    # Enable logging
    CONFIG_LOG=y
    CONFIG_MCUBOOT_UTIL_LOG_LEVEL_WRN=y
    # smp_srv overlay-bt.confg below:
    # Allow for large Bluetooth data packets.
    CONFIG_BT_L2CAP_TX_MTU=498
    CONFIG_BT_BUF_ACL_RX_SIZE=502
    CONFIG_BT_BUF_ACL_TX_SIZE=502
    CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
    # Enable the Bluetooth mcumgr transport (unauthenticated).
    CONFIG_MCUMGR_SMP_BT=y
    CONFIG_MCUMGR_SMP_BT_AUTHEN=n
    CONFIG_MCUMGR_SMP_BT_CONN_PARAM_CONTROL=y
    # Enable the Shell mcumgr transport.
    # ?!? remarked 10-01-2023 CONFIG_MCUMGR_SMP_SHELL=y
    # Enable the mcumgr Packet Reassembly feature over Bluetooth and its configuration dependencies.
    # MCUmgr buffer size is optimized to fit one SMP packet divided into five Bluetooth Write Commands,
    # transmitted with the maximum possible MTU value: 498 bytes.
    CONFIG_MCUMGR_SMP_REASSEMBLY_BT=y
    CONFIG_MCUMGR_BUF_SIZE=2475
    CONFIG_OS_MGMT_MCUMGR_PARAMS=y
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
    # Enable the LittleFS file system.
    CONFIG_FILE_SYSTEM=y
    CONFIG_FILE_SYSTEM_LITTLEFS=y
    # Enable file system commands
    CONFIG_MCUMGR_CMD_FS_MGMT=y
    # Enable the storage erase command.
    CONFIG_MCUMGR_GRP_ZEPHYR_BASIC=y
    CONFIG_MCUMGR_GRP_BASIC_CMD_STORAGE_ERASE=y
    # New definions below:
    CONFIG_REBOOT=y
    # AMI definions below:
    CONFIG_REBOOT=y
    CONFIG_BT=y
    CONFIG_BT_DEBUG_LOG=y
    CONFIG_BT_PERIPHERAL=y
    CONFIG_BT_DEVICE_APPEARANCE=1344
    CONFIG_BT_MAX_CONN=1
    #CONFIG_BT_LL_SOFTDEVICE=y
    CONFIG_BT_DEVICE_NAME="VaporBLE"
    # Enable Dynamic name modification
    CONFIG_BT_DEVICE_NAME_DYNAMIC=y
    # Maximum character of the device name
    # (Range: 2 to 248)
    CONFIG_BT_DEVICE_NAME_MAX=20
    # ?!? remarked 10-01-2023 CONFIG_BT_SMP=y
    # ?!? remarked 10-01-2023 CONFIG_BT_SIGNING=y
    # If yes then there is a random MAC advertised
    CONFIG_BT_PRIVACY=n
    # Allow for updating data length
    CONFIG_BT_USER_DATA_LEN_UPDATE=y
    # Allow for Phy change
    CONFIG_BT_USER_PHY_UPDATE=y
    # Device Information
    CONFIG_BT_DIS=y
    CONFIG_BT_DIS_PNP=n
    CONFIG_BT_DIS_MODEL="VaporBT"
    CONFIG_BT_DIS_MANUF="AMI Global"
    CONFIG_BT_DIS_SERIAL_NUMBER=y
    CONFIG_BT_DIS_SERIAL_NUMBER_STR="0523382370"
    CONFIG_BT_DIS_FW_REV=y
    CONFIG_BT_DIS_FW_REV_STR="000.000"
    CONFIG_BT_DIS_HW_REV=y
    CONFIG_BT_DIS_HW_REV_STR="000.000"
    CONFIG_BT_DIS_SW_REV=y
    CONFIG_BT_DIS_SW_REV_STR="000.000"
    CONFIG_BT_DIS_SETTINGS=y
    CONFIG_BT_DIS_STR_MAX=21
    # Below is setup to let DIS information be read from settings
    CONFIG_BT_SETTINGS=y
    CONFIG_SETTINGS_RUNTIME=y
    CONFIG_SETTINGS=y
    CONFIG_SETTINGS_NONE=y
    # TX Power
    #CONFIG_BT_CTLR_TX_PWR_PLUS_4=y
    #CONFIG_BT_CTLR_ADVANCED_FEATURES=y
    #CONFIG_BT_CTLR_CONN_RSSI=y
    CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL=y
    # Passkey not used
    CONFIG_BT_AMI_CM_SECURITY_ENABLED=y
    CONFIG_HEAP_MEM_POOL_SIZE=32768
    CONFIG_FPU=y
    CONFIG_NEWLIB_LIBC=y
    # for Spectral|Impact DSP
    CONFIG_CMSIS_DSP=y
    CONFIG_CMSIS_DSP_SUPPORT=y
    CONFIG_CMSIS_DSP_FASTMATH=y
    CONFIG_CMSIS_DSP_COMPLEXMATH=y
    CONFIG_CMSIS_DSP_STATISTICS=y
    CONFIG_CMSIS_DSP_TRANSFORM=y
    #CONFIG_CMSIS_DSP_TABLES_ALL_FAST=y
    #CONFIG_CMSIS_DSP_TABLES_ALL_FFT=y
    CONFIG_CMSIS_DSP_TABLES_ALL_FAST=n
    CONFIG_CMSIS_DSP_TABLES_ALL_FFT=n
    CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F32_32=y
    CONFIG_CMSIS_DSP_TABLES_ARM_SIN_F32=y
    CONFIG_CMSIS_DSP_TABLES_ARM_COS_F32=y
    CONFIG_CMSIS_DSP_TABLES_ARM_CMPLX_MAG_Q31=y
    CONFIG_CMSIS_DSP_TABLES_RFFT_F32_512=y
    # Watchdog
    #CONFIG_WDT_LOG_LEVEL_DBG=y
    CONFIG_WATCHDOG=y
    # GPIO
    CONFIG_GPIO=y
    # I2c for 24LC512
    CONFIG_I2C=y
    CONFIG_I2C_NRFX=y
    CONFIG_I2C_LOG_LEVEL_OFF=y
    # EEPROM
    CONFIG_EEPROM=y
    CONFIG_EEPROM_AT24=y
    # SPI for LSM6DSL
    CONFIG_SPI=y
    CONFIG_NRFX_SPIM1=y
    # LSM6DSL
    CONFIG_SENSOR=y
    CONFIG_LSM6DSL=y
    CONFIG_AMI_LSM6DSL_EXTEND_CFG=y
    CONFIG_LSM6DSL_ACCEL_FS=2
    CONFIG_LSM6DSL_ACCEL_ODR=0
    # Power management
    CONFIG_PM=y
    CONFIG_PM_DEVICE=y
    CONFIG_PM_DEVICE_RUNTIME=y
    #CONFIG_PM_STATS=y
    #CONFIG_STATS=y
    CONFIG_PINCTRL=y
    CONFIG_MULTITHREADING=y
    # ADC
    CONFIG_ADC=y
    CONFIG_ADC_ASYNC=y
    # Timers
    CONFIG_NRFX_TIMER1=y
    # USE RTT  Instead of Uart
    CONFIG_CONSOLE=y
    CONFIG_RTT_CONSOLE=y
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_LOG_BACKEND_RTT=y
    # below for Cellular DFU
    # ?!? remarked 10-01-2023 CONFIG_ZCBOR=y
    # ?!? remarked 10-01-2023 CONFIG_ZCBOR_STOP_ON_ERROR=y
    # below for DFU
    # Enable mcumgr.
    # ?!? remarked 10-01-2023 CONFIG_MCUMGR=y
    # DFU Target ?!? new
    # ?!? remarked 10-01-2023 CONFIG_DFU_TARGET=y
    # ?!? remarked 10-01-2023 CONFIG_DFU_TARGET_MCUBOOT=y
    # ?!? remarked 10-01-2023 CONFIG_STREAM_FLASH_ERASE=y
    # ?!? remarked 10-01-2023 CONFIG_STREAM_FLASH=y
    # ?!? remarked 10-01-2023 CONFIG_IMG_ERASE_PROGRESSIVELY=y
    # nRF9160 Flash page is 0x1000 = 4096
    # ?!? remarked 10-01-2023 CONFIG_IMG_BLOCK_BUF_SIZE=4096
    # ?!? new 14-Dec-2022
    # ?!? remarked 10-01-2023 CONFIG_IMG_MANAGER=y
    # ?!? remarked 10-01-2023 CONFIG_MCUBOOT_IMG_MANAGER=y
    CONFIG_RING_BUFFER=y
    # The image management command handlers makes it possible to upload, list, test and confirm the image(s)
    # ?!? remarked 10-01-2023 CONFIG_MCUMGR_CMD_IMG_MGMT=y
    # The OS management command handlers makes it possible to reset the chip (and run the echo command).
    # ?!? remarked 10-01-2023 CONFIG_MCUMGR_CMD_OS_MGMT=y
    # ?!? remarked 10-01-2023 CONFIG_BOOTLOADER_MCUBOOT=y
    # Allow for large Bluetooth data packets for uploading binary (Nordic Definitions)
    # commented when smp srv stuff added
    #CONFIG_BT_L2CAP_TX_MTU=252
    #CONFIG_BT_BUF_ACL_RX_SIZE=256
    # Enable the Bluetooth (unauthenticated) and shell mcumgr transports.
    # ?!? remarked 10-01-2023 CONFIG_MCUMGR_SMP_BT=y
    # ?!? remarked 10-01-2023 CONFIG_MCUMGR_SMP_BT_AUTHEN=n
    # Below from the throughput example
    # ?!? remarked 10-01-2023 CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=n
    # ?!? remarked 10-01-2023 CONFIG_BT_USER_DATA_LEN_UPDATE=y
    # Below from the smp srv example
    # ?!? remarked 10-01-2023 CONFIG_BT_L2CAP_TX_MTU=498
    # ?!? remarked 10-01-2023 CONFIG_BT_BUF_ACL_RX_SIZE=502
    # ?!? remarked 10-01-2023 CONFIG_BT_BUF_ACL_TX_SIZE=502
    # ?!? remarked 10-01-2023 CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
    # ?!? remarked 10-01-2023 CONFIG_MCUMGR_SMP_BT_CONN_PARAM_CONTROL=y
    # ?!? no need for shell CONFIG_MCUMGR_SMP_SHELL=y
    # ?!? remarked 10-01-2023 CONFIG_MCUMGR_SMP_REASSEMBLY_BT=y
    # ?!? remarked 10-01-2023 CONFIG_MCUMGR_BUF_SIZE=2475
    # ?!? remarked 10-01-2023 CONFIG_OS_MGMT_MCUMGR_PARAMS=y
    # ?!? remarked 10-01-2023 CONFIG_FILE_SYSTEM=y
    # ?!? remarked 10-01-2023 CONFIG_FILE_SYSTEM_LITTLEFS=y
    # ?!? CONFIG_MCUMGR_CMD_FS_MGMT=y
    # ?!? remarked 10-01-2023 CONFIG_MCUMGR_GRP_ZEPHYR_BASIC=y
    # ?!? remarked 10-01-2023 CONFIG_MCUMGR_GRP_BASIC_CMD_STORAGE_ERASE=y
    I can use the nRFConnect app to DFU the image without problem.
    The CONFIG_REBOOT=y did not help my SMP reset problem as far as I can see.
    I need code that works as the app, though I do not know what it is doing exactly when it displays its different status messages.
    I maybe could covert the central and the sensor to both run on SDKs and make a serial PC app that would stream the image to the central as requested.
    I then could let Nordic support see the problems.
    I would need both AMI and Nordic management OKs for this.
    I do not know exactly how to advance.
    Both SMP ZCBOR and my manual transfers were not reliable.
    Thanks David
