nrf52840 S140 Central DFU Bluetooth Zephyr 2.0.0 nrf52840 peripheral
We have nrf52840 S140 BLE Central device that currently connects to TI based sensors. I have implemented code that can upgrade those TI sensors' firmware using the TI BLE protocol.
Now we are developing our own BLE peripheral sensors also based on the nrf52840 but now using the newly supported Zephyr 2.0.0. RF connect stuff. I can update the sensors using the Nordic Android program (unauthenticated for now) and now need to implement upgrading BLE DFU using our central device which connects to a cellular gateway.
I do not want to reinvent the wheel, writing existing code, like I had to do with the TI sensors.
Could you point me to code that allows a Central device to update a peripheral device BLE DFU?
If not where can I look to reinvent another wheel?
Thanks David
  • Hi David,
    Thanks for testing my suggestion.
    To get more insight into the issue, I think that I need to set up Simons sample on my end.
    I will do so and return with my status tomorrow.
    DavidKaplan said:
    I maybe could covert the central and the sensor to both run on SDKs and make a serial PC app that would stream the image to the central as requested.
    I then could let Nordic support see the problems.
    I would need both AMI and Nordic management OKs for this.
    I do not know exactly how to advance.
    I do not understand what you mean by this, could you explain a bit more?
    Sigurd Hellesvik
  • I could comment out any hardware specific code on our central and Sensor.
    In order to simulate correctly image transfer which is done by the serial connection from our Central host, I could build a simple PC program that streams any specified image as the central requests it.
    Simon's test code used the central's flash as storage for the sensor's image.
    I stream it from our host's flash as needed.
    David
    Both SMP ZCBOR and my manual transfers were not reliable.
    Thanks David
    I think you are moving a bit too fast for me to follow.
    1. Do you currently try to use Simons sample SMP Client without changes?
      1. Yes
      2. No
    2. Have Simons sample SMP Client ever worked for you?
      1. Yes
      2. No
    3. Are your current solution of the SMP Client doing a or b?
      1. Storing new image to flash
      2. Streaming data directly
    4. Is your end goal to do either a, b or c
      1. Store new image in flash of SMP Client before sending it to the SMP Server
      2. Stream image via SMP Client to the SMP Server
      3. Does not matter as long as SMP from client works.
    In addition to this, if you are able: Can you draw a simple block diagram of your DFU design so that I can understand better?
    Sigurd Hellesik
  • I tried to answer as well as I can. I could not find my ruler but his is my block diagram:
    I could run my sensor code on SDKs with the special hardware additions commented out.
    I could run our Central code on any SDK since there are no hardware additions.
    Any PC could be used as the host as I could write a program that streamed the image file to the Central when requested.
    1) Do you currently try to use Simons sample SMP Client without changes?
     NO, I can't store sensor images in the Central's internal flash using any local serial interface since the units are in the field and only have modem access and in any case, images must be streamed from the board's host micro-controller which has cellular modem access to the Central. The Host is responsible for updating both the Central and sensors by way of the Central.
     There are very few changes in the Simon's code such as using error numbers instead of local printouts in his callback functions and not waiting for the image upload semaphore forever. In the
    smp_list_rsp_proc(0 function, I had to increase two array sizes, but I could also just not parse anything but the 2 slot's hash values.
    2) Have Simons sample SMP Client ever worked for you?
     No. Mostly the upload smp_upload_rsp_proc() would return all OK, but then there would be no response from the sensor to the first packet sent by bt_dfu_smp_command() which returns zero. I have compared roughly that the first packet's streamed bytes are identical as the file image bytes.
    3) Are your current solution of the SMP Client doing a or b?
      a) Storing new image to flash - No
      b) Streaming data directly - Yes
    4) Is your end goal to do either a, b or c
      a) Store new image in flash of SMP Client before sending it to the SMP Server
          I could stream the image from the host to the SMP Client's internal flash, but I thought it would just add another step and flash wear as updates can be quite frequent. It does have an advantage that I would not have to stream the image from the host multiple times when I DFU each sensor but this only adds a little more time. Time vs flash wear. The Central must also be able to be updated by the serial interface from the host. I do not use SMP for this and it seems to work OK.
      b) Stream image via SMP Client to the SMP Server
         This is the way I went. I keep a ring buffer filled and instead of reading from the flash, flash_read(), I read from the ring buffer. I could even retry if I kept the last data read from the ring buffer is a local array.
      c) Does not matter as long as SMP from client works.
        I just want sensor DFU to work, you are correct.
    I set in the child_image/mcuboot.conf the boot move define.
    ### ?!? 18-Dec-2022 Without this swap is used which limits upgrades 10000 / (150 / 4) ~ 267
    CONFIG_BOOT_SWAP_USING_MOVE=y
    Below is my Central SMP code which you can see is very similar to Simon's original code.
    I am some dyslectic so I could messed up a line.
    d_printf is my function that prints with code file name and line number.
    The AMI_SMP_PRINT defined is not set and I let the messages in the callbacks for reference purposes.
    #ifdef AMI_SMP_PRINT
              d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Unexpected operation code (%u)!",smp_rsp_buff.header.op);
    /* main.c - Application main entry point */
     * Copyright (c) 2019 Nordic Semiconductor ASA
    #include <zephyr/types.h>
    #include <stddef.h>
    #include <errno.h>
    #include <zephyr/kernel.h>
    #include <zcbor_encode.h>
    #include <zcbor_decode.h>
    #include <zcbor_common.h>
    #include <zephyr/bluetooth/hci.h>
    #include <zephyr/bluetooth/conn.h>
    #include <zephyr/bluetooth/uuid.h>
    #include <zephyr/bluetooth/gatt.h>
    #include <bluetooth/gatt_dm.h>
    #include <zephyr/sys/byteorder.h>
    #include <bluetooth/scan.h>
    #include <bluetooth/services/dfu_smp.h>
    #include <dk_buttons_and_leds.h>
    #include <zephyr/sys/ring_buffer.h>
    #include <zephyr/device.h>
    #include <drivers/flash.h>
    #include "aqua_def.h"
    #include "d_printf.h"
    #include "ami_uart_host.h"
    #include "ami_smp.h"
    #include "ami_ble.h"
    #include "ami_timer.h"
    #include "ami_watchdog.h"
    static struct bt_dfu_smp dfu_smp;
    static struct k_work dfu_work_item;
    K_SEM_DEFINE(upload_sem, 1, 1);
    /* Buffer for response */
    struct smp_buffer {
    	struct bt_dfu_smp_header header;
    	uint8_t payload[512]; //300
    #ifdef AMI_OAD_TRANSFER
    #else
    static struct smp_buffer smp_rsp_buff;
    static char hash_value_secondary_slot[33];
    static char hash_value_primary_slot[33];
    static uint8_t which_work;
    static void dfu_smp_on_error(struct bt_dfu_smp *dfu_smp, int err)
    	d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"DFU SMP generic error: %d", err);
    } // dfu_smp_on_error
    static const struct bt_dfu_smp_init_params init_params = {
    	.error_cb = dfu_smp_on_error
    static void smp_reset_rsp_proc(struct bt_dfu_smp *dfu_smp)
    	atomic_set(&smp_finished,true);
    	d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"RESET RESPONSE CB. Doing nothing");
    } // smp_reset_rsp_proc
    static void smp_upload_rsp_proc(struct bt_dfu_smp *dfu_smp)
    	uint8_t *p_outdata = (uint8_t *)(&smp_rsp_buff);
    	const struct bt_dfu_smp_rsp_state *rsp_state;
    	rsp_state = bt_dfu_smp_rsp_state(dfu_smp);
    	if (rsp_state->offset + rsp_state->chunk_size > sizeof(smp_rsp_buff)) {
    	  d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Response size buffer overflow");
    	}else{
    		  p_outdata += rsp_state->offset;
    		  memcpy(p_outdata,rsp_state->data,rsp_state->chunk_size);
    	if (bt_dfu_smp_rsp_total_check(dfu_smp)) {
    		if (smp_rsp_buff.header.op != 3 /* WRITE RSP*/) {
     		  ami_state->DFUErr = AMI_SMP_DFU_ERR_UPLOAD+1;
    		  return;
    		uint16_t group = ((uint16_t)smp_rsp_buff.header.group_h8) << 8 |
    		       		                smp_rsp_buff.header.group_l8;
    		if (group != 1 /* Application/software image management group */) {
    		  d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Unexpected command group (%u)!", group);
     		  ami_state->DFUErr = AMI_SMP_DFU_ERR_UPLOAD+2;
    		  return;
    		if (smp_rsp_buff.header.id != 1 /* UPLOAD */) {
    		  d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Unexpected command (%u)",smp_rsp_buff.header.id);
     		  ami_state->DFUErr = AMI_SMP_DFU_ERR_UPLOAD+3;
    		  return;
    		size_t payload_len = ((uint16_t)smp_rsp_buff.header.len_h8) << 8 |
     				                        smp_rsp_buff.header.len_l8;
    		zcbor_state_t zsd[CBOR_DECODER_STATE_NUM];
    		struct zcbor_string value = {0};
    		bool ok;
    		zcbor_new_decode_state(zsd, ARRAY_SIZE(zsd), smp_rsp_buff.payload, payload_len, 1);
    		// Stop decoding on the error.
    		zsd->constant_state->stop_on_error = true;
    		ok = zcbor_map_start_decode(zsd);
    		if (!ok) {
    		  d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Decoding error, start_decode (err: %d)", zcbor_pop_error(zsd));
     		  ami_state->DFUErr = AMI_SMP_DFU_ERR_UPLOAD+4;
    		  return;
    		// Decoding rc (status error code)
    		char rc_key[5];
    		ok = zcbor_tstr_decode(zsd, &value);
    		if (!ok) {
    		  d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Decoding error, rc key (err: %d)", zcbor_pop_error(zsd));
     		  ami_state->DFUErr = AMI_SMP_DFU_ERR_UPLOAD+5;
    		  return;
    		}else
    		if (value.len != 2) {
    		  d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Invalid data received (rc key). Length %d is not equal 2", value.len);
     		  ami_state->DFUErr = AMI_SMP_DFU_ERR_UPLOAD+6;
    		  return;
    		}else
    		if (!strncmp(value.value,'rc', 2)){
    		  d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Invalid data received (rc key). String '%.2s' is not equal to 'rc'", value.value);
     		  ami_state->DFUErr = AMI_SMP_DFU_ERR_UPLOAD+7;
    		  return;
    		memcpy(rc_key, value.value, value.len);
    		rc_key[value.len] = '\0';
    		// Decoding rc value
    		int32_t rc_value;
    		ok = zcbor_int32_decode(zsd, &rc_value);
    		if (!ok) {
    		  d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Decoding error, rc value (err: %d)", zcbor_pop_error(zsd));
     		  ami_state->DFUErr = AMI_SMP_DFU_ERR_UPLOAD+8;
    		  return;
    		if (rc_value){
    		  d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Error in image upload response: %d", rc_value);
     		  ami_state->DFUErr = AMI_SMP_DFU_ERR_UPLOAD+9;
    		  return;
    		// Decoding offset key
    		char off_key[5];
    		if (!ok) {
    		  d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Decoding error, offset key (err: %d)", zcbor_pop_error(zsd));
     		  ami_state->DFUErr = AMI_SMP_DFU_ERR_UPLOAD+10;
    		  return;
    		}else
    		if ((value.len!=3)) {
    		  d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Invalid data received (rc key). Length %d is not equal 3", value.len);
     		  ami_state->DFUErr = AMI_SMP_DFU_ERR_UPLOAD+11;
    		  return;
    		memcpy(off_key, value.value, value.len);
    		off_key[value.len] = '\0';
    		// Decoding offset value
    		int32_t off_val;
    		ok = zcbor_int32_decode(zsd, &off_val);
    		if (!ok) {
    		  d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Decoding error, offset value (err: %d)", zcbor_pop_error(zsd));
    		  ami_state->DFUErr = AMI_SMP_DFU_ERR_UPLOAD+12;
    		  return;
    		zcbor_map_end_decode(zsd);
    		if (zcbor_check_error(zsd)) {
    		  //d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"%s: %d", off_key, off_val);
    		  //do nothing
    		}else{
    			  d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Cannot print received image upload CBOR stream (err: %d)",
    				ami_state->DFUErr = AMI_SMP_DFU_ERR_UPLOAD+13;
    		k_sem_give(&upload_sem);
    		return;
    } // smp_upload_rsp_proc
    static void smp_list_rsp_proc(struct bt_dfu_smp *dfu_smp)
    #ifdef AMI_DEBUG_BLE
      struct ami_timer wait_Timer;
      ami_state->bDebugBLE = true;
      // Disconnect before sending reply
      bt_conn_disconnect(dfu_smp->conn,BT_HCI_ERR_REMOTE_USER_TERM_CONN);
      ami_timer_set(&wait_Timer,AMI_TIME_2S);
      // Wait until VibeBT disconnects
      while (atomic_get(&ble_connected) && !ami_timer_expired(&wait_Timer)){
    	k_sleep(K_MSEC(25));
    	}else{
    		if (smp_rsp_buff.header.op != 1 && smp_rsp_buff.header.op != 3 ) {
    			ami_state->DFUErr = AMI_SMP_DFU_ERR_LIST_BAD_OPER;
    			return;
    			ami_state->DFUErr = AMI_SMP_DFU_ERR_LIST_BAD_GROUP;
    			return;
    		if (smp_rsp_buff.header.id != 0 /* STATE */) {
    			ami_state->DFUErr = AMI_SMP_DFU_ERR_LIST_BAD_CMD;
    			return;
    		zcbor_state_t zsd[10];
    		bool ok;
    		zcbor_new_decode_state(zsd, ARRAY_SIZE(zsd), smp_rsp_buff.payload, payload_len, 5);
    		/* Stop decoding on the error. */
    		if (!ok) {
    			d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Decoding error 1, start_decode (err: %d)", zcbor_pop_error(zsd));
    			ami_state->DFUErr = AMI_SMP_DFU_ERR_LIST_START_DECODE;
    			return;
    		//Decoding images key
    		char images_key[10];
    		if (!ok) {
    			d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Decoding error 2, images key (err: %d)", zcbor_pop_error(zsd));
    			ami_state->DFUErr = AMI_SMP_DFU_ERR_LIST_IMAGE_DECODE;
    			return;
    		memcpy(images_key, value.value, value.len);
    		images_key[value.len] = '\0';
    		//d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Images key: %s",images_key);
    		ok = zcbor_list_start_decode(zsd);
    		if (!ok) {
    			d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Decoding error, start_decode images->list  (err: %d)", zcbor_pop_error(zsd));
    			ami_state->DFUErr = AMI_SMP_DFU_ERR_LIST_IMAGE_LIST;
    			return;
    		for(int slot=0; slot<2;slot++){
    			if (!ok) {
    				if(slot == 0){
    					d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Error decoding slot 0. Err: %d", zcbor_pop_error(zsd));
    				}else if(slot == 1){
    					d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"No secondary image present");
    					// No secondary image exists!
    					memset(hash_value_secondary_slot,0, sizeof(hash_value_secondary_slot));
    			if(slot==0){
    				d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"-----------PRIMARY IMAGE-----------");
    				d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"-----------SECONDARY IMAGE-----------");
    			//Decoding slot key
    			char slot_key[5];
    			if (!ok) {
    				d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Decoding error, slot key (err: %d)", zcbor_pop_error(zsd));
    				ami_state->DFUErr = AMI_SMP_DFU_ERR_LIST_SLOT_KEY;
       			    return;
    			memcpy(slot_key, value.value, value.len);
    			slot_key[value.len] = '\0';
    			//d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Slot key: %s",slot_key);
    			//Decoding slot value
    			int32_t slot_value;
    			ok = zcbor_int32_decode(zsd, &slot_value);
    			if (!ok) {
    				d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Decoding error, slot value (err: %d)", zcbor_pop_error(zsd));
    				ami_state->DFUErr = AMI_SMP_DFU_ERR_LIST_SLOT_VAL;
            		return;
    			d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"      %s: %d",slot_key,slot_value);
    			//Decoding version key
    			char version_key[16]; // ?!? len =7
    			if (!ok) {
    				d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Decoding error, version key (err: %d)", zcbor_pop_error(zsd));
    				ami_state->DFUErr = AMI_SMP_DFU_ERR_LIST_DECODE_VER;
         			return;
    			memcpy(version_key, value.value, value.len);
    			version_key[value.len] = '\0';
    			//d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"version key: %s",version_key);
    			//decoding version value
    			char version_value[16]; // ?!? len=5 was [5]
    			if (!ok) {
    				d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Decoding error, version value (err: %d)", zcbor_pop_error(zsd));
    				ami_state->DFUErr = AMI_SMP_DFU_ERR_LIST_VER_VAL;
            		return;
    			memcpy(version_value, value.value, value.len);
    			version_value[value.len] = '\0';
    			d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"      %s: %s",version_key,version_value);
    			//Decoding hash key
    			char hash_key[5];
    			if (!ok) {
    				d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Decoding error, hash key (err: %d)", zcbor_pop_error(zsd));
    				ami_state->DFUErr = AMI_SMP_DFU_ERR_LIST_DECODE_HASH;
        			return;
    			memcpy(hash_key, value.value, value.len);
    			hash_key[value.len] = '\0';
    			//d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"hash key: %s",hash_key);
    			//decoding hash value
    			char hash_value[40];
    			ok = zcbor_bstr_decode(zsd, &value);
    			if (!ok) {
    				d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Decoding error, hash value (err: %d)", zcbor_pop_error(zsd));
    				ami_state->DFUErr = AMI_SMP_DFU_ERR_LIST_HASH_VAL;
        			return;
    			memcpy(hash_value, value.value, value.len);
    			if(slot == 0){
    				memcpy(hash_value_primary_slot, value.value, value.len);
    			else if(slot == 1){
    				memcpy(hash_value_secondary_slot, value.value, value.len);
    			hash_value[value.len] = '\0';
    			d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"      %s: 0x", hash_key);
    			for(int x = 0; x< value.len;x++){
    				d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"%x", hash_value[x]);
    			d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"");
    			//Decoding bootable key
    			char bootable_key[10];
    			if (!ok) {
    				ami_state->DFUErr = AMI_SMP_DFU_ERR_LIST_DECODE_BOOT;
         			return;
    			memcpy(bootable_key, value.value, value.len);
    			bootable_key[value.len] = '\0';
    			//d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"bootable key: %s",bootable_key);
    			//Decoding bootable value
    			bool bootable_value;
    			bootable_value = zcbor_bool_expect(zsd, true);
    			if (!zcbor_check_error(zsd)) {
    				d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Decoding error, bootable value (err: %d)", zcbor_pop_error(zsd));
    				ami_state->DFUErr = AMI_SMP_DFU_ERR_LIST_BOOT_VAL;
        			return;
    			d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"      %s: %s",bootable_key, bootable_value?"true":"false");
    			//Decoding pending key
    			char pending_key[10];
    			if (!ok) {
    				d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Decoding error, pending key (err: %d)", zcbor_pop_error(zsd));
    				ami_state->DFUErr = AMI_SMP_DFU_ERR_LIST_DECODE_PEND;
        			return;
    			memcpy(pending_key, value.value, value.len);
    			pending_key[value.len] = '\0';
    			//d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"pending key: %s",pending_key);
    			//Decoding pending value
    			bool pending_value;
    			pending_value = zcbor_bool_expect(zsd, true);
    				d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Decoding error, pending value (err: %d)", zcbor_pop_error(zsd));
    				ami_state->DFUErr = AMI_SMP_DFU_ERR_LIST_PEND_VAL;
          			return;
    			d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"      %s: %s",pending_key, pending_value?"true":"false");
    			//Decoding confirmed key
    			char confirmed_key[10];
    			if (!ok) {
    				d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Decoding error, confirmed key (err: %d)", zcbor_pop_error(zsd));
    				ami_state->DFUErr = AMI_SMP_DFU_ERR_LIST_DECODE_CONFIRM;
          			return;
    			memcpy(confirmed_key, value.value, value.len);
    			confirmed_key[value.len] = '\0';
    			//d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Confirmed key: %s",confirmed_key);
    			//Decoding confirmed value
    			bool confirmed_value;
    			confirmed_value = zcbor_bool_expect(zsd, true);
    				d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Decoding error, confirmed value (err: %d)", zcbor_pop_error(zsd));
    				ami_state->DFUErr = AMI_SMP_DFU_ERR_LIST_CONFIRM_VAL;
        			return;
    			d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"      %s: %s",confirmed_key, confirmed_value?"true":"false");
    			//Decoding active key
    			char active_key[10];
    			if (!ok) {
    				d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Decoding error, active key (err: %d)", zcbor_pop_error(zsd));
    				ami_state->DFUErr = AMI_SMP_DFU_ERR_LIST_DECODE_ACT;
         			return;
    			memcpy(active_key, value.value, value.len);
    			active_key[value.len] = '\0';
    			//d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Active key: %s",active_key);
    			//Decoding active value
    			bool active_value;
    			active_value = zcbor_bool_expect(zsd, true);
    				d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Decoding error, active value (err: %d)", zcbor_pop_error(zsd));
    				ami_state->DFUErr = AMI_SMP_DFU_ERR_LIST_ACT_VAL;
          			return;
    			d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"      %s: %s",active_key, active_value?"true":"false");
    			//Decoding permanent key
    			char permanent_key[10];
    			if (!ok) {
    				d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Decoding error, permanent key (err: %d)", zcbor_pop_error(zsd));
    				ami_state->DFUErr = AMI_SMP_DFU_ERR_LIST_DECODE_PERM;
          			return;
    			memcpy(permanent_key, value.value, value.len);
    			permanent_key[value.len] = '\0';
    			//d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Permanent key: %s",permanent_key);
    			//Decoding permanent value
    			bool permanent_value;
    			permanent_value = zcbor_bool_expect(zsd, true);
    				ami_state->DFUErr = AMI_SMP_DFU_ERR_LIST_PERM_VAL;
    				d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Decoding error, permanent value (err: %d)", zcbor_pop_error(zsd));
            		return;
    			d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"      %s: %s",permanent_key, permanent_value?"true":"false");
    		zcbor_list_end_decode(zsd);
    } // smp_list_rsp_proc
    static void smp_echo_rsp_proc(struct bt_dfu_smp *dfu_smp)
    	d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Echo response part received, size: %zu.",
    	} else {
    		memcpy(p_outdata,
    		       rsp_state->data,
    		d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Total response received - decoding");
    			goto smp_echo_rsp_proc_end;
    		if (group != 0 /* OS */) {
    		if (smp_rsp_buff.header.id != 0 /* ECHO */) {
    		char map_key[SMP_ECHO_MAP_KEY_MAX_LEN];
    		char map_value[SMP_ECHO_MAP_VALUE_MAX_LEN];
    		bool ok;
    		if (!ok) {
    			d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Decoding error (err: %d)", zcbor_pop_error(zsd));
    		} else if ((value.len != 1) || (*value.value != 'r')) {
    			d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Invalid data received.");
    		} else {
    			/* Do nothing */
    		map_key[0] = value.value[0];
    		/* Add string NULL terminator */
    		map_key[1] = '\0';
    		if (!ok) {
    		} else if (value.len > (sizeof(map_value) - 1)) {
    			d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"To small buffer for received data.");
    		} else {
    			/* Do nothing */
    		memcpy(map_value, value.value, value.len);
    		map_value[value.len] = '\0';
    			/* Print textual representation of the received CBOR map. */
    			d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"{_\"%s\": \"%s\"}", map_key, map_value);
    		} else {
    			d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Cannot print received CBOR stream (err: %d)",
    smp_echo_rsp_proc_end:
    } // smp_echo_rsp_proc
    #define PROGRESS_WIDTH 50
    static void progress_print(size_t downloaded, size_t file_size)
    #ifdef TBD
    	const int percent = (downloaded * 100) / file_size;
    	size_t lpad = (percent * PROGRESS_WIDTH) / 100;
    	size_t rpad = PROGRESS_WIDTH - lpad;
    	d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"\r[ %3d%% ] |", percent);
    	for (size_t i = 0; i < lpad; i++) {
    		d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"=");
    	for (size_t i = 0; i < rpad; i++) {
    		d_printf(LINE_INFO,kDbg_Error|kDbg_Host," ");
    	d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"| (%d/%d bytes)", downloaded, file_size);
    	d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"DFU:%d/%d", downloaded, file_size);
    } // progress_print
    // send_upload2
    //  Description
    //   WorkItem that attempts to transfer a VibeBT OAD image
    //   Performed once for each DFU attempt
    //  Parameters
    //    item
    //  Returns
    #define UPLOAD_CHUNK		400// 50 //This has to be at least 32 bytes, since first it has to send the whole header (which is 32 bytes)
    void send_upload2(void)
    	    zcbor_state_t zse[2];
      	    size_t        payload_len;
    	    uint8_t       data[UPLOAD_CHUNK+1]; // One more byte, to store '/0'
    		int           start_addr   = 0;
    		int           curr_addr    = 0;
    		int           upload_chunk = UPLOAD_CHUNK;
    		int           last_addr;
    		int           err;
    	    bool          update_complete = false;
            uint8_t       wait_timeouts = 0;
    		ami_state->DFUErr = AMI_SMP_DFU_ERR_OK;
    		while (!update_complete){
    			struct smp_buffer smp_cmd;
    			zcbor_new_encode_state(zse, ARRAY_SIZE(zse), smp_cmd.payload,sizeof(smp_cmd.payload), 0);
    			// Wait until response is received until sending the next chunk
    			err = k_sem_take(&upload_sem, K_MSEC(AMI_DFU_MAX_TOTAL_MS/10));
    			last_addr    = ami_state->dfu.ImageSize.ulong;
    			if (ami_state->DFUErr){
    			  d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"SMPErr:%u",ami_state->DFUErr);
    			  update_complete = true;
    			// Disconnected?
    			if (!atomic_get(&ble_connected)){
    			  ami_state->DFUErr = AMI_DFU_ERR_DISCONNECTED;
    			// No Error but semiphore times out!
    			if (err){
    			  wait_timeouts++;
    			  if (wait_timeouts<10){
    //				goto upload_retry;
    			    continue;
    			  ami_state->DFUErr = AMI_SMP_DFU_ERR_LOOP_TIMEOUT;
    //            uint16_t mtu = bt_gatt_get_mtu(dfu_smp.conn);
    // ?!?			(zse->payload - smp_cmd.payload);
                wait_timeouts = 0;
    			if ((curr_addr+UPLOAD_CHUNK) > last_addr){
    				upload_chunk = last_addr - curr_addr;
    			// Try to get block from ringbuffer
    			uint16_t bytes_rd = 0;
    			uint16_t pos      = 0;
    			uint8_t  secs     = 0;
    			do{
    			   uint16_t len = ring_buf_get(&dfu_ring_buf,&data[pos],upload_chunk-bytes_rd);
    			   // Wait for ringbuffer to refill
    			   if (len<=0){
    				 // Cause a chain reaction to fill the image buffer
    				 if (ami_state->dfu.ImageRingWrOffset.ulong<ami_state->dfu.ImageSize.ulong){
    					uint32_t free_space = ring_buf_space_get(&dfu_ring_buf);
    					if (free_space>=(VIBEBT_DFU_BLOCK_SIZE*3)){
    					// Request to send another Image block to fill up our buffer
    					ami_state->rqt_alert_bitmap  |= AMI_NORDIC_ALERT_VIBEBT_GET_IMAGE_BLOCK_MASK;
    					atomic_or(&host_msg_action,AMI_HOST_COM_ACT_SEND_MSG_MASK);
    					// Raise semiphore to trigger message handling
    					k_sem_give(&host_com_sem);
    				 k_sleep(K_MSEC(1000));
    				 secs++;
    				 if (secs>60){
    			   }else{
                         pos      += len;
                         bytes_rd += len;
    			}while(bytes_rd<upload_chunk);
    			// RingUnderrun?
    			if (bytes_rd<upload_chunk){
    			  d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"RingUnderrun");
    			  ami_state->DFUErr = AMI_SMP_DFU_ERR_RING_UNDERRUN;
    // upload_retry:
    			progress_print(curr_addr-start_addr, last_addr-start_addr);
    			data[upload_chunk] = '\0';
    			zse->constant_state->stop_on_error = true;
    			zcbor_map_start_encode(zse, 20);
    			zcbor_tstr_put_lit(zse, "image");
    			zcbor_int64_put(zse, 0);
    			zcbor_tstr_put_lit(zse, "data");
    			zcbor_bstr_put_lit(zse, data);
    			zcbor_tstr_put_lit(zse, "len");
    			zcbor_uint64_put(zse, (uint64_t)ami_state->dfu.ImageSize.ulong);
    			zcbor_tstr_put_lit(zse, "off");
    			zcbor_uint64_put(zse, curr_addr - start_addr);
    			zcbor_tstr_put_lit(zse, "sha");
    			zcbor_bstr_put_lit(zse, "12345");
    			zcbor_tstr_put_lit(zse, "upgrade");
    			zcbor_bool_put(zse, false);
    			zcbor_map_end_encode(zse, 20);
    			// ZCBOR error?
    			if (!zcbor_check_error(zse)) {
    			  d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Failed to encode SMP test packet, err: %d", zcbor_pop_error(zse));
    			  ami_state->DFUErr = AMI_SMP_DFU_ERR_UPLOAD_ENCODE;
    			curr_addr+=upload_chunk;
    			payload_len = (size_t)(zse->payload - smp_cmd.payload);
    			smp_cmd.header.op = 2; /* write request */
    			smp_cmd.header.flags = 0;
    			smp_cmd.header.len_h8 = (uint8_t)((payload_len >> 8) & 0xFF);
    			smp_cmd.header.len_l8 = (uint8_t)((payload_len >> 0) & 0xFF);
    			smp_cmd.header.group_h8 = 0;
    			smp_cmd.header.group_l8 = 1; /* IMAGE */
    			smp_cmd.header.seq = 0;
    			smp_cmd.header.id  = 1; /* UPLOAD */
    			// ZCBOR error?
    			err = bt_dfu_smp_command(&dfu_smp,smp_upload_rsp_proc,sizeof(smp_cmd.header)+payload_len,&smp_cmd); // ?!?
    			if (err){
    			  d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"bt_dfu_smp_command failed with %d", err);
    			  ami_state->DFUErr = AMI_SMP_DFU_ERR_SEND;
    		} // while
    		if (!ami_state->DFUErr){
    		  d_printf(LINE_INFO,kDbg_General|kDbg_Host,"SMP UploadOK");
    } // send_upload2
    static int send_smp_list(struct bt_dfu_smp *dfu_smp)
    	static struct smp_buffer smp_cmd;
    //	zcbor_state_t zse[CBOR_ENCODER_STATE_NUM];
    //	size_t payload_len;
    //	payload_len = (size_t)(zse->payload);
    	smp_cmd.header.op = 0; /* read request */
    	smp_cmd.header.len_h8 = 0;
    	smp_cmd.header.len_l8 = 0;
    	smp_cmd.header.id  = 0; /* LIST */
    	return bt_dfu_smp_command(dfu_smp, smp_list_rsp_proc,
    				  sizeof(smp_cmd.header),
    				  &smp_cmd);
    } // send_smp_list
    static int send_smp_reset(struct bt_dfu_smp *dfu_smp,const char *string)
    	size_t payload_len;
    	/* Stop encoding on the error. */
    	zcbor_map_start_encode(zse, CBOR_MAP_MAX_ELEMENT_CNT);
    	zcbor_tstr_put_lit(zse, "d");
    	zcbor_tstr_put_term(zse, string);
    	zcbor_map_end_encode(zse, CBOR_MAP_MAX_ELEMENT_CNT);
    		d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Failed to encode SMP reset packet, err: %d", zcbor_pop_error(zse));
    		return -EFAULT;
    	smp_cmd.header.op = 2; /* Write */
    	smp_cmd.header.group_l8 = 0; /* OS */
    	smp_cmd.header.id  = 5; /* RESET */
    	return bt_dfu_smp_command(dfu_smp, smp_reset_rsp_proc,
    				  sizeof(smp_cmd.header) + payload_len,
    				  &smp_cmd);
    } // send_smp_reset
    static int send_smp_confirm(struct bt_dfu_smp *dfu_smp)
    	size_t payload_len;
    	zcbor_tstr_put_lit(zse, "hash");
    	zcbor_bstr_put_lit(zse, hash_value_secondary_slot);
    	zcbor_tstr_put_lit(zse, "confirm");
    	zcbor_bool_put(zse, true);
    	  d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Failed to encode SMP confirm packet, err: %d", zcbor_pop_error(zse));
    	  ami_state->DFUErr = AMI_SMP_DFU_ERR_CONFIRM_ENCODE;
    	  return -EFAULT;
    	smp_cmd.header.group_l8 = 1; /* app/image */
    	smp_cmd.header.id  = 0; /* ECHO */
    	// confirm has same response as list command
    				  &smp_cmd);
    } // send_smp_confirm
    static int send_smp_test(struct bt_dfu_smp *dfu_smp)
    	size_t payload_len;
    	  ami_state->DFUErr = AMI_SMP_DFU_ERR_TEST_ENCODE;
    	  return -EFAULT;
    				  &smp_cmd);
    } // send_smp_test
    static int send_smp_echo(struct bt_dfu_smp *dfu_smp,
    			 const char *string)
    	size_t payload_len;
    		d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Failed to encode SMP echo packet, err: %d", zcbor_pop_error(zse));
    		return -EFAULT;
    	return bt_dfu_smp_command(dfu_smp, smp_echo_rsp_proc,
    				  &smp_cmd);
    } // send_smp_echo
    int ami_smp_confirm(void)
    	int ret;
    	ret = send_smp_confirm(&dfu_smp);
    	if (ret) {
    		d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Confirm command send error (err: %d)", ret);
    	return ret;
    } // ami_smp_confirm
    int ami_smp_echo(void)
    	static unsigned int echo_cnt;
    	char buffer[32];
    	int ret;
    	++echo_cnt;
    	d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Echo test: %d", echo_cnt);
    	snprintk(buffer, sizeof(buffer), "Echo message: %u", echo_cnt);
    	ret = send_smp_echo(&dfu_smp, buffer);
    	if (ret) {
    		d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Echo command send error (err: %d)", ret);
    	return ret;
    } // ami_smp_echo
    int ami_smp_reset(void)
    	int ret;
    	ret = send_smp_reset(&dfu_smp,"RESET");
    	if (ret) {
    		d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Reset command send error (err: %d)", ret);
    	return ret;
    } // ami_smp_reset
    void submit_work(struct k_work *item)
       int ret = 0;
       switch (which_work){
         case AMI_SMP_WORK_UPLOAD:
    	      send_upload2();
         case AMI_SMP_WORK_LIST:
    		  ret = send_smp_list(&dfu_smp);
    		  if (ret) {
    		    d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Image list command send error (err: %d)", ret);
                ami_state->DFUErr = AMI_SMP_DFU_ERR_LIST_SEND;
         case AMI_SMP_WORK_TEST:
    	      ret = send_smp_test(&dfu_smp);
    	      if (ret) {
    		    d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Test command send error (err: %d)", ret);
                ami_state->DFUErr = AMI_SMP_DFU_ERR_TEST_SEND;
         case AMI_SMP_WORK_RESET:
    		 ret = ami_smp_reset();
         case AMI_SMP_WORK_CONFIRM:
    		 ret = ami_smp_confirm();
       } // switch
    } // submit_work
    int ami_smp_submit_work(uint8_t which)
       which_work = which;
           d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"ImageUpload");
           d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"ImageList");
           d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"ImageTest");
           d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"ImageReset");
           d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"ImageConfirm");
       } // switch
    #if CONFIG_WATCHDOG
       // Kick watchdog
       ami_watchdog_feed();
       k_work_submit(&dfu_work_item);
       return 0;
    } // ami_smp_submit_work
    int  ami_smp_assign_handles(struct bt_gatt_dm *dm)
      // DFU for OTAP support
      bt_dfu_smp_init(&dfu_smp, &init_params);
      // Assign SMP characteristic handles
      int err = bt_dfu_smp_handles_assign(dm, &dfu_smp);
      return err;
    } // ami_smp_assign_handles
    void ami_smp_init(void)
    #else
      k_work_init(&dfu_work_item,submit_work);
    } // ami_smp_init
    Thank you very much.
     David
  • Hi David,
    Sorry for the late answer.
    I am trying to run Simons sample as well, but I am also getting some issues.
    I will continue trying to make this work, and update you on my progress.
    Sigurd Hellesvik
