Write protection pin for External SPI Flash configuration
i am working with nRF5340, nRF Connect SDK 1.9.1 and an external SPI Nor Flash.
The configuration in the device tree is the following:
/* External flash  */
&spi4 {
	label = "spi-ext-flash";
	status = "okay";
	sck-pin = < 17 >;
	mosi-pin = < 13 >;
	miso-pin = < 14 >;
	cs-gpios = < &gpio0 18 GPIO_ACTIVE_LOW >;
	mx66: mx66u1g45g@0 {
		compatible = "jedec,spi-nor";
		label = "MX66";
		reg = <0>;
		spi-max-frequency = <16000000>; /* Max frequency achievable with nRF5340 at 64Mhz */
		size = <1073741824>;	/* Size in bit set to 1 Gb (128 MBytes) */
		wp-gpios = < &gpio0 15 GPIO_ACTIVE_LOW >;
		enter-4byte-addr = <0x85>;
		has-dpd;
		t-enter-dpd = <10000>;
 		t-exit-dpd = <30000>;
		jedec-id = [c2 25 3b];
I do not see any activity on the Write Protection pin when the code is run.
Could you please give me a feedback regarding the configuration of the writep protection and reset pin defined in the device tree file ?
Is any code generated if those pin are declared in the device tree file ?
Thanks in advance for the help !
