active_wait_timeout setting doesn't seem to be taking effect
I'm having some issues regarding the data update interval when running the asset_tracker_v2 application, particularly with adjusting how frequently it publishes data to the nRF Cloud. I have adjusted the KConfig setting such that the default value for DATA_ACTIVE_TIMEOUT_SECONDS is 30 inside the Kconfig.data_module file. However, what the device seems to be doing is sampling data every 30 seconds, but only publishing it to nRF Cloud once every 2 minutes.
I have also tried changing the activeWaitTime setting on the nRF Cloud portal to 30 with a similar lack of effect.
Does anyone have any additional information about this? Thanks!
    do you have logs from this? Can you enable logging in the respective modules?
  • Having enabled logging, the log is attached below:
    Booting (0x8200).
    *** Booting Zephyr OS build v3.0.99-ncs1  ***
    I: Starting bootloader
    I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Boot source: none
    I: Swap type: none
    I: Swap type: none
    I: Bootloader chainload address offset: 0x28000
    I: Jumping to the first image slot
    APPLICATION START!
    [00:00:00.507,690]
    [0m<inf> app_event_manager: APP_EVT_START
    [0m
    [00:00:00.509,002]
    [1;31m<err> settings: set-value failure. key: data_module/config error(40)
    [0m
    [00:00:00.509,216]
    [0m<inf> app_event_manager: DATA_EVT_CONFIG_INIT
    [0m
    [00:00:00.509,735]
    [0m<inf> app_event_manager: APP_EVT_ACTIVITY_DETECTION_DISABLE
    [0m
    [00:00:00.510,467]
    [0m<inf> app_event_manager: MODEM_EVT_INITIALIZED
    [0m
    [00:00:00.572,570]
    [0m<inf> app_event_manager: MODEM_EVT_LTE_CONNECTING
    [0m
    %CESQ: 54,2,10,1
    +CEREG: 2,"2042","00378F1E",7
    %CESQ: 49,2,3,0
    +CSCON: 1
    [00:00:03.913,085]
    [0m<inf> app_event_manager: MODEM_EVT_LTE_DISCONNECTED
    [0m
    [00:00:03.913,696]
    [0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE
    [0m
    %CESQ: 50,2,8,1
    %XTIME: ,"22701241737440","01"
    %MDMEV: SEARCH STATUS 2
    +CEREG: 5,"2042","00378F1E",7,,,"11100000","11100000"
    AT+COPS=3,2
    OK
    AT+COPS?
    +COPS: 0,2,"23415",7
    OK
    AT%XCBAND
    %XCBAND: 20
    OK
    AT+CGDCONT?
    [00:00:09.490,051]
    [0m<inf> app_event_manager: DATA_EVT_DATE_TIME_OBTAINED
    [0m
    [00:+CGDCONT: 0,"IP","wlapn.com","10.111.7.191",0,0
    OK
    00:10.320,037]
    [0m<inf> app_event_manager: MODEM_EVT_LTE_CONNECTED
    [0m
    [00:00:10.320,678]
    [0m<inf> app_event_manager: MODEM_EVT_LTE_PSM_UPDATE
    [0m
    AT+CGACT?
    [00:00:10.322,082]
    [1;33m<wrn> cloud_module: Cloud connection establishment in progress
    [0m
    [00:00:10.322,082]
    [1;33m<wrn> cloud_module: New connection attempt in 32 seconds if not successful
    [0m
    [00:00:10.322,265]
    [0m<inf> app_event_manager: CLOUD_EVT_CONNECTING
    [0m
    +CGACT: 0,1
    OK
    %CESQ: 49,2,3,0
    [00:00:16.199,981]
    [0m<inf> app_event_manager: CLOUD_EVT_CONFIG_RECEIVED
    [0m
    [00:00:16.207,397]
    [0m<inf> app_event_manager: DATA_EVT_CONFIG_SEND
    [0m
    [00:00:16.208,129]
    [0m<inf> app_event_manager: CLOUD_EVT_DATA_SEND_QOS
    [0m
    [00:00:17.396,423]
    [0m<inf> app_event_manager: CLOUD_EVT_CONNECTED
    [0m
    [00:00:17.397,613]
    [0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, NEIGHBOR_CELLS, MOD_STAT)
    [0m
    [00:00:17.399,139]
    [0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_DATA_READY
    [0m
    [00:00:17.402,984]
    [0m<dbg> modem_info: parse_ip_addresses: Device has 1 IP addresses
    [0m
    [00:00:17.403,259]
    [0m<dbg> modem_info: parse_ip_addresses: IP address found: 10.111.7.191
    [0m
    [00:00:17.404,205]
    [0m
    [00:00:17.404,479]
    [0m
    [00:00:17.506,072]
    [0m<inf> app_event_manager: MODEM_EVT_MODEM_STATIC_DATA_READY
    [0m
    [00:00:17.508,911]
    [0m
    [00:00:17.509,185]
    [0m
    [00:00:17.557,708]
    [0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_READY
    [0m
    %NCELLMEAS: 0,"00378F1E","23415","2042",63,6300,104,57,16,17226,6300,103,52,6,0,17019
    [00:00:17.651,947]
    [0m
    [00:00:17.652,221]
    [0m
    [00:00:17.700,378]
    [0m<inf> app_event_manager: MODEM_EVT_BATTERY_DATA_READY
    [0m
    [00:00:17.710,876]
    [0m<inf> app_event_manager: MODEM_EVT_NEIGHBOR_CELLS_DATA_READY
    [0m
    [00:00:17.711,700]
    [0m<inf> app_event_manager: DATA_EVT_DATA_READY
    [0m
    [00:00:17.716,003]
    [0m<inf> app_event_manager: DATA_EVT_NEIGHBOR_CELLS_DATA_SEND
    [0m
    [00:00:17.736,175]
    [0m<inf> app_event_manager: DATA_EVT_DATA_SEND_BATCH
    [0m
    [00:00:17.736,938]
    [0m
    [00:00:17.737,213]
    [0m
    %CESQ: 49,2,8,1
    %NCELLMEAS: 0,"00378F1E","23415","2042",64,6300,104,57,19,30273,6300,103,53,11,0,25557
    [00:00:30.509,796]
    [0m<inf> app_event_manager: APP_EVT_DATA_GET_ALL
    [0m
    [00:00:30.510,559]
    [0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, NEIGHBOR_CELLS, GNSS)
    [0m
    [00:00:30.628,021]
    [0m<inf> app_event_manager: GNSS_EVT_ACTIVE
    [0m
    [00:00:30.629,211]
    [0m
    [00:00:30.643,066]
    [0m
    [00:00:30.643,341]
    [0m
    [00:00:30.695,190]
    [0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY
    [0m
    [00:00:30.697,814]
    [0m
    [00:00:30.698,089]
    [0m
    [00:00:30.744,781]
    [0m
    [00:00:30.755,493]
    [0m
    +CSCON: 0
    %CESQ: 52,2,3,0
    %CESQ: 54,2,14,2
    %CESQ: 54,2,9,1
    %CESQ: 54,2,4,0
    %CESQ: 55,2,9,1
    [00:01:00.509,826]
    [0m
    [00:01:00.510,498]
    [0m
    [00:01:00.510,559]
    [1;33m<wrn> gnss_module: GNSS search already active and will not be restarted
    [0m
    [00:01:00.510,559]
    [1;33m<wrn> gnss_module: Try setting a sample/publication interval greater
    [0m
    [00:01:00.510,589]
    [1;33m<wrn> gnss_module: than the GNSS search timeout.
    [0m
    [00:01:00.511,383]
    [0m
    [00:01:00.513,610]
    [0m
    [00:01:00.513,885]
    [0m
    [00:01:00.560,791]
    [0m
    [00:01:00.563,568]
    [0m
    [00:01:00.563,842]
    [0m
    %NCELLMEAS: 0,"00378F1E","23415","2042",65,6300,104,54,5,59808,35797
    [00:01:00.703,857]
    [0m
    [00:01:00.714,813]
    [0m
    %CESQ: 53,2,3,0
    %CESQ: 53,2,8,1
    [00:01:30.509,857]
    [0m
    [00:01:30.510,528]
    [0m
    [00:01:30.510,589]
    [0m
    [00:01:30.510,589]
    [0m
    [00:01:30.510,620]
    [0m
    [00:01:30.511,474]
    [0m
    [00:01:30.513,519]
    [0m
    [00:01:30.513,793]
    [0m
    [00:01:30.561,157]
    [0m
    [00:01:30.563,781]
    [0m
    [00:01:30.564,056]
    [0m
    %NCELLMEAS: 0,"00378F1E","23415","2042",65,6300,104,53,12,89877,35797
    [00:01:30.703,033]
    [0m
    [00:01:30.713,958]
    [0m
    +CSCON: 1
    [00:01:40.917,541]
    [0m<inf> app_event_manager: GNSS_EVT_TIMEOUT
    [0m
    [00:01:40.918,029]
    [0m<inf> app_event_manager: GNSS_EVT_INACTIVE
    [0m
    [00:01:40.919,097]
    [0m
    [00:01:40.922,302]
    [0m
    [00:01:40.968,536]
    [0m
    [00:01:40.969,329]
    [0m
    [00:01:40.969,604]
    [0m
    %CESQ: 52,2,3,0
    +CSCON: 0
    %NCELLMEAS: 0,"00378F1E","23415","2042",67,6300,104,51,-3,120690,119399
    [00:02:00.509,857]
    [0m
    [00:02:00.510,528]
    [0m
    [00:02:00.527,191]
    [0m
    [00:02:00.528,472]
    [0m
    [00:02:00.536,437]
    [0m
    [00:02:00.536,712]
    [0m
    [00:02:00.601,257]
    [0m
    [00:02:00.603,881]
    [0m
    [00:02:00.604,156]
    [0m
    [00:02:00.668,365]
    [0m
    [00:02:01.140,502]
    [0m
    %CESQ: 53,2,8,1
    %CESQ: 53,2,13,1
    %CESQ: 53,2,8,1
    %CESQ: 53,2,13,1
    [00:02:30.509,887]
    [0m
    [00:02:30.510,559]
    [0m
    [00:02:30.510,620]
    [0m
    [00:02:30.510,620]
    [0m
    [00:02:30.510,650]
    [0m
    [00:02:30.511,444]
    [0m
    [00:02:30.513,671]
    [0m
    [00:02:30.513,946]
    [0m
    [00:02:30.561,126]
    [0m
    [00:02:30.563,934]
    [0m
    [00:02:30.564,208]
    [0m
    %NCELLMEAS: 0,"00378F1E","23415","2042",67,6300,104,54,12,150037,119399
    [00:02:30.703,247]
    [0m
    [00:02:30.715,820]
    [0m
    [00:03:00.509,918]
    [0m
    [00:03:00.510,589]
    [0m
    [00:03:00.510,650]
    [0m
    [00:03:00.510,650]
    [0m
    [00:03:00.510,681]
    [0m
    [00:03:00.511,566]
    [0m
    [00:03:00.513,732]
    [0m
    [00:03:00.514,007]
    [0m
    [00:03:00.563,354]
    [0m
    [00:03:00.566,040]
    [0m
    [00:03:00.566,314]
    [0m
    %NCELLMEAS: 0,"00378F1E","23415","2042",67,6300,104,55,9,180117,119399
    [00:03:00.705,993]
    [0m
    [00:03:00.718,292]
    [0m
    +CSCON: 1
    [00:03:05.346,496]
    [0m
    [00:03:05.346,954]
    [0m
    [00:03:05.348,022]
    [0m
    [00:03:05.351,196]
    [0m
    [00:03:05.397,460]
    [0m
    [00:03:05.398,254]
    [0m
    [00:03:05.398,559]
    [0m
    %CESQ: 51,2,8,1
    %CESQ: 50,2,2,0
    %CESQ: 51,2,7,1
    As you might be able to see, the data isn't being sent each time it's sampled, but instead only sent during certain sampling attempts.
  • In the beginning of the log there is the line
    which I assume means the config is not properly set.
    Did you do this by changing the file directly? All config settings should be changed in the prj.conf file or similar.
  • Could you clarify which setting I should change within the prj.conf file? I've poked around but not seem any configuration to change. In any case, I have restored the original Kconfig file and instead changed the code inside data_module.c to manually change active_wait_timeout to 30 seconds. The behaviour is the same as before, and I have attached the log below.
    I: Swap type: none
    I: Swap type: none
    APPLICATION START!
    [00:00:00.507,629]
    [0m
    [00:00:00.508,758]
    [0m
    [00:00:00.570,739]
    [0m
    [00:00:01.527,038]
    [1;33m<wrn> data_module: Active wait timeout: 30
    [0m
    [00:00:01.527,099]
    [0m
    [00:00:01.527,130]
    [1;33m<wrn> data_module: Movement resolution: 120
    [0m
    [00:00:01.527,130]
    [1;33m<wrn> data_module: Movement timeout: 3600
    [0m
    [00:00:01.527,160]
    [1;33m<wrn> data_module: GPS timeout: 60
    [0m
    [00:00:01.527,160]
    [1;33m<wrn> data_module: Accelerometer threshold: 10.00
    [0m
    [00:00:01.527,252]
    [0m
    [00:00:01.527,770]
    [0m
    %CESQ: 53,2,8,1
    +CEREG: 2,"2042","00378F14",7
    +CSCON: 1
    %CESQ: 59,2,17,2
    [00:00:03.887,023]
    [0m
    [00:00:03.887,634]
    [0m
    %XTIME: ,"22705201954140","01"
    +CEREG: 5,"2042","00378F14",7,,,"11100000","11100000"
    AT+COPS=3,2
    OK
    AT+COPS?
    OK
    AT%XCBAND
    %XCBAND: 20
    OK
    AT+CGDCONT?
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    [00:00:07.934,082]
    [0m
    [00:00:08.381,591]
    [0m
    [00:00:08.382,232]
    [0m
    [00:00:08.383,605]
    [0m
    [00:00:08.383,605]
    [0m
    [00:00:08.383,758]
    [0m
    [00:00:12.073,364]
    [0m
    [00:00:12.080,780]
    [0m
    [00:00:12.081,512]
    [0m
    [00:00:13.018,218]
    [0m
    [00:00:13.019,409]
    [0m
    [00:00:13.020,935]
    [0m
    [00:00:13.024,993]
    [0m
    [00:00:13.025,268]
    [0m
    [00:00:13.026,397]
    [0m
    [00:00:13.026,672]
    [0m
    %NCELLMEAS: 0,"00378F14","23415","2042",80,6300,103,61,23,12800,6300,104,58,17,0,12849
    [00:00:13.200,927]
    [0m
    [00:00:13.203,857]
    [0m
    [00:00:13.204,132]
    [0m
    [00:00:13.253,265]
    [0m
    [00:00:13.256,256]
    [0m
    [00:00:13.256,530]
    [0m
    [00:00:13.305,267]
    [0m
    [00:00:13.315,704]
    [0m
    [00:00:13.316,589]
    [0m
    [00:00:13.320,678]
    [0m
    [00:00:13.323,150]
    [1;31m<err> cloud_codec: Value of button is 0
    [0m
    [00:00:13.323,211]
    [0m
    [00:00:13.323,272]
    [0m
    [00:00:13.341,064]
    [0m
    [00:00:13.341,827]
    [0m
    [00:00:13.342,102]
    [0m
    %NCELLMEAS: 0,"00378F14","23415","2042",80,6300,103,60,21,31032,6300,104,59,19,0,30170
    [00:00:31.527,801]
    [0m
    [00:00:31.528,564]
    [0m
    [00:00:31.579,895]
    [0m
    [00:00:31.581,085]
    [0m
    [00:00:31.594,940]
    [0m
    [00:00:31.595,214]
    [0m
    [00:00:31.664,581]
    [0m
    [00:00:31.667,236]
    [0m
    [00:00:31.667,510]
    [0m
    [00:00:31.737,670]
    [0m
    [00:00:31.747,924]
    [0m
    +CSCON: 0
    %CESQ: 51,2,0,0
    %CESQ: 58,2,17,2
    [00:01:01.527,832]
    [0m
    [00:01:01.528,503]
    [0m
    [00:01:01.528,564]
    [0m
    [00:01:01.528,564]
    [0m
    [00:01:01.528,594]
    [0m
    [00:01:01.529,479]
    [0m
    [00:01:01.531,768]
    [0m
    [00:01:01.532,043]
    [0m
    [00:01:01.581,268]
    [0m
    [00:01:01.583,984]
    [0m
    [00:01:01.584,259]
    [0m
    %NCELLMEAS: 0,"00378F14","23415","2042",73,6300,103,58,16,60971,42330
    [00:01:01.724,243]
    [0m
    [00:01:01.736,358]
    [0m
    %CESQ: 58,2,12,1
    %CESQ: 58,2,17,2
    %CESQ: 57,2,12,1
    [00:01:31.527,893]
    [0m
    [00:01:31.528,564]
    [0m
    [00:01:31.528,625]
    [0m
    [00:01:31.528,625]
    [0m
    [00:01:31.528,656]
    [0m
    [00:01:31.529,571]
    [0m
    [00:01:31.531,707]
    [0m
    [00:01:31.531,982]
    [0m
    [00:01:31.580,139]
    [0m
    [00:01:31.583,190]
    [0m
    [00:01:31.583,465]
    [0m
    %NCELLMEAS: 0,"00378F14","23415","2042",73,6300,103,57,13,91051,42330
    [00:01:31.723,144]
    [0m
    [00:01:31.735,321]
    [0m
    %CESQ: 57,2,17,2
    %CESQ: 57,2,12,1
    +CSCON: 1
    %CESQ: 59,2,18,2
    [00:01:47.138,916]
    [0m
    [00:01:47.139,404]
    [0m
    [00:01:47.140,563]
    [0m
    [00:01:47.143,737]
    [0m
    [00:01:47.148,986]
    [0m
    [00:01:47.149,047]
    [0m
    [00:01:47.149,108]
    [0m
    [00:01:47.189,910]
    [0m
    [00:01:47.190,795]
    [0m
    [00:01:47.191,101]
    [0m
    CONFIG_DATA_ACTIVE_TIMEOUT_SECONDS.
    I'm not sure why setting it directly in the code doesn't work, but you can try setting the config in prj.conf and try again.
