Application can't run after enable MCUBoot and external flash memory.
Hi all
In development with nRF91 and my application need to using an external flash memory to store the firmware and I try to follow the example this link below.
https://devzone.nordicsemi.com/f/nordic-q-a/87722/how-to-use-external-spi-flash-in-fota-with-nrf91-on-ncs1-7-0
https://devzone.nordicsemi.com/f/nordic-q-a/83590/mcuboot-s-secondary-image-on-external-flash-on-nrf9160/347597#347597
But I found when I enable to use external flash memory to store firmware slot 1. The bootloader can't enter to use the firmare in slot 0 on flash memory of nRF91.
I'm not sure. What's happened? Every time, My board has to restart.
*** Booting Zephyr OS build v3.0.99-ncs1  ***
I: Starting bootloader
I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Secondary image: magic=bad, swap_type=0x1, copy_done=0x2, image_ok=0x2
I: Boot source: none
I: Swap type: none
I: Bootloader chainload address offset: 0x20000
*** Booting Zephyr OS build v+----------------------+
I: Starting bootloader       |    Leave Minicom?    |
I: Primary image: magic=unset|     Yes       No     |ne=0x3, image_ok=0x3
I: Secondary image: magic=bad+----------------------+ne=0x2, image_ok=0x2
I: Swap type: none
I: Swap type: none
I: Swap type: none
I: Swap type: none
I: Jumping to the first image slot
Base on:
1. SDK version ncs 2.0
2. HW PCA10090 V.1.0.0
My source code for test.
https://we.tl/t-mHPBn8nALd
Wasan
