Lots of "No such file or directory" errors when "make -j all" command is used
Hi everyone,
I am new to nRF52833, and trying to learn it with some tutorials. I am following this tutorial.
You can download my "examples" file from here. You should put it under "examples" folder.
I am attaching the errors when I execute "make -j all" command under the directory of "...pca10100\s140\armgcc"
Also, I give some details below.
DK: nRF52833-DK
pca number: pca10100
SDK: NRF5_SDK_15.0.0
These are the errors I get:
PS C:\Users\alper\Desktop\nRF5_SDK\nRF5_SDK_15.0.0\nRF5_SDK_15.0.0_a53641a_s140\nRF5_SDK_15.0.0_a53641a\examples\my_projects\nrf52-ble-tutorial-advertising-copy2\pca10100\s140\armgcc> make -j all
Makefile:297: Cannot find source file: ../../../../../../modules/nrfx/mdk/gcc_startup_nrf52833.S
Makefile:297: Cannot find source file: ../../../../../../modules/nrfx/mdk/system_nrf52833.c
Assembling file: gcc_startup_nrf52833.S
Compiling file: nrf_log_backend_rtt.c
Compiling file: nrf_log_backend_serial.c
arm-none-eabi-gcc.exe:Compiling file: nrf_log_backend_uart.c
error: ../../../../../../modules/nrfx/mdk/gcc_startup_nrf52833.S: No such file or directory
arm-none-eabi-gcc.exe: fatal error: no input files
compiarm-none-eabi-gcc.exe:la t oerror: n ../../../../../../components/libraries/experimental_log/src/nrf_log_backend_rtt.c: No such file or directory
tCompiling file: nrf_log_default_backends.cer
minated.
compilation terminated.
arm-none-eabi-gcc.exe: error: ../../../../../../components/libraries/experimental_log/src/nrf_log_backend_serial.c: No such file or directory
arm-none-eabi-gcc.exe:make: *** [../../../../../../components/toolchain/gcc/Makefile.common:280: _build/nrf52833_xxaa/gcc_startup_nrf52833.S.o] Error 1
 fatal error: make: *** Waiting for unfinished jobs....
make: *** [../../../../../../components/toolchain/gcc/Makefile.common:272: _build/nrf52833_xxaa/nrf_log_backend_rtt.c.o] Error 1
no input files
arm-none-eabi-gcc.exe: error: ../../../../../../components/libraries/experimental_log/src/nrf_log_backend_uart.c: No such file or directory
arm-none-eabi-gcc.exe: error: ../../../../../../components/libraries/experimental_log/src/nrf_log_default_backends.c: No such file or directory
make: *** [../../../../../../components/toolchain/gcc/Makefile.common:272: _build/nrf52833_xxaa/nrf_log_backend_serial.c.o] Error 1
make: *** [../../../../../../components/toolchain/gcc/Makefile.common:272: _build/nrf52833_xxaa/nrf_log_backend_uart.c.o] Error 1
make: *** [../../../../../../components/toolchain/gcc/Makefile.common:272: _build/nrf52833_xxaa/nrf_log_default_backends.c.o] Error 1
If you want some other details, I can share with you.
Omer
  • Edit: Also, these are the problems appearing in my "main.c" file:
    	"resource": "/C:/Users/alper/Desktop/nRF5_SDK/nRF5_SDK_15.0.0/nRF5_SDK_15.0.0_a53641a_s140/nRF5_SDK_15.0.0_a53641a/examples/my_projects/nrf52-ble-tutorial-advertising-copy2/main.c",
    	"owner": "C/C++",
    	"code": "1574",
    	"severity": 8,
    	"message": "static assertion failed with \"NRF_SDH_BLE_ENABLED not set!\"",
    	"source": "C/C++",
    	"startLineNumber": 113,
    	"startColumn": 1,
    	"endLineNumber": 113,
    	"endColumn": 17
    	"owner": "C/C++",
    	"code": "1574",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 114,
    	"startColumn": 1,
    	"endLineNumber": 114,
    	"endColumn": 16
    	"owner": "C/C++",
    	"code": "1574",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 115,
    	"startColumn": 1,
    	"endLineNumber": 115,
    	"endColumn": 20
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"message": "variable \"uint8_t\" is not a type name",
    	"source": "C/C++",
    	"startLineNumber": 142,
    	"startColumn": 51,
    	"endLineNumber": 142,
    	"endColumn": 58
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"message": "variable \"uint32_t\" is not a type name",
    	"source": "C/C++",
    	"startLineNumber": 198,
    	"startColumn": 17,
    	"endLineNumber": 198,
    	"endColumn": 32
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 210,
    	"startColumn": 13,
    	"endLineNumber": 210,
    	"endColumn": 28
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 216,
    	"startColumn": 13,
    	"endLineNumber": 216,
    	"endColumn": 28
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 222,
    	"startColumn": 13,
    	"endLineNumber": 222,
    	"endColumn": 28
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 228,
    	"startColumn": 13,
    	"endLineNumber": 228,
    	"endColumn": 28
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 253,
    	"startColumn": 5,
    	"endLineNumber": 253,
    	"endColumn": 20
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 272,
    	"startColumn": 50,
    	"endLineNumber": 272,
    	"endColumn": 57
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 274,
    	"startColumn": 5,
    	"endLineNumber": 274,
    	"endColumn": 20
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 288,
    	"startColumn": 5,
    	"endLineNumber": 288,
    	"endColumn": 20
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 297,
    	"startColumn": 5,
    	"endLineNumber": 297,
    	"endColumn": 20
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 308,
    	"startColumn": 35,
    	"endLineNumber": 308,
    	"endColumn": 43
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 326,
    	"startColumn": 5,
    	"endLineNumber": 326,
    	"endColumn": 20
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 348,
    	"startColumn": 9,
    	"endLineNumber": 348,
    	"endColumn": 24
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 357,
    	"startColumn": 39,
    	"endLineNumber": 357,
    	"endColumn": 47
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 382,
    	"startColumn": 5,
    	"endLineNumber": 382,
    	"endColumn": 20
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 397,
    	"startColumn": 5,
    	"endLineNumber": 397,
    	"endColumn": 20
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 401,
    	"startColumn": 5,
    	"endLineNumber": 401,
    	"endColumn": 20
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 405,
    	"startColumn": 5,
    	"endLineNumber": 405,
    	"endColumn": 20
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 424,
    	"startColumn": 13,
    	"endLineNumber": 424,
    	"endColumn": 28
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 456,
    	"startColumn": 13,
    	"endLineNumber": 456,
    	"endColumn": 28
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 459,
    	"startColumn": 13,
    	"endLineNumber": 459,
    	"endColumn": 28
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 471,
    	"startColumn": 13,
    	"endLineNumber": 471,
    	"endColumn": 28
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 479,
    	"startColumn": 13,
    	"endLineNumber": 479,
    	"endColumn": 28
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 487,
    	"startColumn": 13,
    	"endLineNumber": 487,
    	"endColumn": 28
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 506,
    	"startColumn": 5,
    	"endLineNumber": 506,
    	"endColumn": 20
    	"owner": "C/C++",
    	"code": "65",
    	"severity": 8,
    	"message": "expected a ';'",
    	"source": "C/C++",
    	"startLineNumber": 510,
    	"startColumn": 14,
    	"endLineNumber": 510,
    	"endColumn": 23
    	"owner": "C/C++",
    	"code": "20",
    	"severity": 8,
    	"message": "identifier \"ram_start\" is undefined",
    	"source": "C/C++",
    	"startLineNumber": 511,
    	"startColumn": 67,
    	"endLineNumber": 511,
    	"endColumn": 76
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 512,
    	"startColumn": 5,
    	"endLineNumber": 512,
    	"endColumn": 20
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 516,
    	"startColumn": 5,
    	"endLineNumber": 516,
    	"endColumn": 20
    	"owner": "C/C++",
    	"code": "1574",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 519,
    	"startColumn": 5,
    	"endLineNumber": 519,
    	"endColumn": 25
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 531,
    	"startColumn": 5,
    	"endLineNumber": 531,
    	"endColumn": 20
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 550,
    	"startColumn": 5,
    	"endLineNumber": 550,
    	"endColumn": 20
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 553,
    	"startColumn": 5,
    	"endLineNumber": 553,
    	"endColumn": 20
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 566,
    	"startColumn": 5,
    	"endLineNumber": 566,
    	"endColumn": 20
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 589,
    	"startColumn": 17,
    	"endLineNumber": 589,
    	"endColumn": 32
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 599,
    	"startColumn": 21,
    	"endLineNumber": 599,
    	"endColumn": 36
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 632,
    	"startColumn": 5,
    	"endLineNumber": 632,
    	"endColumn": 20
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 648,
    	"startColumn": 5,
    	"endLineNumber": 648,
    	"endColumn": 20
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 651,
    	"startColumn": 5,
    	"endLineNumber": 651,
    	"endColumn": 20
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 662,
    	"startColumn": 5,
    	"endLineNumber": 662,
    	"endColumn": 20
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 674,
    	"startColumn": 5,
    	"endLineNumber": 674,
    	"endColumn": 20
    	"owner": "C/C++",
    	"code": "757",
    	"severity": 8,
    	"source": "C/C++",
    	"startLineNumber": 704,
    	"startColumn": 9,
    	"endLineNumber": 704,
    	"endColumn": 24
  • Hello Omer,
    nRF5 SDK v15.0.0 is not compatible with nRF52833. Please choose nRF5 SDK v16.0.0 or higher. You can see which versions are compatible on the Infocenter in this compatibility matrix.
    For more information on the nRF5 SDK, take a look at this blogpost from 2020.
    Since you are just getting started, I recommend that you consider using our newer SDK: nRF Connect SDK.
    A recently updated course covering the fundamentals of nRF Connect SDK is available here on DevZone.
    Maria
  • Hello Maria,
    Several hours after posting this question, I realized this incompatibility issue when I don't see the name of my kit in "...modules\nrfx\mdk" and its "pca number" in "readme.txt" of the examples.
    Recently I have been surfing from one SDK to another SDK to run my tutorial. But the thing is I had lots of problems with both. I will try to post those with the new SDK here.
    Edit: Maybe, I should post them by opening a new discussion.
    Thanks for your reply,
    Omer
