HI ,
I'm trying to open terminal/command SDK v2.0.0 from toolchain manager (working with nrf connect for desktop v3.11.1) but it doesn't open.
while on SDK v1.9.1 it works good :
Pls advice
Tnx,
Eran.
HI ,
Pls advice
Tnx,
Eran.
That is odd.
Does the NCS v2 SDK otherwise work alright? Are you able build a sample on VSC using it? Did you install NCS v2 using the automatic installation from the Toolchain Manager?
Elfving
HI Elfing,
Yes , I installed the NCS v2 from the toolchain manager.
I can't build a sample on VSC. This is what I get when trying to change the path from v1.9.1
Tnx,
Eran.
Hi Elfving,
I don't have the toolchain folder in my v2.0.0
Tnx,
Eran.
ERAN GISSER said:I don't have the toolchain folder in my v2.0.0
That is no problem, it is supposed to be like that in NCS 2. The folder is outside the NCS folder, though can you check that it is still there? As you have NCS directly on your C drive maybe its been moved by mistake?
And can you make sure that your VSC extensions are up to date? A similar issue should be addressed in a version from 15/7.
ERAN GISSER said:This is what I get when trying to change the path from v1.9.1
What if you open VSC from NCS 2 in the Toolchain Manager? What happens when you from VSC press ctrl+shift+p, and then "select nRF Connect Toolchain"?
Elfving
Hi Elfving,
Now , I'm able to build samples or application under SDK v2.0.0 with different DK's without any issue.
But still the same issue , can't open both cmd & bash
Tnx,
Eran.
