Trouble installing nrf commandline tools on Debian
I'm trying to install nrf-command-line-tools_10.17.0_amd64.deb on an up to date Debian 11, but dpkg always fails with this error:
# dpkg -i nrf-command-line-tools_10.17.0_amd64.deb
Sélection du paquet nrf-command-line-tools précédemment désélectionné.
(Lecture de la base de données... 326042 fichiers et répertoires déjà installés.)
Préparation du dépaquetage de nrf-command-line-tools_10.17.0_amd64.deb ...
Dépaquetage de nrf-command-line-tools (10.17.0) ...
Paramétrage de nrf-command-line-tools (10.17.0) ...
dpkg: erreur: dpkg frontend lock was locked by another process with pid 6161
Note: removing the lock file is always wrong, and can end up damaging the
locked area and the entire system. See <wiki.debian.org/.../FAQ>.
dpkg: erreur de traitement du paquet nrf-command-line-tools (--install) :
 installed nrf-command-line-tools package post-installation script subprocess returned error exit status 2
Des erreurs ont été rencontrées pendant l'exécution :
I can't see any process 6161. Any help will be greatly appreciated :-)
Vincent
  • Hello Vincent,
    Another forum-user recently also reported this, but we are still looking into the root cause.
    The other forum-user were seemingly able to work around it by editing their postint script, like described in their ticket.
    Hopefully this workaround will work for you as well, while we patch the .deb.
    Karl
  • Thank you for the answer and the link. I'm a bit angry, nobody has verified the package before it's publication! I'm really sorry to say that but the postinst script is crap. There's a unattended fi at line 22, there are rpm commands which is nonsense in a debian package, lines 12 to 21 are repeated at 24 to 33 (??!) and last there's no 'segger' folder under /opt/nrf-command-line-tools/share/ so  the dpkg --install can only fail.
    Coming from ST world, I wanted to give Nordic a try since I have a nRF52840 dev board. Bad start.
    Since I'm a developer I know there can be bugs here or there that can pass verification and tests, but in this case just trying to install the package would have avoid this issue.
    Regards
    Vincent
  • Hello again, Vincent
    I am very sorry to hear that this is the state of the postinst script - I personally have very little debian experience myself, but this does indeed sound pretty grave based on your description.
    I will update my internal ticket to the developers to contain your comment.
    We always wholeheartedly welcome feedback like this, so that we can improve - thank you for the valuable insight!
    I understand how this would constitute a bad start to your Nordic evaluation, but I hope and trust that it all will be better from here once you get into working with the nRF Connect SDK! :)
    Please do not hesitate to open another ticket if you should encounter any other issues or questions in the future!
    Karl
  • I've been able to install the package after manually editing the postinst script (deleted all after the second 'ln -sf' command). I now have issues with VSCode not finding nrfjprog and complaining about a shell initialization failure.
    II've seen in another thread that a 10.17.2 update should be available in a few days. I'll wait.
    Regards.
    Vincent
  • I just want to voice my opinion about this whole dev environment experience as being absolutely atrocious - one of the worst of its kind.  It has made me look bad at work where I suggested we select the nRF chipset for our next generation product, which looked appealing at first but it's just been fighting problem after problem despite following the instructions to the letter to get a basic blinking LED program to just start with.  From simple errors in the documentation such as support of the latest LTS Ubuntu (22 as of now, and as our team generally don't run Windows or Mac), then installing all the bits and pieces manually, and after spending ages finding out that 22 is in fact not supported by one of the required components, then backtracking, reinstalling Ubuntu 20, finding broken deb packages and components, seeing myself and other users experience initialization problems in VS Code... honestly, Nordic has really dropped us all in it this time - just atrocious.  I've programmed in all sorts of MCUs and ARM boards so I'm not new to dev environments.  Our manager is now pressing to abandon the choice of nRF and I might just have to comply because I've got nothing to show for it but a migraine.
