sample code get compiling error on nrf5340
ubuntu 20.3
vscode + nrf connect
when i creat project from sample code unicast_audio_client, i get the following compiling error message:
* Executing task: nRF Connect: Build: unicast_audio_client/build (active)
Building unicast_audio_client
west build --build-dir /home/yanzhongsan/Nordic/projects/unicast_audio_client/build /home/yanzhongsan/Nordic/projects/unicast_audio_client --pristine --board nrf5340_audio_dk_nrf5340_cpuapp -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="/home/yanzhongsan/Nordic/projects/broadcast_audio_source;/home/yanzhongsan/Nordic/projects/peripheral_hr;/home/yanzhongsan/Nordic/projects/broadcast_audio_sink;/home/yanzhongsan/Nordic/projects/unicast_audio_server;/home/yanzhongsan/Nordic/projects/unicast_audio_client" -DCONFIG_DEBUG_OPTIMIZATIONS:STRING="y" -DCONFIG_DEBUG_THREAD_INFO:STRING="y" -DCONF_FILE:STRING="/home/yanzhongsan/Nordic/projects/unicast_audio_client/prj.conf"
-- Application: /home/yanzhongsan/Nordic/projects/unicast_audio_client
-- Found Python3: /usr/bin/python3.8 (found suitable exact version "3.8.10") found components: Interpreter
-- Cache files will be written to: /home/yanzhongsan/.cache/zephyr
-- Zephyr version: 3.1.99 (/home/yanzhongsan/Nordic/ncs-main/zephyr)
-- Found west (found suitable version "0.13.1", minimum required is "0.7.1")
-- Board: nrf5340_audio_dk_nrf5340_cpuapp
-- Found dtc: /usr/bin/dtc (found suitable version "1.5.0", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (/opt/gcc-arm/gcc-arm-none-eabi-10.3-2021.10)
-- Found BOARD.dts: /home/yanzhongsan/Nordic/ncs-main/nrf/boards/arm/nrf5340_audio_dk_nrf5340/nrf5340_audio_dk_nrf5340_cpuapp.dts
-- Generated zephyr.dts: /home/yanzhongsan/Nordic/projects/unicast_audio_client/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: /home/yanzhongsan/Nordic/projects/unicast_audio_client/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: /home/yanzhongsan/Nordic/projects/unicast_audio_client/build/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: /home/yanzhongsan/Nordic/projects/unicast_audio_client/build/zephyr/dts.cmake
Parsing /home/yanzhongsan/Nordic/ncs-main/zephyr/Kconfig
Loaded configuration '/home/yanzhongsan/Nordic/ncs-main/nrf/boards/arm/nrf5340_audio_dk_nrf5340/nrf5340_audio_dk_nrf5340_cpuapp_defconfig'
Merged configuration '/home/yanzhongsan/Nordic/projects/unicast_audio_client/prj.conf'
Merged configuration '/home/yanzhongsan/Nordic/projects/unicast_audio_client/build/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to '/home/yanzhongsan/Nordic/projects/unicast_audio_client/build/zephyr/.config'
Kconfig header saved to '/home/yanzhongsan/Nordic/projects/unicast_audio_client/build/zephyr/include/generated/autoconf.h'
warning: Experimental symbol BT_ISO_CENTRAL is enabled.
warning: Experimental symbol BT_AUDIO is enabled.
warning: Experimental symbol BT_AUDIO_UNICAST_CLIENT is enabled.
-- The C compiler identification is GNU 10.3.1
-- The CXX compiler identification is GNU 10.3.1
-- Found assembler: /opt/gcc-arm/gcc-arm-none-eabi-10.3-2021.10/bin/arm-none-eabi-gcc
=== child image hci_rpmsg - CPUNET begin ===
loading initial cache file /home/yanzhongsan/Nordic/projects/unicast_audio_client/build/hci_rpmsg/child_image_preload.cmake
-- Application: /home/yanzhongsan/Nordic/ncs-main/zephyr/samples/bluetooth/hci_rpmsg
-- Board: nrf5340_audio_dk_nrf5340_cpunet
-- Found BOARD.dts: /home/yanzhongsan/Nordic/ncs-main/nrf/boards/arm/nrf5340_audio_dk_nrf5340/nrf5340_audio_dk_nrf5340_cpunet.dts
-- Generated zephyr.dts: /home/yanzhongsan/Nordic/projects/unicast_audio_client/build/hci_rpmsg/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: /home/yanzhongsan/Nordic/projects/unicast_audio_client/build/hci_rpmsg/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: /home/yanzhongsan/Nordic/projects/unicast_audio_client/build/hci_rpmsg/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: /home/yanzhongsan/Nordic/projects/unicast_audio_client/build/hci_rpmsg/zephyr/dts.cmake
Loaded configuration '/home/yanzhongsan/Nordic/ncs-main/nrf/boards/arm/nrf5340_audio_dk_nrf5340/nrf5340_audio_dk_nrf5340_cpunet_defconfig'
Merged configuration '/home/yanzhongsan/Nordic/ncs-main/zephyr/samples/bluetooth/hci_rpmsg/prj.conf'
Merged configuration '/home/yanzhongsan/Nordic/ncs-main/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Configuration saved to '/home/yanzhongsan/Nordic/projects/unicast_audio_client/build/hci_rpmsg/zephyr/.config'
Kconfig header saved to '/home/yanzhongsan/Nordic/projects/unicast_audio_client/build/hci_rpmsg/zephyr/include/generated/autoconf.h'
-- libmetal version: 1.2.0 (/home/yanzhongsan/Nordic/ncs-main/zephyr/samples/bluetooth/hci_rpmsg)
-- Build type:
-- Host: Linux/x86_64
-- Target: Generic/arm
-- Machine: arm
-- Looking for include file stdatomic.h
-- Looking for include file stdatomic.h - found
-- open-amp version: 1.2.0 (/home/yanzhongsan/Nordic/ncs-main/modules/lib/open-amp/open-amp)
-- Machine: arm
-- C_FLAGS : -Wall -Wextra
-- Looking for include file fcntl.h
-- Looking for include file fcntl.h - found
-- Configuring done
-- Generating done
-- Build files have been written to: /home/yanzhongsan/Nordic/projects/unicast_audio_client/build/hci_rpmsg
=== child image hci_rpmsg - CPUNET end ===
-- libmetal version: 1.2.0 (/home/yanzhongsan/Nordic/projects/unicast_audio_client)
-- Build type:
-- Machine: arm
-- Machine: arm
CMake Warning at /home/yanzhongsan/Nordic/ncs-main/zephyr/CMakeLists.txt:829 (message):
No SOURCES given to Zephyr library: drivers__disk
Excluding target from build.
-- Configuring done
-- Generating done
[1/269] Preparing syscall dependency handling
[2/269] Creating directories for 'hci_rpmsg_subimage'
[3/269] Generating include/generated/version.h
-- Zephyr version: 3.1.99 (/home/yanzhongsan/Nordic/ncs-main/zephyr), build: v3.0.99-ncs1-2464-gd72a2bceca9d
[4/269] No download step for 'hci_rpmsg_subimage'
[5/269] No update step for 'hci_rpmsg_subimage'
[6/269] Generating misc/generated/syscalls_subdirs.trigger
[7/269] No patch step for 'hci_rpmsg_subimage'
[8/269] No configure step for 'hci_rpmsg_subimage'
[8/269] Performing build step for 'hci_rpmsg_subimage'
[1/228] Preparing syscall dependency handling
[2/228] Generating include/generated/version.h
[3/228] Generating misc/generated/syscalls_subdirs.trigger
[4/228] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[5/228] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[6/228] Generating include/generated/driver-validation.h
[7/228] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[8/228] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[9/228] Generating include/generated/offsets.h
[10/228] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[11/228] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
[12/228] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[13/228] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[14/228] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[15/228] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[16/228] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[17/228] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[18/228] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[19/228] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[20/228] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
[21/228] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[22/228] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[23/228] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[24/228] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[25/228] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
[26/228] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[27/228] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[28/228] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[29/228] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[30/228] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
[31/228] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[32/228] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
[33/228] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
[34/228] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
[35/228] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
[36/228] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf53/soc.c.obj
[37/228] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[38/228] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
[39/228] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/ipc/rpmsg_service/rpmsg_backend.c.obj
[40/228] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/ipc/rpmsg_service/rpmsg_service.c.obj
[41/228] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/ipc/ipc_service/backends/ipc_rpmsg_static_vrings.c.obj
[42/228] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/ipc/ipc_service/ipc_service.c.obj
[43/228] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/ipc/ipc_service/lib/ipc_static_vrings.c.obj
[44/228] Building C object zephyr/CMakeFiles/zephyr.dir/home/yanzhongsan/Nordic/ncs-main/modules/crypto/tinycrypt/lib/source/aes_encrypt.c.obj
[45/228] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/utils/addr_utils.c.obj
[46/228] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
[47/228] Building C object zephyr/CMakeFiles/zephyr.dir/home/yanzhongsan/Nordic/ncs-main/modules/crypto/tinycrypt/lib/source/utils.c.obj
[48/228] Building C object zephyr/CMakeFiles/zephyr.dir/home/yanzhongsan/Nordic/ncs-main/modules/crypto/tinycrypt/lib/source/aes_decrypt.c.obj
[49/228] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/ipc/ipc_service/lib/ipc_rpmsg.c.obj
[50/228] Building C object zephyr/CMakeFiles/zephyr.dir/home/yanzhongsan/Nordic/ncs-main/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
[51/228] Generating linker_zephyr_pre1.cmd
[52/228] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[53/228] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
[54/228] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
[55/228] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
[56/228] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
[57/228] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
[58/228] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
[59/228] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
[60/228] Generating linker_zephyr_pre0.cmd
[61/228] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[62/228] Linking C static library zephyr/arch/common/libisr_tables.a
[63/228] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[64/228] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
[65/228] Linking C static library zephyr/libzephyr.a
[66/228] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
[67/228] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
[68/228] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[69/228] Linking C static library zephyr/arch/common/libarch__common.a
[70/228] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
[71/228] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
[72/228] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
[73/228] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[74/228] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
[75/228] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
[76/228] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
[77/228] Linking C static library zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a
[78/228] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
[79/228] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
[80/228] Building C object CMakeFiles/app.dir/src/main.c.obj
[81/228] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
[82/228] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
[83/228] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
[84/228] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
[85/228] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
[86/228] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
[87/228] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj
[88/228] Linking C static library app/libapp.a
[89/228] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj
[90/228] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a
[91/228] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a
[92/228] Linking C static library zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a
[93/228] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
[94/228] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
[95/228] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
[96/228] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
[97/228] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
[98/228] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
[99/228] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
[100/228] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
[101/228] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
[102/228] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
[103/228] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
[104/228] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrtf.c.obj
[105/228] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrt.c.obj
[106/228] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
[107/228] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
[108/228] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
[109/228] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
[110/228] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/dummy.c.obj
[111/228] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/rpa.c.obj
[112/228] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/log.c.obj
[113/228] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_raw.c.obj
[114/228] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_common.c.obj
[115/228] Linking C static library zephyr/lib/libc/minimal/liblib__libc__minimal.a
[116/228] Linking C static library zephyr/lib/posix/liblib__posix.a
[117/228] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/buf.c.obj
[118/228] Linking C static library zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a
[119/228] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
[120/228] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj
[121/228] Linking C static library zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a
[122/228] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
[123/228] Linking C static library zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a
[124/228] Building C object zephyr/drivers/ipm/CMakeFiles/drivers__ipm.dir/ipm_nrfx_ipc.c.obj
[125/228] Linking C static library zephyr/subsys/net/libsubsys__net.a
[126/228] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/entropy_nrf5.c.obj
[127/228] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
[128/228] Linking C static library zephyr/subsys/random/libsubsys__random.a
[129/228] Linking C static library zephyr/drivers/gpio/libdrivers__gpio.a
[130/228] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a
[131/228] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
[132/228] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
[133/228] Linking C static library zephyr/drivers/ipm/libdrivers__ipm.a
[134/228] Linking C static library zephyr/drivers/entropy/libdrivers__entropy.a
[135/228] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
[136/228] Building C object zephyr/drivers/mbox/CMakeFiles/drivers__mbox.dir/mbox_nrfx_ipc.c.obj
[137/228] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
[138/228] Building C object modules/nrf/lib/multithreading_lock/CMakeFiles/..__nrf__lib__multithreading_lock.dir/multithreading_lock.c.obj
[139/228] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/hci_internal.c.obj
[140/228] Linking C static library zephyr/drivers/pinctrl/libdrivers__pinctrl.a
[141/228] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/hci_driver.c.obj
[142/228] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/crypto.c.obj
[143/228] Linking C static library zephyr/drivers/mbox/libdrivers__mbox.a
[144/228] Linking C static library zephyr/drivers/timer/libdrivers__timer.a
[145/228] Linking C static library modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a
[146/228] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/ecdh.c.obj
[147/228] Building C object modules/nrf/subsys/mpsl/init/CMakeFiles/..__nrf__subsys__mpsl__init.dir/mpsl_init.c.obj
[148/228] Linking C static library modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a
[149/228] Building C object modules/nrf/drivers/mpsl/clock_control/CMakeFiles/..__nrf__drivers__mpsl__clock_control.dir/nrfx_clock_mpsl.c.obj
[150/228] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/yanzhongsan/Nordic/ncs-main/modules/hal/nordic/nrfx/mdk/system_nrf5340_network.c.obj
[151/228] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/yanzhongsan/Nordic/ncs-main/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
[152/228] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
[153/228] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/yanzhongsan/Nordic/ncs-main/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
[154/228] Linking C static library modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a
[155/228] Linking C static library modules/nrf/subsys/mpsl/init/lib..__nrf__subsys__mpsl__init.a
[156/228] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/yanzhongsan/Nordic/ncs-main/modules/hal/nordic/nrfx/drivers/src/nrfx_ipc.c.obj
[157/228] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/device.c.obj
[158/228] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/init.c.obj
[159/228] Linking C static library modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a
[160/228] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/dma.c.obj
[161/228] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/io.c.obj
[162/228] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/irq.c.obj
[163/228] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/log.c.obj
[164/228] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/shmem.c.obj
[165/228] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/softirq.c.obj
[166/228] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/version.c.obj
[167/228] Linking C static library modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
[168/228] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/condition.c.obj
[169/228] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/device.c.obj
[170/228] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/alloc.c.obj
[171/228] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/init.c.obj
[172/228] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/irq.c.obj
[173/228] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/log.c.obj
[174/228] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/time.c.obj
[175/228] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/version.c.obj
[176/228] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/virtio/virtio.c.obj
[177/228] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/virtio/virtqueue.c.obj
[178/228] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/rpmsg/rpmsg.c.obj
[179/228] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/rpmsg/rpmsg_virtio.c.obj
[180/228] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/remoteproc/elf_loader.c.obj
[181/228] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/shmem.c.obj
[182/228] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/remoteproc/remoteproc.c.obj
[183/228] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/remoteproc/rsc_table_parser.c.obj
[184/228] Building C object modules/open-amp/open-amp/lib/CMakeFiles/open_amp.dir/remoteproc/remoteproc_virtio.c.obj
[185/228] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/arm/sys.c.obj
[186/228] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
[187/228] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
[188/228] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
[189/228] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
[190/228] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
[191/228] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
[192/228] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
[193/228] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
[194/228] Linking C static library modules/libmetal/libmetal/lib/libmetal.a
[195/228] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
[196/228] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
[197/228] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
[198/228] Linking C static library modules/open-amp/open-amp/lib/libopen_amp.a
[199/228] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
[200/228] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
[201/228] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj
[202/228] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
[203/228] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
[204/228] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
[205/228] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
[206/228] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
[207/228] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
[208/228] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
[209/228] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
[210/228] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
[211/228] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
[212/228] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
[213/228] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
[214/228] Building C object zephyr/kernel/CMakeFiles/kernel.dir/poll.c.obj
[215/228] Linking C static library zephyr/kernel/libkernel.a
[216/228] Linking C executable zephyr/zephyr_pre0.elf
[217/228] Generating dev_handles.c
[218/228] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj
[219/228] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/misc/empty_file.c.obj
[220/228] Linking C executable zephyr/zephyr_pre1.elf
[221/228] Generating linker.cmd
[222/228] Generating isr_tables.c, isrList.bin
FAILED: zephyr/isr_tables.c zephyr/isrList.bin /home/yanzhongsan/Nordic/projects/unicast_audio_client/build/hci_rpmsg/zephyr/isr_tables.c /home/yanzhongsan/Nordic/projects/unicast_audio_client/build/hci_rpmsg/zephyr/isrList.bin
cd /home/yanzhongsan/Nordic/projects/unicast_audio_client/build/hci_rpmsg/zephyr && /opt/gcc-arm/gcc-arm-none-eabi-10.3-2021.10/bin/arm-none-eabi-objcopy --input-target=elf32-littlearm --output-target=binary --only-section=.intList /home/yanzhongsan/Nordic/projects/unicast_audio_client/build/hci_rpmsg/zephyr/zephyr_pre1.elf isrList.bin && /usr/bin/python3.8 /home/yanzhongsan/Nordic/ncs-main/zephyr/arch/common/gen_isr_tables.py --output-source isr_tables.c --kernel /home/yanzhongsan/Nordic/projects/unicast_audio_client/build/hci_rpmsg/zephyr/zephyr_pre1.elf --intlist isrList.bin --sw-isr-table --vector-table
gen_isr_tables.py: error: multiple registrations at table_index 18 for irq 18 (0x12)
Existing handler 0x1028d59, new handler 0x1028d59
Has IRQ_CONNECT or IRQ_DIRECT_CONNECT accidentally been invoked on the same irq multiple times?
[200/269] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/version.c.obj
FAILED: modules/nrf/samples/hci_rpmsg_subimage-prefix/src/hci_rpmsg_subimage-stamp/hci_rpmsg_subimage-build hci_rpmsg/zephyr/zephyr.hex hci_rpmsg/zephyr/zephyr.elf hci_rpmsg/zephyr/merged_CPUNET.hex /home/yanzhongsan/Nordic/projects/unicast_audio_client/build/modules/nrf/samples/hci_rpmsg_subimage-prefix/src/hci_rpmsg_subimage-stamp/hci_rpmsg_subimage-build /home/yanzhongsan/Nordic/projects/unicast_audio_client/build/hci_rpmsg/zephyr/zephyr.hex /home/yanzhongsan/Nordic/projects/unicast_audio_client/build/hci_rpmsg/zephyr/zephyr.elf /home/yanzhongsan/Nordic/projects/unicast_audio_client/build/hci_rpmsg/zephyr/merged_CPUNET.hex
cd /home/yanzhongsan/Nordic/projects/unicast_audio_client/build/hci_rpmsg && /usr/bin/cmake --build . --
[202/269] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/alloc.c.obj
[203/269] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/softirq.c.obj
[204/269] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/shmem.c.obj
[205/269] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/yanzhongsan/Nordic/ncs-main/modules/hal/nordic/nrfx/drivers/src/nrfx_spim.c.obj
[206/269] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/condition.c.obj
[207/269] Building C object modules/libmetal/libmetal/lib/CMakeFiles/metal.dir/system/zephyr/device.c.obj
[208/269] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/yanzhongsan/Nordic/ncs-main/modules/hal/nordic/nrfx/drivers/src/nrfx_twim.c.obj
FATAL ERROR: command exited with status 1: /usr/bin/cmake --build /home/yanzhongsan/Nordic/projects/unicast_audio_client/build
* The terminal process terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it.
how to solve it?
thanks
