Coap server not working on a third party module
I am building the CoAP client and sever example programs on a third party module (Reytac MDBT50Q). I am using Reytac dev board  MDBT50Q-DB-40. Unfortunately the example apps doesnt seem to work. I am using NRF Connect SDK 2.0.0. I tried the apps on Nordic nRF52840 Dev Kits and they work. I am using the same nrf52840dk_nrf52840.dts file with the Reytac module.
The Reytac dev board doesn't have the HFX oscillator on the dev board, probably it is available in the module itself. The dev board has a 32.7kHz crystal and is oscillating Vpp ~100mV. Dont know if this is too low. I couldnt find a spec for the LFXO in the datasheet.
When I look into the power supply on Dev board, I see VDDH tied to 3V3 and 10uH inductor between VDD and DCH. I reckon this means the power path would be 3V3->VDDH->REG0 DC/DC->REG1 (LDO or DC/DC)->System Power. I couldnt find the code section which handles the power control registers in coap client app.
  1. Is 100mV LFXO acceptable?
  2. Where is power register configuration happens in coap client/server apps?
Parents Reply
  • Hi Edvin,
    I managed to solve it. The issue was when I created the custom module based on nrf52840dk, I have missed the nrf52840dk_nrf52840.overlay file ( I had a similar file but it was all blank in my custom board def folder). After I moved this as nrf52840dk_nrf52840_Minew.overlay to my board folder, everything is working.
    I can see the packet transmission in wireshirk as well.
    Thanks you for all your help.
    Cheers,
