SHARP Memory Display Breakout - 2.7" 400x240 with nrf52840
I want to use SHARP Memory Display Breakout - 2.7" 400x240 with nrf52840 development kit. I have to interface the lvgl library for the graphics development but from the documentation, I could not figure out how to connect and there is no basic code for interfacing with the nordic SDK. Please suggest any type of reference for examples if available.
Any kind of input or help will be appreciated.
Thanks in Advance,
  • Sorry, something is wrong with the latest device tree. I will update this shortly.
  • Please try the following overlay:
    arduino_spi: &spi3 {
        status = "okay";
        cs-gpios = <&arduino_header 16 GPIO_ACTIVE_HIGH>; /* D10 */
        pinctrl-0 = < &spi3_default >;
        pinctrl-1 = < &spi3_sleep >;
        ls0xx: ls0xx@0 {
            compatible = "sharp,ls0xx";
            label = "LS0XX";
            spi-max-frequency = <2000000>;
            reg = <0>;
            width = <400>;
            height = <240>;
            extcomin-gpios = <&arduino_header 9 GPIO_ACTIVE_HIGH>; /* D3 */
            extcomin-frequency = <60>; /* required if extcomin-gpios is defined */
            disp-en-gpios = <&arduino_header 10 GPIO_ACTIVE_HIGH>; /* D4 */
    &pinctrl {
        spi3_default: spi3_default {
            group1 {
                psels = <NRF_PSEL(SPIM_SCK, 1, 15)>,  // D13
                        <NRF_PSEL(SPIM_MISO, 1, 14)>, // D12
                        <NRF_PSEL(SPIM_MOSI, 1, 13)>; // D11
        spi3_sleep: spi3_sleep {
            group1 {
                low-power-enable;
    I have now tested this overlay and I am able to see activity on all pins.
  • Attached is the code that I tested, with the updated overlay:
    20221101-lvgl.zip
  • I assume the original poster left after finding a solution. Re: footnotes on page 8 of the LS027 datasheet, EXTMODE should be connected differently based on the state of EXCOMIN, and DISP determines if the display is on. I'm not sure if this is a problem related to some configuration used in that zipped project, an error with Zephyr's Sharp driver/shield, or a misunderstanding on my part, but the DISP pin is only ever briefly toggled after startup (see below, channel 1).
    This issue is solved specifically on the Adafruit breakout by disconnecting EXTMODE, EXCOMIN, and DISP altogether, as recommended in their user guide. Unfortunately I have no more information to provide for users in the future who may not be using the breakout, maybe I'll revisit this at some point once I've completed my project but for the time being the zip you posted does work properly and displays "Hello World" along with an incrementing counter at the bottom.
    Helsing, I really appreciate you having taken the time to help solve this problem with the poster. I was working on the same bringup process this week (Adafruit breakout for the LS027 + nRF52840 DK) and I hit a stuck point on Zephyr configurations before I found this thread, but the info and files provided here were enormously helpful in guiding me through.
  • Hi  ,
    Thanks for the details. I have been working on this with Zypher but no success, then I shifted to nRF5 SDK and the segger environment. Lately, I have imported the lvgl library to the segger environment and it compiles successfully. But again I am not able to turn on my display, when I debug the program it runs and I do receive some communication over the logic analyzer of the SPI pins but the program breaks after 5 to to 6 seconds when it goes to the handler in the while loop.
    I think I need some opinion on the connections and working if you can please look at the code I am attaching and let me know what xyou think the issue could be as I think I am now very close but could not able to turn on the display.
    For connections, I am using following
    CS --> P1.10
    MOSI-->P1.13
    CLK--> P1.14
    3V3-->VDD
    GND-->GND
    I have also tried connecting other pins like DISP, EXTMODE and EXCOMIN to VDD or GND with different combincations but no luck. Please check at your end if you can see what I am doing wrong,
    /cfs-file/__key/communityserver-discussions-components-files/4/SDK_5F00_16.zip
    Looking forward to hear from you. Really appreciate the work.
