BLE Secure boot validation option on the App/bootloader zip file
Hi
I have a running DFU code and can update the bootloader as generated zip file and the app with the zip file. Now I saw, that there is the option "VALIDATE_ECDSA_P256_SHA256" to generate the packages.
See also : https://devzone.nordicsemi.com/guides/short-range-guides/b/software-development-kit/posts/getting-started-with-nordics-secure-dfu-bootloader#h12sk6tbb3hw1qnwn7q4hvp5tvthcli
Now I got 2 questions:
1. I made a test and got the Info from the packages with nrfutil pkg display and saw that to zip file for the bootloader is still with CRC validation, why?
the app is with the correct validation:
2. If I download the zip package of the APP with the --app-boot-validation VALIDATE_ECDSA_P256_SHA256, its working. But I can still download an App zip file with CRC validation. The same for the bootloader zip file. Why this? Do I have to use the nrfutil settings generate with the option --app-boot-validation and --sd-boot-validation with VALIDATE_ECDSA_P256_SHA256 aswell?
I expected that a zip file without the VALIDATE_ECDSA_P256_SHA256 is not valid and the update would be impossible, which is not the case.
Thanks for a feedback
  • Checking again, is it possible that the complete DFU OTA is working until 100%, but the check of the validation key is done after rebooting the bootloader? Because now I can do the OTA with a unsigned zip file until 100%, the bootloader restarts, is checking again and the Nordic nRF Connect App restarts automatically to download again and again, maybe because of an unsigned APP? Is this the logic?
    I expected that the check of the signed APP is done BEFORE starting the DFU. I use the single image bootloader and therefore I can "kill" the application with the Nordic App (only with an APP which was generated with the correct key, but which is unsigned)
    Is this the correct handling of the bootloader?
  • I struggle to reproduce this on a DK. Is it intended to run on custom HW? It keeps disconnecting from nRF Connect.
    You are using SDK17.0.2, right?
  • Yes, I run my code on a custom HW with the IO drive to a nRF21540 aswell included into the bootloader code.
    And yes, I work with nRF5 Software Development Kit v17.0.2.
    Again, I think its running like it should, I only expected an other feedback from the bootloader.
    What I expected:
    1) Wrong key on a Booloader or application zip DFU package -> bootloader will not accept the file and not start the flashing
    -> reality: same behaviour
    2) Bootloader or App zip DFU file with no validation option added with nrfutil (correct key added to pkg):
    --app-boot-validation VALIDATE_ECDSA_P256_SHA256 --sd-boot-validation VALIDATE_ECDSA_P256_SHA256
    -> what I expected: -> bootloader will not accept the file and not start the flashing
    -> reality: bootloader accept both zip files, flash them, restarts and do it again and agin and doesn't accept it to load. But the check that there is no validation added is recognized AFTER flash the complete zip file and not before like a wrong key. Is this how it shoulkd work or not?
    Can you try this on your DK please? Does the bootloader on your DK check and block the flashing of a application zip file WITHOUT the validation added before flashing the complete file or can the bootloader check this only if the file was transferred 100% before? (I use nRF Connect App on a Android Phone)
    Thanks a lot
    That is what I did (in an otherwise unmodified SDK).
    Actually, I was testing on SDK17.1.0, but after realizing that your bootloader project was written for SDK17.0.2, I ran the test again now.
    So the unmodified bootloader, pca10056_s140_ble, together with the ble_app_buttonless_dfu example for simplicity.
    First, without any modifications, just checking that everything was OK, and normal DFU was working. Then I changed:
    #define NRF_BL_APP_SIGNATURE_CHECK_REQUIRED 0
    to
    #define NRF_BL_APP_SIGNATURE_CHECK_REQUIRED 1
    In order to get the ble_app_buttonless_dfu example to still run, I changed the command to generate the bootloader settings from:
    nrfutil settings generate --family NRF52840 --application files\buttonless.hex --application-version 2 --bootloader-version 2 --bl-settings-version 2 --key-file ..\..\..\private.key files\settings.hex
    to
    nrfutil settings generate --family NRF52840 --application files\buttonless.hex --application-version 2 --bootloader-version 2 --bl-settings-version 2 --app-boot-validation VALIDATE_ECDSA_P256_SHA256 --key-file ..\..\..\private.key files\settings.hex
    Then the ble_app_buttonless_dfu example would still run. However, the dfu image created with the command:
    nrfutil pkg generate --application files\buttonless2.hex --application-version 3 --hw-version 52 --sd-req 0x0100 --key-file ..\..\..\private.key files\dfu_test.zip
    Does not work. It transfers the image, but the image will be rejected when the CRC is validated. To confirm that it will not run, you can monitor the nrfutil output, or you can make a change in the application that you are trying to upload (I turned on LED4 in the updated application, just to see whether it was running or not).
    Then I added the app validation in the nrfutil pkg generate command:
    nrfutil pkg generate --application files\buttonless2.hex --application-version 3 --hw-version 52 --sd-req 0x0100 --app-boot-validation VALIDATE_ECDSA_P256_SHA256 --key-file ..\..\..\private.key files\dfu_test.zip
    And then the image was accepted again.
    If you want to test yourself, unzip an unmodified DK, and add the following test.bat file to your SDK\examples\dfu\secure_bootloader\pca10056_s140_ble\armgcc folder:
    make -j9
    make -j9 -C ..\..\..\..\ble_peripheral\ble_app_buttonless_dfu\pca10056\s140\armgcc
    mkdir files
    del files\buttonless.hex
    copy ..\..\..\..\ble_peripheral\ble_app_buttonless_dfu\pca10056\s140\armgcc\_build\nrf52840_xxaa.hex files\buttonless.hex
    del files\settings.hex
    ::nrfutil settings generate --family NRF52840 --application files\buttonless.hex --application-version 2 --bootloader-version 2 --bl-settings-version 2 --key-file ..\..\..\private.key files\settings.hex
    ::nrfutil settings generate --family NRF52840 --application files\buttonless.hex --application-version 2 --bootloader-version 2 --bl-settings-version 2 --app-boot-validation VALIDATE_ECDSA_P256_SHA256 --sd-boot-validation VALIDATE_ECDSA_P256_SHA256 --key-file ..\..\..\private.key files\settings.hex
    :: REPLACE THE SERIAL NUMBER TO MATCH YOUR TARGET DK
    nrfjprog -e --snr 683825227
    nrfjprog --program _build\nrf52840_xxaa_s140.hex --verify --snr 683825227
    nrfjprog --program ..\..\..\..\..\components\softdevice\s140\hex\s140_nrf52_7.2.0_softdevice.hex --verify --snr 683825227
    nrfjprog --program files\settings.hex --verify --snr 683825227
    nrfjprog --program files\buttonless.hex --verify --snr 683825227
    nrfjprog --reset --snr 683825227
    ::nrfutil pkg generate --application files\buttonless2.hex --application-version 3 --hw-version 52 --sd-req 0x0100 --app-boot-validation VALIDATE_ECDSA_P256_SHA256 --key-file ..\..\..\private.key files\dfu_test.zip
    timeout 5
    :: REPLACE THE COM PORT TO MATCH YOUR CONNECTIVITY DK
    nrfutil dfu ble -pkg files\dfu_test.zip -ic NRF52 -p COM8 -n "Nordic_Buttonless" -f
    NB: You need to change the serial number to match your target DK and the COM port to match your connectivity DK.
    The current setup in test.bat will fail to upload the DFU. To succeed, comment out line 25 and uncomment line 26.
    Also, you need to compile the ble_app_buttonless_dfu example with a modification (not strictly needed to modify it), and place it in the files\ folder, with the name buttonless2.hex.
    Edvin
  • Does not work. It transfers the image, but the image will be rejected when the CRC is validated. To confirm that it will not run, you can monitor the nrfutil output, or you can make a change in the application that you are trying to upload (I turned on LED4 in the updated application, just to see whether it was running or not).
    Yes this is the same behaviour what I had, the DFU OTA was possible but after the transfer of 100%, the image will be rejected. My fault was, that I expected that the image will be rejected before the transfer like when I generate the files with a wrong key.
    Yes, I had the same on my custom HW.
    -> at the end I can say it's working like it should, the only "problem" was that I expected the rejection before the transfer and not after.
    Thank you for your effort and time!
