Hello All,
I need an example code of the GPIOTE port event on NRF5340 based on the nRF Connect SDK v1.9.0.
Thanks in advance,
Hello All,
Thanks in advance,
We have example code for GPIOTE events at zephyr/samples/boards/nrf/nrfx
Simply change the high_accuracy field of the in_config to "false" to use PORT event instead of IN event.
To verify, you can call nrfx_gpiote_in_event_get(pin) in the button_handler and compare the return value with NRF_GPIOTE_EVENT_PORT.
Here is a main file for the sample, which has been edited with these changes:
* Copyright (c) 2019 Nordic Semiconductor ASA
#include <zephyr.h>
#include <nrfx_gpiote.h>
#include <helpers/nrfx_gppi.h>
#if defined(DPPI_PRESENT)
#include <nrfx_dppi.h>
#else
#include <nrfx_ppi.h>
#include <logging/log.h>
LOG_MODULE_REGISTER(nrfx_sample, LOG_LEVEL_INF);
#define INPUT_PIN DT_GPIO_PIN(DT_ALIAS(sw0), gpios)
#define OUTPUT_PIN DT_GPIO_PIN(DT_ALIAS(led0), gpios)
static void button_handler(nrfx_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
LOG_INF("GPIO input event callback");
nrf_gpiote_event_t event_test;
event_test = nrfx_gpiote_in_event_get(pin);
if (event_test == NRF_GPIOTE_EVENT_PORT)
LOG_INF("PORT EVENT");
LOG_INF("IN EVENT");
void main(void)
LOG_INF("nrfx_gpiote sample on %s", CONFIG_BOARD);
nrfx_err_t err;
/* Connect GPIOTE_0 IRQ to nrfx_gpiote_irq_handler */
IRQ_CONNECT(DT_IRQN(DT_NODELABEL(gpiote)),
DT_IRQ(DT_NODELABEL(gpiote), priority),
nrfx_isr, nrfx_gpiote_irq_handler, 0);
/* Initialize GPIOTE (the interrupt priority passed as the parameter
* here is ignored, see nrfx_glue.h).
err = nrfx_gpiote_init(0);
if (err != NRFX_SUCCESS) {
LOG_ERR("nrfx_gpiote_init error: %08x", err);
return;
nrfx_gpiote_in_config_t const in_config = {
.sense = NRF_GPIOTE_POLARITY_HITOLO,
.pull = NRF_GPIO_PIN_PULLUP,
.is_watcher = false,
.hi_accuracy = false,
.skip_gpio_setup = false,
/* Initialize input pin to generate event on high to low transition
* (falling edge) and call button_handler()
err = nrfx_gpiote_in_init(INPUT_PIN, &in_config, button_handler);
LOG_ERR("nrfx_gpiote_in_init error: %08x", err);
return;
nrfx_gpiote_out_config_t const out_config = {
.action = NRF_GPIOTE_POLARITY_TOGGLE,
.init_state = 1,
.task_pin = true,
/* Initialize output pin. SET task will turn the LED on,
* CLR will turn it off and OUT will toggle it.
err = nrfx_gpiote_out_init(OUTPUT_PIN, &out_config);
LOG_ERR("nrfx_gpiote_out_init error: %08x", err);
return;
nrfx_gpiote_in_event_enable(INPUT_PIN, true);
nrfx_gpiote_out_task_enable(OUTPUT_PIN);
LOG_INF("nrfx_gpiote initialized");
/* Allocate a (D)PPI channel. */
uint8_t channel;
err = nrfx_dppi_channel_alloc(&channel);
#else
nrf_ppi_channel_t channel;
err = nrfx_ppi_channel_alloc(&channel);
LOG_ERR("(D)PPI channel allocation error: %08x", err);
return;
/* Configure endpoints of the channel so that the input pin event is
* connected with the output pin OUT task. This means that each time
* the button is pressed, the LED pin will be toggled.
nrfx_gppi_channel_endpoints_setup(channel,
nrfx_gpiote_in_event_addr_get(INPUT_PIN),
nrfx_gpiote_out_task_addr_get(OUTPUT_PIN));
/* Enable (D)PPI channel. */
err = nrfx_dppi_channel_enable(channel);
#else
err = nrfx_ppi_channel_enable(channel);
LOG_ERR("Failed to enable (D)PPI channel, error: %08x", err);
return;
LOG_INF("(D)PPI configured, leaving main()");
