Merged.hex & merged_CPUNET.hex not created (running BLE Peripheral sample)
I'm trying to run the Ble Peripheral sample from "nrf\samples\bluetooth\peripheral_lbs"
i'm using nrf connect V1.8.0 and NRF5340dk
i followed the code in the github
but i was not able to run it on the CPU_NET neither on the CPU_APP
i have read that: in order for the Bluetooth LE sample to function properly on the nRF53 the hex file <build folder>\zephyr\merged.hex has to get programmed onto the application core and the hex file <build folder>hci_rpmsg\zephyr\merged_CPUNET.hex has to get programmed onto the network core.
However i tried to run this command "nrfjprog -f NRF53 --coprocessor CP_NETWORK --eraseall && nrfjprog -f NRF53 --coprocessor CP_NETWORK --program merged_CPUNET.hex" under the "nrf\samples\bluetooth\peripheral_lbs\build_nrf5340dk_nrf5340_cpuapp\hci_rpmsg\zephyr"
but  i had an output saying that the operation is unvailable due to to readback protection on => so i tried runnning "nrfjprog -f NRF53 -- recover"  and it was successfull
but even after running ths and returninng to build the merged file it always shows the same error
do you have any suggestions to be able to build the BLE Peripheral app ?
i even tried to run it by the west command i had an error
if you have any ideas that can help or any suggestions please feel free
i will be very gratefull
Kindly,
    do you ave any recommendation to be able to build the project
    i'm linking it below
    it will make issue reproduction faster for you
    Please keep me updated if you have different output then mine
    peripheral_lbs.zip
    very kindly,
    Could your issue be due to Windows Path Length? See step 3 in Common fixes for nRF Connect SDK build problems.
    To get started with the nRF Connect SDK, i highly recommend https://academy.nordicsemi.com/.
    Sigurd Hellesvik
  • Thank you for your answer
    i managed to change the windows path to a shorter path
    and i tried to rebuild the app again but the build have failed like always
    Infact i'm keeping getting the ssme error no matter what i do
    Building ‘C:/Users/rzaafouri/ncs/v1.8.0/zephyr/include/dt-bindings/gpio/gpio.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘C:/Users/rzaafouri/ncs/v1.8.0/zephyr/include/dt-bindings/i2c/i2c.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/misc/generated/syscalls.json’ from solution ‘build’ in configuration ‘Common’
    1> Checking ‘zephyr/misc/generated/syscalls.json’
    1> zephyr/misc/generated/syscalls.json does not exist.
    1> Combining ‘zephyr/misc/generated/syscalls.json’
    1> C:\Users\rzaafouri\ncs\v1.8.0\toolchain\opt\bin\python.exe C:/Users/rzaafouri/ncs/v1.8.0/zephyr/scripts/parse_syscalls.py --include C:/Users/rzaafouri/ncs/v1.8.0/zephyr/include --include C:/Users/rzaafouri/ncs/v1.8.0/zephyr/drivers --include C:/Users/rzaafouri/ncs/v1.8.0/zephyr/subsys/net --json-file C:/Users/rzaafouri/ncs/v1.8.0/nrf/MyProjects/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/zephyr/misc/generated/syscalls.json --tag-struct-file C:/Users/rzaafouri/ncs/v1.8.0/nrf/MyProjects/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/zephyr/misc/generated/struct_tags.json
    Building ‘zephyr/misc/generated/struct_tags.json’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/CMakeFiles/parse_syscalls_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/parse_syscalls_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/driver-validation.h’ from solution ‘build’ in configuration ‘Common’
    1> Checking ‘zephyr/include/generated/driver-validation.h’
    1> zephyr/include/generated/driver-validation.h does not exist.
    1> Combining ‘zephyr/include/generated/driver-validation.h’
    1> C:\Users\rzaafouri\ncs\v1.8.0\toolchain\opt\bin\python.exe C:/Users/rzaafouri/ncs/v1.8.0/zephyr/scripts/gen_kobject_list.py --validation-output C:/Users/rzaafouri/ncs/v1.8.0/nrf/MyProjects/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/zephyr/include/generated/driver-validation.h --include C:/Users/rzaafouri/ncs/v1.8.0/nrf/MyProjects/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/zephyr/misc/generated/struct_tags.json
    Building ‘zephyr/CMakeFiles/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/kobj-types-enum.h’ from solution ‘build’ in configuration ‘Common’
    1> Checking ‘zephyr/include/generated/kobj-types-enum.h’
    1> zephyr/include/generated/kobj-types-enum.h does not exist.
    1> Combining ‘zephyr/include/generated/kobj-types-enum.h’
    1> C:\Users\rzaafouri\ncs\v1.8.0\toolchain\opt\bin\python.exe C:/Users/rzaafouri/ncs/v1.8.0/zephyr/scripts/gen_kobject_list.py --kobj-types-output C:/Users/rzaafouri/ncs/v1.8.0/nrf/MyProjects/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/zephyr/include/generated/kobj-types-enum.h --kobj-otype-output C:/Users/rzaafouri/ncs/v1.8.0/nrf/MyProjects/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/zephyr/include/generated/otype-to-str.h --kobj-size-output C:/Users/rzaafouri/ncs/v1.8.0/nrf/MyProjects/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/zephyr/include/generated/otype-to-size.h --include C:/Users/rzaafouri/ncs/v1.8.0/nrf/MyProjects/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/zephyr/misc/generated/struct_tags.json
    Building ‘zephyr/include/generated/otype-to-str.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/CMakeFiles/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/otype-to-size.h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/syscall_list.h’ from solution ‘build’ in configuration ‘Common’
    1> Checking ‘zephyr/include/generated/syscall_list.h’
    1> zephyr/include/generated/syscall_dispatch.c does not exist.
    1> Combining ‘zephyr/include/generated/syscall_list.h’
    1> C:\Users\rzaafouri\ncs\v1.8.0\toolchain\opt\bin\python.exe C:/Users/rzaafouri/ncs/v1.8.0/zephyr/scripts/gen_syscalls.py --json-file C:/Users/rzaafouri/ncs/v1.8.0/nrf/MyProjects/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/zephyr/misc/generated/syscalls.json --base-output include/generated/syscalls --syscall-dispatch include/generated/syscall_dispatch.c --syscall-list C:/Users/rzaafouri/ncs/v1.8.0/nrf/MyProjects/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/zephyr/include/generated/syscall_list.h --split-type k_timeout_t
    Building ‘zephyr/CMakeFiles/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/syscall_dispatch.c’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_offsets’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj’ from solution ‘build’ in configuration ‘Common’
    2> Checking ‘offsets.c’
    2> zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj does not exist.
    2> Compiling ‘offsets.c’
    2> C:\Users\rzaafouri\ncs\v1.8.0\toolchain\opt/bin/arm-none-eabi-gcc -DBUILD_VERSION=v2.7.0-ncs1 -DKERNEL -DNRF5340_XXAA_APPLICATION -DUSE_PARTITION_MANAGER=1 -D_FORTIFY_SOURCE=2 -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/Users/rzaafouri/ncs/v1.8.0/zephyr/kernel/include -IC:/Users/rzaafouri/ncs/v1.8.0/zephyr/arch/arm/include -IC:/Users/rzaafouri/ncs/v1.8.0/zephyr/include -Izephyr/include/generated -IC:/Users/rzaafouri/ncs/v1.8.0/zephyr/soc/arm/nordic_nrf/nrf53 -IC:/Users/rzaafouri/ncs/v1.8.0/zephyr/subsys/bluetooth -IC:/Users/rzaafouri/ncs/v1.8.0/zephyr/subsys/settings/include -IC:/Users/rzaafouri/ncs/v1.8.0/nrf/include -IC:/Users/rzaafouri/ncs/v1.8.0/modules/hal/cmsis/CMSIS/Core/Include -IC:/Users/rzaafouri/ncs/v1.8.0/modules/hal/nordic/nrfx -IC:/Users/rzaafouri/ncs/v1.8.0/modules/hal/nordic/nrfx/drivers/include -IC:/Users/rzaafouri/ncs/v1.8.0/modules/hal/nordic/nrfx/mdk -IC:/Users/rzaafouri/ncs/v1.8.0/zephyr/modules/hal_nordic/nrfx/. -Imodules/libmetal/libmetal/lib/include -IC:/Users/rzaafouri/ncs/v1.8.0/modules/lib/open-amp/open-amp/lib/include -IC:/Users/rzaafouri/ncs/v1.8.0/modules/crypto/tinycrypt/lib/include -IC:/Users/rzaafouri/ncs/v1.8.0/nrfxlib/softdevice_controller/include -isystem C:/Users/rzaafouri/ncs/v1.8.0/zephyr/lib/libc/minimal/include -isystem c:/users/rzaafouri/ncs/v1.8.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/include -isystem c:/users/rzaafouri/ncs/v1.8.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/include-fixed -isystem C:/Users/rzaafouri/ncs/v1.8.0/nrfxlib/crypto/nrf_cc312_platform/include -Os -imacros C:/Users/rzaafouri/ncs/v1.8.0/nrf/MyProjects/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee -imacros C:/Users/rzaafouri/ncs/v1.8.0/zephyr/include/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-address-of-packed-member -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=C:/Users/rzaafouri/ncs/v1.8.0/nrf/MyProjects/peripheral_lbs=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/Users/rzaafouri/ncs/v1.8.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/Users/rzaafouri/ncs/v1.8.0=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MF C:/Users/rzaafouri/ncs/v1.8.0/nrf/MyProjects/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/zephyr\CMakeFiles\offsets.dir\arch\arm\core\offsets\offsets.c.obj.d -fno-diagnostics-show-caret -o zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj -c C:/Users/rzaafouri/ncs/v1.8.0/zephyr/arch/arm/core/offsets/offsets.c
    Building ‘zephyr/offsets’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/include/generated/offsets.h’ from solution ‘build’ in configuration ‘Common’
    1> Checking ‘zephyr/include/generated/offsets.h’
    1> zephyr/include/generated/offsets.h does not exist.
    1> Combining ‘zephyr/include/generated/offsets.h’
    1> C:\Users\rzaafouri\ncs\v1.8.0\toolchain\opt\bin\python.exe C:/Users/rzaafouri/ncs/v1.8.0/zephyr/scripts/gen_offset_header.py -i C:/Users/rzaafouri/ncs/v1.8.0/nrf/MyProjects/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj -o C:/Users/rzaafouri/ncs/v1.8.0/nrf/MyProjects/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/zephyr/include/generated/offsets.h
    Building ‘zephyr/CMakeFiles/offsets_h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/offsets_h’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/zephyr_generated_headers’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_app’ from solution ‘build’ in configuration ‘Common’
    Building ‘app/libapp.a’ from solution ‘build’ in configuration ‘Common’
    2> Checking ‘main.c’
    2> CMakeFiles/app.dir/src/main.c.obj does not exist.
    2> Compiling ‘main.c’
    2> C:\Users\rzaafouri\ncs\v1.8.0\toolchain\opt/bin/arm-none-eabi-gcc -DBUILD_VERSION=v2.7.0-ncs1 -DKERNEL -DNRF5340_XXAA_APPLICATION -DUSE_PARTITION_MANAGER=1 -D_FORTIFY_SOURCE=2 -D__PROGRAM_START -D__ZEPHYR__=1 -I../. -IC:/Users/rzaafouri/ncs/v1.8.0/zephyr/include -Izephyr/include/generated -IC:/Users/rzaafouri/ncs/v1.8.0/zephyr/soc/arm/nordic_nrf/nrf53 -IC:/Users/rzaafouri/ncs/v1.8.0/zephyr/subsys/bluetooth -IC:/Users/rzaafouri/ncs/v1.8.0/zephyr/subsys/settings/include -IC:/Users/rzaafouri/ncs/v1.8.0/nrf/include -IC:/Users/rzaafouri/ncs/v1.8.0/modules/hal/cmsis/CMSIS/Core/Include -IC:/Users/rzaafouri/ncs/v1.8.0/modules/hal/nordic/nrfx -IC:/Users/rzaafouri/ncs/v1.8.0/modules/hal/nordic/nrfx/drivers/include -IC:/Users/rzaafouri/ncs/v1.8.0/modules/hal/nordic/nrfx/mdk -IC:/Users/rzaafouri/ncs/v1.8.0/zephyr/modules/hal_nordic/nrfx/. -Imodules/libmetal/libmetal/lib/include -IC:/Users/rzaafouri/ncs/v1.8.0/modules/lib/open-amp/open-amp/lib/include -IC:/Users/rzaafouri/ncs/v1.8.0/modules/crypto/tinycrypt/lib/include -IC:/Users/rzaafouri/ncs/v1.8.0/nrfxlib/softdevice_controller/include -isystem C:/Users/rzaafouri/ncs/v1.8.0/zephyr/lib/libc/minimal/include -isystem c:/users/rzaafouri/ncs/v1.8.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/include -isystem c:/users/rzaafouri/ncs/v1.8.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/include-fixed -isystem C:/Users/rzaafouri/ncs/v1.8.0/nrfxlib/crypto/nrf_cc312_platform/include -Os -imacros C:/Users/rzaafouri/ncs/v1.8.0/nrf/MyProjects/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee -imacros C:/Users/rzaafouri/ncs/v1.8.0/zephyr/include/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-address-of-packed-member -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=C:/Users/rzaafouri/ncs/v1.8.0/nrf/MyProjects/peripheral_lbs=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/Users/rzaafouri/ncs/v1.8.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/Users/rzaafouri/ncs/v1.8.0=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MF C:/Users/rzaafouri/ncs/v1.8.0/nrf/MyProjects/peripheral_lbs/build_nrf5340dk_nrf5340_cpuapp/CMakeFiles\app.dir\src\main.c.obj.d -fno-diagnostics-show-caret -o CMakeFiles/app.dir/src/main.c.obj -c ../src/main.c
    2> ../src/main.c:11:10: fatal error: zephyr/sys/printk.h: No such file or directory
    2> compilation terminated.
    Build failed
    is it related to the version of toolchain manager ?
    Do you know if there's any solution to this error please ?
    can you help me please
    Try to delete the build folder manually and then build the project again.
    What is your new, shorter path for the nRF Connect SDK?
    Sigurd Hellesvik
    My newpath is "C:\Users\rzaafouri\ncs\v1.8.0\nrf\MyProjects\peripheral_lbs"
    and it's important to precise that when i build the build file is not even created i get the fatal error befor even the build file is created
    all i have is the build_nrf5340dk_nrf5340_cpuapp .
    it's problematic
    do you know what's the main issue here please
