ble_app_uart won't advertise as coded from example set
Hello, I am currently trying to program the uart example code from the nRF5_SDK_12.3.0_d7731ad zip file. After dealing with various reference address and device package issues, I am now able to flash the softdevice and progam sets to the chip. However, the chip is not advertising and it does work with the premade hex file. At this point I have no idea what could be wrong, the only noticible difference between the hex file layout in nRF Connect and the flashed softdevice and code from Kiel 5 is shown in the attached image, with hex file on the left covers the register address from 0 to 0x0001E3F7 while the flashed program from Keil goes from 0 to 0x0001E3FF. Other than that the recovery error is shown in the command window, but this occured even for the hex file which would advertise so I am unsure how to proceed.
  • Hi
    Okay, do you perhaps only flash the application, and not the SoftDevice? As this is necessary to flash as well when building/flashing using Keil.
    Simon
  • Hello Simonr,
    No, as seen in the first image from nRFConnect, I would flash both the application and the SoftDevice. Attached is the Flash log of the SoftDevice. I had only sent the applications flash log as I would think the error was only occuring there.
    Load "..\\..\\..\\..\\..\\..\\components\\softdevice\\s130\\hex\\s130_nrf51_2.0.1_softdevice.hex"
    Set JLink Project File to "C:\ncs\nRF5_SDK_12.3.0_d7731ad\examples\ble_peripheral\ble_app_uart\pca10028\s130\arm5_no_packs\JLinkSettings.ini"
    * JLink Info: Device "NRF51422_XXAC" selected.
    JLink info:
    DLL: V7.68 , compiled Jul 14 2022 16:47:42
    Firmware: J-Link OB-SAM3U128-V2-NordicSemi compiled Jan 20 2022 16:43:31
    Hardware: V1.00
    S/N : 681222439
    Feature(s) : RDI, FlashBP, FlashDL, JFlash, GDB
    * JLink Info: Found SW-DP with ID 0x0BB11477
    * JLink Info: DPIDR: 0x0BB11477
    * JLink Info: CoreSight SoC-400 or earlier
    * JLink Info: Scanning AP map to find all available APs
    * JLink Info: AP[1]: Stopped AP scan as end of AP map has been reached
    * JLink Info: AP[0]: AHB-AP (IDR: 0x04770021)
    * JLink Info: Iterating through AP map to find AHB-AP to use
    * JLink Info: AP[0]: Core found
    * JLink Info: AP[0]: AHB-AP ROM base: 0xF0000000
    * JLink Info: CPUID register: 0x410CC200. Implementer code: 0x41 (ARM)
    * JLink Info: Found Cortex-M0 r0p0, Little endian.
    * JLink Info: FPUnit: 4 code (BP) slots and 0 literal slots
    * JLink Info: CoreSight components:
    * JLink Info: ROMTbl[0] @ F0000000
    * JLink Info: [0][0]: E00FF000 CID B105100D PID 000BB471 ROM Table
    * JLink Info: ROMTbl[1] @ E00FF000
    * JLink Info: [1][0]: E000E000 CID B105E00D PID 000BB008 SCS
    * JLink Info: [1][1]: E0001000 CID B105E00D PID 000BB00A DWT
    * JLink Info: [1][2]: E0002000 CID B105E00D PID 000BB00B FPB
    * JLink Info: [0][1]: F0002000 CID B105900D PID 000BB9A3 ???
    ROMTableAddr = 0xF0000000
    * JLink Info: Reset: Halt core after reset via DEMCR.VC_CORERESET.
    * JLink Info: Reset: Reset device via AIRCR.SYSRESETREQ.
    Target info:
    Device: nRF51422_xxAC
    VTarget = 3.300V
    State of Pins:
    TCK: 0, TDI: 1, TDO: 1, TMS: 1, TRES: 1, TRST: 1
    Hardware-Breakpoints: 4
    Software-Breakpoints: 8192
    Watchpoints:          2
    JTAG speed: 1000 kHz
    Erase Done.
    Programming Done.
    Verify OK.
    Application running ...
    Flash Load finished at 23:56:23
    SIncerely,
    Alexandre Tessier
  • Okay, and still the only change you made from the original example is to change the DEVICE_NAME, correct? What did you change it to exactly? If it is too long to fit in the advertising packet it might not show up as the name you thought.
    Simon
  • Hello Simonr, I changed the name to EMG. So definetly should not have any effect.
  • Hi
    I'm inclined to think that there must be something else changed in your project, as it should be identical to the .hex file you're using. Can you try downloading a fresh instance of the SDK, as the ble_app_uart project works fine on my end in SD v12.3.0
    Simon
