Issues with 52832 sleep current
The product is used in a humid environment, found that the 52832 chip sleep current becomes large, from 30uA to 80uA, now has disconnected all external pins only retain the most basic peripheral circuit, the situation is still the same. If you use a baking gun to blow on the chip for a short time, the current will return to normal. What has happened inside the chip due to the water vapor that caused the current to increase, and what should I do next?
Thanks & Regards,
xiaoQ911
