I want to use the BLE Secure connection feature with the following options
CONFIG_BT_SMP_SC_PAIR_ONLY=y
CONFIG_BT_SMP_SC_ONLY=y
CONFIG_BT_SMP_APP_PAIRING_ACCEPT=y
CONFIG_BT_SMP_DISABLE_LEGACY_JW_PASSKEY=y
CONFIG_BT_FIXED_PASSKEY=y
I know that using a fixed passkey is discouraged but my peripheral will not have a display and the pairing should be done automatically. I have opted for creating a secret algorithm that generates the passkey dynamically with bt_passkey_set. The Central also knows the algorithm and can figure automatically which passkey should be sent.
Before I continue with the idea of generating dynamically the passkey with bt_passkey_set. I decided to enter a constant passkey at the beginning.
bt_passkey_set(123456);
Unfortunately when I try to pair with for example an Android Device I dont get the passkey dialog and the connection has a timeout and closes. If I do not use a static passkey with CONFIG_BT_FIXED_PASSKEY=y I get a random passkey, the BLE central gets the dialog to enter the passkey and zephyr calls the display passkey_display callback.
To Reproduce
Use any example that has a BLE peripheral and add the following Kconfig options
As callbacks use the following for authentication
static void auth_passkey_display(bt_conn *conn, unsigned int passkey) { char addr[BT_ADDR_LE_STR_LEN]; bt_addr_le_to_str(bt_conn_get_dst(conn), addr, sizeof(addr)); printk("Passkey for %s: %06u\n", addr, passkey); } static void auth_cancel(bt_conn *conn) { char addr[BT_ADDR_LE_STR_LEN]; bt_addr_le_to_str(bt_conn_get_dst(conn), addr, sizeof(addr)); printk("Pairing cancelled: %s\n", addr); } static void pairing_confirm(bt_conn *conn) { bt_conn_auth_passkey_confirm(conn); } static bt_conn_auth_cb auth_cb_display = { .passkey_display = auth_passkey_display, .passkey_entry = nullptr, .cancel = auth_cancel, .pairing_confirm = pairing_confirm };
In your bluetooth initialization call the following to register the callbacks and set the passkey:
bt_conn_auth_cb_register(&auth_cb_display); bt_passkey_set(123456);
Expected behavior
Android Central device should get a passkey dialog to enter the passkey after pairing attempt with BLE Secure connection enabled on Zephyr.
If anyone could point me out what I am doing wrong API-wise or Kconfig-wise would be really helpful-
