Power Profiler Kit 2 shows non-linearity measurement result
Dear person in charge.
Before using PPK2 for a evaluation of current consumption, I checkd power supply vs corrent measurement by using PPK2 and 5kΩ chip resistor.
I expected that power supply vs corrent measuremen shows linearity, however, PPK2 shows non-linearity.
Would you support how to solve this issue ?
Can you see this issue ?
If this issue does not be improved, I can't use PPK2 for our evaluation.
[Issue]
・PPK2 result shows non-linearity.
・I think Range3(500μA-5mA) cause this problem because lower currents are same as Ideal (5kΩ / Vin) .
・I used Agilent N6705B (DC power analyzer) as reference data, this result is the same as Ideal.
   So, this non-linearity issue occurs at only PPK2.
[Measurement Setup]
・VOUT : 800mV ~ 4000mV
(HW setup)
(SW setup)
・Power Profiler v3.4.5
