Error when fetching device versions: readFwInfo error (Origin: "Error when running nrfdl_fw_read_info")
I am suffering a very similar problem as to case 280113 (ERROR Error when fetching device versions: readFwInfo error (Origin: "Error when running nrfdl_fw_read_info")) and I was wanting to see if there are any updates or changes that assist me in programming an nRF52840 Dongle.
Below I have collected the details of software versions and the procedure that I have been through to get the system to work correctly and collect log reports etc.
As an aside I have repeated this exact same procedure for the nRF52840DK and managed to successfully program the blinky App into the device.
Any guidance on curing this issue is greatly appreciated.
Details below.
Regards
Andy
Software versions:
nRF Connect for Desktop version 3.12.0
Programmer version 3.0.4
The procedure I followed is as follows:
1. Start nRF Connect for Desktop
2. Start Programmer
3. Attached nRF52840 Dongle to USB, red LED pulsing every second
4. Pressed reset button
5. SELECT DEVICE -> Open DFU Bootloader D7BA81B22774
6. Error log is shown below
7. Collected detailed error message and shown below
8. Collected System Report - shown below.
9. Performed nrfjprog --recover
ERROR: No debuggers were discovered.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
10. Repeated for two different dongles: PCA10059 1.2.0 2019.41 and PCA10059 2.1.0 2022.9
Exactly the same result
11. Repeated for nRF52840DK device: PCA10056 2.0.0 2019.48
Worked correctly
Error Log:
2022-09-18T08:05:43.103Z DEBUG Application data folder: C:\Users\Andy\AppData\Roaming\nrfconnect\pc-nrfconnect-programmer
2022-09-18T08:05:43.424Z INFO Using nrf-device-lib-js version: 0.4.13
2022-09-18T08:05:43.425Z INFO Using nrf-device-lib version: 0.12.8
2022-09-18T08:05:43.425Z INFO Using nrfjprog DLL version: 10.16.0
2022-09-18T08:05:43.426Z INFO Using JLink version: JLink_V7.66a
2022-09-18T08:05:43.615Z DEBUG App pc-nrfconnect-programmer v3.0.4 official
2022-09-18T08:05:43.616Z DEBUG App path: C:\Users\Andy\.nrfconnect-apps\node_modules\pc-nrfconnect-programmer
2022-09-18T08:05:43.616Z DEBUG nRFConnect 3.12.0, required by the app is (^3.12.0)
2022-09-18T08:05:43.617Z DEBUG nRFConnect path: C:\Users\Andy\AppData\Local\Programs\nrfconnect\resources\app.asar
2022-09-18T08:05:43.617Z DEBUG HomeDir: C:\Users\Andy
2022-09-18T08:05:43.617Z DEBUG TmpDir: C:\Users\Andy\AppData\Local\Temp
2022-09-18T08:05:48.134Z DEBUG Client Id: 773cbbf7-d4cb-4122-8e5c-dc8ae40e802d
2022-09-18T08:05:51.189Z DEBUG Google Analytics for category pc-nrfconnect-programmer has initialized
2022-09-18T08:05:59.444Z DEBUG Sending usage data {"category":"pc-nrfconnect-programmer","action":"architecture","label":"ia32"}
2022-09-18T08:05:59.447Z DEBUG Sending usage data {"category":"pc-nrfconnect-programmer","action":"Open device","label":"nordicUsb"}
2022-09-18T08:05:59.453Z INFO Using @nordicsemiconductor/nrf-device-lib-js to communicate with target via USB SDFU protocol
2022-09-18T08:05:59.454Z DEBUG Sending usage data {"category":"pc-nrfconnect-programmer","action":"Open jlink device family","label":"NRF52_FAMILY"}
2022-09-18T08:05:59.455Z DEBUG Sending usage data {"category":"pc-nrfconnect-programmer","action":"Open jlink device version","label":"nRF52840"}
2022-09-18T08:05:59.457Z DEBUG Sending usage data {"category":"pc-nrfconnect-programmer","action":"Open jlink device board version","label":"PCA10059"}
2022-09-18T08:05:59.537Z ERROR Error when fetching device versions: readFwInfo error (Origin: "Error when running nrfdl_fw_read_info")
2022-09-18T08:08:32.154Z DEBUG Sending usage data {"category":"pc-nrfconnect-programmer","action":"Close device","label":""}
2022-09-18T08:08:32.158Z INFO Target device closed
Show Detailed Error Message:
Cannot read property 'map' of undefined
TypeError: Cannot read property 'map' of undefined
at n (C:\Users\Andy\.nrfconnect-apps\node_modules\pc-nrfconnect-programmer\dist\bundle.js:45:92325)
at Ki (file:///C:/Users/Andy/AppData/Local/Programs/nrfconnect/resources/app.asar/dist/app-bundle.js:40:57930)
at ys (file:///C:/Users/Andy/AppData/Local/Programs/nrfconnect/resources/app.asar/dist/app-bundle.js:40:104169)
at ul (file:///C:/Users/Andy/AppData/Local/Programs/nrfconnect/resources/app.asar/dist/app-bundle.js:40:96717)
at sl (file:///C:/Users/Andy/AppData/Local/Programs/nrfconnect/resources/app.asar/dist/app-bundle.js:40:96642)
at Qs (file:///C:/Users/Andy/AppData/Local/Programs/nrfconnect/resources/app.asar/dist/app-bundle.js:40:93672)
at file:///C:/Users/Andy/AppData/Local/Programs/nrfconnect/resources/app.asar/dist/app-bundle.js:40:45314
at t.unstable_runWithPriority (file:///C:/Users/Andy/AppData/Local/Programs/nrfconnect/resources/app.asar/dist/app-bundle.js:48:3844)
at zo (file:///C:/Users/Andy/AppData/Local/Programs/nrfconnect/resources/app.asar/dist/app-bundle.js:40:45023)
at Go (file:///C:/Users/Andy/AppData/Local/Programs/nrfconnect/resources/app.asar/dist/app-bundle.js:40:45259)
Show System Report:
# nRFConnect System Report - 2022-09-18T08-16-09.742Z
- System: LENOVO 20DQ0039UK
- BIOS: LENOVO LENOVO - 1390
- CPU: 1 x Intel CoreTm i7-5500U 2.4 GHz 4 cores (2 physical)
- Memory: 1.1 GB free of 7.9 GB total
- Filesystem: C: (NTFS) 224.3 GB 91.0% used
- OS: Microsoft Windows 8.1 Pro (6.3.9600) Windows ia32
- Versions
- kernel: 6.3.9600
- git: 2.13.0.windows.1
- node: 14.16.0
- python: 2.7.10
- python3:
- nrf-device-lib-js: 0.4.13
- nrf-device-lib: 0.12.8
- nrfjprog DLL: 10.16.0
- JLink: JLink_V7.66a
- Connected devices:
- D7BA81B22774 : undefined
- Current device:
- name: Open DFU Bootloader
- serialNumber: D7BA81B22774
- cores: Unknown
- website: Unknown
