Logging thread stack overflow
I am having an issue with Zephyr, it constantly reboots the system because of stack overflow.
00> [00:05:36.447,265] <err> os: r0/a1:  0x00000002  r1/a2:  0x20004d60  r2/a3:  0xf0f0f0f0
00> [00:05:36.447,296] <err> os: r3/a4:  0x2000e700 r12/ip:  0x2000a5e4 r14/lr:  0x00058045[0m
00> [00:05:36.447,326] <err> os:  xpsr:  0x41070000
00> [00:05:36.447,326] <err> os: r4/v1:  0x00000000  r5/v2:  0xffffffff  r6/v3:  0xffffffff
00> [00:05:36.447,357] <err> os: r7/v4:  0x00000000  r8/v5:  0x00000001  r9/v6:  0x00000000
00> [00:05:36.447,357] <err> os: r10/v7: 0x00000001  r11/v8: 0x20001a00    psp:  0x20026d28
00> [00:05:36.447,357] <err> os: EXC_RETURN: 0x0
00> [00:05:36.447,387] <err> os: Faulting instruction address (r15/pc): 0x00046704
00> [00:05:36.447,418] <err> os: >>> ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0
00> [00:05:36.447,418] <err> os: Current thread: 0x20004d60 (logging)
00> [00:05:36.780,670] <err> fatal_error: Resetting system
[03:04:16.903,503] <err> os: r0/a1:  0x00000002  r1/a2:  0xe000ed04  r2/a3:  0xf0f0f0f0
00> [03:04:16.903,533] <err> os: r3/a4:  0x2000e700 r12/ip:  0x00000000 r14/lr:  0x0003235d
00> [03:04:16.903,533] <err> os:  xpsr:  0x410f0021
00> [03:04:16.903,564] <err> os: r4/v1:  0x20003890  r5/v2:  0x0005a3a3  r6/v3:  0x00000007
00> [03:04:16.903,564] <err> os: r7/v4:  0x000000c6  r8/v5:  0x20003888  r9/v6:  0x00030f79
00> [03:04:16.903,594] <err> os: r10/v7: 0x00058b54  r11/v8: 0x00000000    psp:  0x20026c10
00> [03:04:16.903,594] <err> os: EXC_RETURN: 0x0
00> [03:04:16.903,594] <err> os: Faulting instruction address (r15/pc): 0x00046704
00> [03:04:16.903,625] <err> os: >>> ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0
00> [03:04:16.903,656] <err> os: Fault during interrupt handling
00>
00> [03:04:16.903,656] <err> os: Current thread: 0x20004d60 (logging)
00> [03:04:17.257,568] <err> fatal_error: Resetting system[0m
Sometimes in these faults, it says "Fault during interrupt handling".
The code line for the faulting address is:
arm-none-eabi-addr2line.exe -e build\zephyr\zephyr.elf 0x00046704
ncs/v2.1.0/zephyr/kernel/thread.c:380
It is actually in reference to the SENTINEL mechanism:
I am using the following CONFIG options for logging, and even with absurd values of stack it still fails:
# -- Lora
# -- BLE
# -- MCUBoot
# -- Logs
CONFIG_UART_CONSOLE=n
CONFIG_USE_SEGGER_RTT=y
CONFIG_RTT_CONSOLE=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG=y
CONFIG_LOG_PROCESS_THREAD=y
CONFIG_LOG_DEFAULT_LEVEL=4
CONFIG_LOG_BUFFER_SIZE=8192
CONFIG_PRINTK=n
CONFIG_LOG_PRINTK=n
CONFIG_NEWLIB_LIBC=y
CONFIG_CBPRINTF_FULL_INTEGRAL=y
CONFIG_CBPRINTF_FP_SUPPORT=y
CONFIG_NEWLIB_LIBC_FLOAT_SCANF=y
CONFIG_NEWLIB_LIBC_NANO=n
# -- Optimizations
CONFIG_NO_OPTIMIZATIONS=n
# -- Sentinel and stacks
CONFIG_STACK_SENTINEL=y
CONFIG_THREAD_STACK_INFO=y
CONFIG_THREAD_MONITOR=y
CONFIG_INIT_STACKS=y
CONFIG_THREAD_NAME=y
CONFIG_EXTRA_EXCEPTION_INFO=y
CONFIG_GPIO_LOG_LEVEL_DBG=y
CONFIG_LORA_LOG_LEVEL_DBG=y
CONFIG_BT_RX_STACK_SIZE=4096
CONFIG_IDLE_STACK_SIZE=4096
CONFIG_PRIVILEGED_STACK_SIZE=4096
CONFIG_BT_CTLR_RX_PRIO_STACK_SIZE=1024
CONFIG_BT_HCI_TX_STACK_SIZE=4096
CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=100000
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_ISR_STACK_SIZE=32768
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
# -- Heap
CONFIG_HEAP_MEM_POOL_SIZE=15240
Is the problem really the logging thread? Any suggestions?
  • I am running now without enabling the logging thread, by setting the following:
    CONFIG_LOG_PROCESS_THREAD=n
    CONFIG_LOG_MODE_IMMEDIATE=y
    #CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=100000
    I have also added the following:
    # Thread analyzer
    CONFIG_THREAD_ANALYZER=y
    CONFIG_THREAD_ANALYZER_ISR_STACK_USAGE=y
    CONFIG_THREAD_ANALYZER_AUTO_INTERVAL=10
    CONFIG_THREAD_ANALYZER_AUTO=y
    CONFIG_THREAD_ANALYZER_USE_LOG=y
    CONFIG_THREAD_ANALYZER_AUTO_STACK_SIZE=4096
    Through the log, the fault happened a little different now:
    00> [01:01:48.405,303] <inf> internaluart: Requisicao Status ok
    00> [01:01:48.644,317] <inf> internaluart: Requisicao LORA ok
    00> [01:01:48.773,315] <dbg> sx12xx_common: sx12xx_lora_send: Expected air time of 171 bytes = 277ms
    00> [01:01:55.327,392] <inf> thread_analyzer: Thread analyze:
    00> [01:01:55.327,850] <inf> thread_analyzer:  BT CTLR ECDH        : STACK: unused 196 usage 708 / 904 (78 %); CPU: 0 %
    00> [01:01:55.328,460] <inf> thread_analyzer:       : Total CPU cycles used: 852
    00> [01:01:55.329,559] <inf> thread_analyzer:  BT RX               : STACK: unused 3900 usage 196 / 4096 (4 %); CPU: 0 %
    00> [01:01:55.330,200] <inf> thread_analyzer:       : Total CPU cycles used: 2
    00> [01:01:55.330,810] <inf> thread_analyzer:  BT TX               : STACK: unused 996 usage 540 / 1536 (35 %); CPU: 0 %
    00> [01:01:55.331,451] <inf> thread_analyzer:       : Total CPU cycles used: 76
    00> [01:01:55.332,427] <inf> thread_analyzer:  thread_analyzer     : STACK: unused 3180 usage 916 / 4096 (22 %); CPU: 0 %
    00> [01:01:55.333,099] <inf> thread_analyzer:       : Total CPU cycles used: 814167
    00> [01:01:55.334,960] <inf> thread_analyzer:  lora_task_id        : STACK: unused 7868 usage 2372 / 10240 (23 %); CPU: 0 %
    00> [01:01:55.335,601] <inf> thread_analyzer: [01:01:55.351,165] <inf> thread_analyzer:  internal_comm_task_id: STACK: unused 340 usage 684 / 1024 (66 %); CPU: 0 %
    00> [01:01:55.356,933] <inf> thread_analyzer:       : Total CPU cycles used: 97168
    00> [01:01:55.358,093] <inf> thread_analyzer:  ble_task_id         : STACK: unused 4308 usage 812 / 5120 (15 %); CPU: 0 %
    00> [01:01:55.358,703] <inf> thread_analyzer:       : Total CPU cycles used: 376413
    00> [01:01:55.359,771] <inf> thread_analyzer:  sysworkq            : STACK: unused 3676 usage 420 / 4096 (10 %); CPU: 0 %
    00> [01:01:55.360,412] <inf> thread_analyzer:       : Total CPU cycles used: 5224
    00> [01:01:55.361,022] <inf> thread_analyzer:  MPSL Work           : STACK: unused 780 usage 244 / 1024 (23 %); CPU: 0 %
    00> [01:01:55.366,790] <inf> thread_analyzer:       : Total CPU cycles used: 123
    00> [01:01:55.367,370] <inf> thread_analyzer:  BT_LW_WQ            : STACK: unused 628 usage 676 / 1304 (51 %); CPU: 0 %
    00> [01:01:55.368,041] <inf> thread_anal[01:01:55.384,216] <inf> thread_analyzer:  idle                : STACK: unused 3964 usage 132 / 4096 (3 %); CPU: 98 %
    00> [01:01:55.384,918] <inf> thread_analyzer:       : Total CPU cycles used: 119996721
    00> [01:01:55.390,319] <inf> thread_analyzer:  ISR0                : STACK: unused 31636 usage 1132 / 32768 (3 %)
    00> [01:02:05.390,991] <inf> thread_analyzer: Thread analyze:
    00> [01:02:05.391,448] <inf> thread_analyzer:  BT CTLR ECDH        : STACK: unused 196 usage 708 / 904 (78 %); CPU: 0 %
    00> [01:02:05.392,059] <inf> thread_analyzer:       : Total CPU cycles used: 852
    00> [01:02:05.393,157] <inf> thread_analyzer:  BT RX               : STACK: unused 3900 usage 196 / 4096 (4 %); CPU: 0 %
    00> [01:02:05.393,798] <inf> thread_analyzer:       : Total CPU cycles used: 2
    00> [01:02:05.394,439] <inf> thread_analyzer:  BT TX               : STACK: unused 996 usage 540 / 1536 (35 %); CPU: 0 %
    00> [01:02:05.395,080] <inf> thread_analyzer:       : Total CPU cycles used: 76
    00> [01:02:05.396,209] <inf> thread_analyzer:  thread_analyzer     : STACK: unused 3180 usage 916 / 4096 (22 %); CPU: 0 %
    00> [01:02:05.396,850] <inf> thread_analyzer:       : Total CPU cycles used: 816241
    00> [01:02:05.398,559] <inf> thread_analyzer:  lora_task_id        : STACK: unused 7868 usage 2372 / 10240 (23 %); CPU: 0 %
    00> [01:02:05.404,205] <inf> thread_analyzer:       : Total CPU cycles used: 56096
    00> [01:02:05.404,754] <inf> thread_analyzer:  internal_comm_task_id: STACK: unused 340 usage 684 / 1024 (66 %); CPU: 0 %
    00> [01:02:05.405,456] <inf> thread_analyzer:       : Total CPU cyc[01:02:05.421,722] <inf> thread_analyzer:  ble_task_id         : STACK: unused 4308 usage 812 / 5120 (15 %); CPU: 0 %
    00> [01:02:05.427,490] <inf> thread_analyzer:       : Total CPU cycles used: 377422
    00> [01:02:05.428,558] <inf> thread_analyzer:  sysworkq            : STACK: unused 3676 usage 420 / 4096 (10 %); CPU: 0 %
    00> [01:02:05.429,229] <inf> thread_analyzer:       : Total CPU cycles used: 5224
    00> [01:02:05.429,840] <inf> thread_analyzer:  MPSL Work           : STACK: unused 780 usage 244 / 1024 (23 %); CPU: 0 %
    00> [01:02:05.430,480] <inf> thread_analyzer:       : Total CPU cycles used: 123
    00> [01:02:05.431,060] <inf> thread_analyzer:  BT_LW_WQ            : STACK: unused 628 usage 676 / 1304 (51 %); CPU: 0 %
    00> [01:02:05.431,823] <inf> thread_analyzer:       : Total CPU cycles used: 110
    00> [01:02:05.443,359] <inf> thread_analyzer:  idle                : STACK: unused 3964 usage 132 / 4096 (3 %); CPU: 98 %
    00> [01:02:05.444,000] <inf> thread_analyzer:       : Total CPU cycles used: 120322396
    00> [01:02:05.449,523] <inf> thread_analyzer:  ISR0                : STACK: unused 31636 usage 1132 / 32768 (3 %)
    00> [01:02:06.437,408] <inf> internaluart: Requisicao Status ok
    00> [01:02:06.676,513] <inf> internaluart: Requisicao LORA ok
    00> [01:02:06.805,572] <dbg> sx12xx_common: sx12xx_lora_send: Expected air time of 171 bytes = 277ms
    00> [01:02:15.450,225] <inf> thread_analyzer: Thread analyze:
    00> [01:02:15.450,683] <inf> thread_analyzer:  BT CTLR ECDH        : STACK: unused 196 usage 708 / 904 (78 %); CPU: 0 %
    00> [01:02:15.451,385] <inf> thread_analyzer:       : Total CPU cycles used: 852
    00> [01:02:15.452,453] <inf> thread_analyzer:  BT RX               : STACK: unused 3900 usage 196 / 4096 (4 %); CPU: 0 %
    00> [01:02:15.453,094] <inf> thread_analyzer:       : Total CPU cycles used: 2
    00> [01:02:15.453,735] <inf> thread_analyzer:  BT TX               : STACK: unused 996 usage 540 / 1536 (35 %); CPU: 0 %
    00> [01:02:15.454,376] <inf> thread_analyzer:       : Total CPU cycles used: 76
    00> [01:02:15.455,352] <inf> thread_analyzer:  thread_analyzer     : STACK: unused 3180 usage 916 / 4096 (22 %); CPU: 0 %
    00> [01:02:15.455,993] <inf> thread_analyzer:       : Total CPU cycles used: 818166
    00> [01:02:15.457,794] <inf> thread_analyzer:  lora_task_id        : STACK: unused 7868 usage 2372 / 10240 (23 %); CPU: 0 %
    00> [01:02:15.463,500] <inf> thread_analyzer:       : Total CPU cycles used: 56347
    00> [01:02:15.464,050] <inf> thread_analyzer:  internal_comm_task_id: STACK: unused 340 usage 684 / 1024 (66 %); CPU: 0 %
    00> [01:02:15.464,691] <inf> thread_analyzer[01:02:15.480,957] <inf> thread_analyzer:  ble_task_id         : STACK: unused 4308 usage 812 / 5120 (15 %); CPU: 0 %
    00> [01:02:15.486,663] <inf> thread_analyzer:       : Total CPU cycles used: 378423
    00> [01:02:15.487,792] <inf> thread_analyzer:  sysworkq            : STACK: unused 3676 usage 420 / 4096 (10 %); CPU: 0 %
    00> [01:02:15.488,433] <inf> thread_analyzer:       : Total CPU cycles used: 5251
    00> [01:02:15.489,044] <inf> thread_analyzer:  MPSL Work           : STACK: unused 780 usage 244 / 1024 (23 %); CPU: 0 %
    00> [01:02:15.489,715] <inf> thread_analyzer:       : Total CPU cycles used: 123
    00> [01:02:15.490,295] <inf> thread_analyzer:  BT_LW_WQ            : STACK: unused 628 usage 676 / 1304 (51 %); CPU: 0 %
    00> [01:02:15.495,971] <inf> thread_analyzer:       : Total CPU cycles used: 110
    00> [01:02:15.497,161] <inf> thread_analyzer:  idle                : STACK: unused 3964 usage 132 / 4096 (3 %); CPU: 98 %
    00> [01:02:15.497,802] <inf> thread_analyz[01:02:15.518,859] <inf> thread_analyzer:  ISR0                : STACK: unused 31636 usage 1132 / 32768 (3 %)
    00> [01:02:24.448,974] <inf> internaluart: Requisicao Status ok
    00> [01:02:24.687,347] <inf> internaluart: Requisicao LORA ok
    00> [01:02:24.816,375] <dbg> sx12xx_common: sx12xx_lora_send: Expected air time of 172 bytes = 277ms
    00> [01:02:25.519,531] <inf> thread_analyzer: Thread analyze:
    00> [01:02:25.519,989] <inf> thread_analyzer:  BT CTLR ECDH        : STACK: unused 196 usage 708 / 904 (78 %); CPU: 0 %
    00> [01:02:25.520,599] <inf> thread_analyzer:       : Total CPU cycles used: 852
    00> [01:02:25.521,697] <inf> thread_analyzer:  BT RX               : STACK: unused 3900 usage 196 / 4096 (4 %); CPU: 0 %
    00> [01:02:25.522,338] <inf> thread_analyzer:       : Total CPU cycles used: 2
    00> [01:02:25.522,949] <inf> thread_analyzer:  BT TX               : STACK: unused 996 usage 540 / 1536 (35 %); CPU: 0 %
    00> [01:02:25.523,590] <inf> thread_analyzer:       : Total CPU cycles used: 76
    00> [01:02:25.524,566] <inf> thread_analyzer:  thread_analyzer     : STACK: unused 3180 usage 916 / 4096 (22 %); CPU: 0 %
    00> [01:02:25.525,207] <inf> thread_analyzer:       : Total CPU cycles used: 820419
    00> [01:02:25.526,977] <inf> thread_analyzer:  lora_task_id        : STACK: unused 7868 usage 2372 / 10240 (23 %); CPU: 0 %
    00> [01:02:25.527,648] <inf> thread_analyzer:       : Total CPU cycles[01:02:25.543,304] <inf> thread_analyzer:  internal_comm_task_id: STACK: unused 340 usage 684 / 1024 (66 %); CPU: 0 %
    00> [01:02:25.549,072] <inf> thread_analyzer:       : Total CPU cycles used: 98023
    00> [01:02:25.550,231] <inf> thread_analyzer:  ble_task_id         : STACK: unused 4308 usage 812 / 5120 (15 %); CPU: 0 %
    00> [01:02:25.550,872] <inf> thread_analyzer:       : Total CPU cycles used: 379431
    00> [01:02:25.551,971] <inf> thread_analyzer:  sysworkq            : STACK: unused 3676 usage 420 / 4096 (10 %); CPU: 0 %
    00> [01:02:25.552,612] <inf> thread_analyzer:       : Total CPU cycles used: 5258
    00> [01:02:25.553,222] <inf> thread_analyzer:  MPSL Work           : STACK: unused 780 usage 244 / 1024 (23 %); CPU: 0 %
    00> [01:02:25.553,863] <inf> thread_analyzer:       : Total CPU cycles used: 123
    00> [01:02:25.559,570] <inf> thread_analyzer:  BT_LW_WQ            : STACK: unused 628 usage 676 / 1304 (51 %); CPU: 0 %
    00> [01:02:25.560,211] <inf> thread_anal[01:02:25.576,843] <inf> thread_analyzer:  idle                : STACK: unused 3964 usage 132 / 4096 (3 %); CPU: 98 %
    00> [01:02:25.582,550] <inf> thread_analyzer:       : Total CPU cycles used: 120972248
    00> [01:02:25.588,043] <inf> thread_analyzer:  ISR0                : STACK: unused 31636 usage 1132 / 32768 (3 %)
    00> [01:02:29.924,682] <err> lora_task: Another LoRa device was ACKed!
    00> [01:02:29.925,109] <err> os: ***** USAGE FAULT *****
    00> [01:02:29.925,476] <err> os:   Illegal load of EXC_RETURN into PC
    00> [01:02:29.925,903] <err> os: r0/a1:  0xaaaaaaaa  r1/a2:  0xaaaaaaaa  r2/a3:  0xaaaaaaaa
    00> [01:02:29.926,452] <err> os: r3/a4:  0xaaaaaaaa r12/ip:  0xaaaaaaaa r14/lr:  0xaaaaaaaa
    00> [01:02:29.927,001] <err> os:  xpsr:  0xaaaaaa00
    00> [01:02:29.927,368] <err> os: r4/v1:  0x200038b0  r5/v2:  0x20008661  r6/v3:  0x00000000
    00> [01:02:29.927,917] <err> os: r7/v4:  0x00000000  r8/v5:  0x00000000  r9/v6:  0x00000000
    00> [01:02:29.928,436] <err> os: r10/v7: 0x00000000  r11/v8: 0x00000000    psp:  0x20011c10
    00> [01:02:29.928,955] <err> os: EXC_RETURN: 0xfffffffd
    00> [01:02:29.929,351] <err> os: Faulting instruction address (r15/pc): 0xaaaaaaaa
    00> [01:02:29.929,840] <err> os: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0[0m
    00> [01:02:29.940,277] <err> os: Current thread: 0x200038f8 (idle)
    00> [01:02:29.960,571] [1;31m<err> fatal_error: Resetting system[0m
  • I can see that the "logging" threads stack size is set by CONFIG_LOG_PROCESS_THREAD_STACK_SIZE
    https://github.com/nrfconnect/sdk-zephyr/blob/v3.1.99-ncs1/subsys/logging/log_core.c#L688
    But you've already set that to a really high value, so I'm not sure what the issue might be
    • Could you check the file <sample>/build/zephyr/.config and search for CONFIG_LOG_PROCESS_THREAD_STACK_SIZE and see if it's actually set
    • Do you have any child images in your application? For example mcuboot. In that case, are you sure that the log is not coming from the child image? Then you need to set CONFIG_LOG_PROCESS_THREAD_STACK_SIZE in the mcuboot prj.conf file, and confirm the value using the file <sample>/build/mcuboot/zephyr/.config
    • Would you be able to share a minimal reproducible sample, so I can test it on my end?
    Simon
  • * CONFIG_LOG_PROCESS_THREAD_STACK_SIZE = 65536 (I've changed it, and checked it in the build/zephyr/.config file, it keeps the value that I set).
    * Child images - Yes, I have MCUBoot enabled in my Application prj.conf file. I can see in the build/mcuboot/zephyr/.config file that CONFIG_MCUBOOT_LOG_THREAD_STACK_SIZE=768. Though there is no CONFIG_LOG_PROCESS_THREAD_STACK_SIZE. I haven't seen any log in the RTT viewer related to the MCUBoot, so I am not sure if MCUBoot is really logging anything during application runtime. Anyway, how could I change CONFIG_MCUBOOT_LOG_THREAD_STACK_SIZE?
    * I can see that MCUBoot has CONFIG_PRINTK enabled, might that be an issue? I've seen some issues in Zephyr's Github repository that it's not good to use both printk and LOG. But since I am new to Zephyr, I can't really confirm this.
    * Minimal reproducible sample - I'll try to prepare this. In the meantime, any other suggestions / tryouts?
  • Hello and sorry for the late reply,
    I'm not sure what the issue might be then.
    I've asked internally
    Simon
  • I got some useful input internally
    When the sentinel check fails, it means that the sentinel (magic) value is overwritten, it is not the sentinel function itself that is the issue. It does not seem like it is the logging thread, so maybe some other thread is writing out of bounds. Try placing a data write breakpoint on the sentinel location (stack start) and check what code overwrites it.
    You can also use THREAD_ANALYZER and other related Kconfig to auto print the stack usage every few seconds, and if any thread is missing from its list, the thread has likely overflowed by a huge amount and corrupting many thread stacks.
    Simon
