not able to send more the 20 bytes using bt_gatt_notify api
i am using SDK 1.9.1 to notify data  to peripheral to central device i am using ''bt_gatt_notify " api to send data to mobile but i am able to send only 20 bytes data to central device ,but my requirement i am getting packets from MCU  with 240 bytes each pkt ,but i am not able to transmit full pkt once data i am splitting the pkt 20 bytes  and sending but the requirement is need to send pkt by pkt continually please help to solve the problem.
    We usually refer to our throughput sample found in ncs\nrf\samples\bluetooth\throughput. However, there are a lot of configs from the prj.conf file in that sample.
    madhurubharath said:
    please suggest any other method  to transmit data
    You still want to use that API, but you want to ensure that you actually have a higher MTU. Please check this ticket for more info on how to increase the MTU size in a connection.
    Edvin
  • APP FILE:
    uint8_t TM_u8SendData_central_dev(tm_u8_t *BT_rx_data,uint16_t rxbuflen)
       int tm_status=0,Ack_len,nty_count=0,ble_tx_size=0;
       ble_buff_len=rxbuflen;
       uart_irq_rx_enable(uartDev);
       char AckMent[11];
       char buff_size[20];
       if(tm_flag == 1)
        size_t size=0, SendLen=0;
        char *sPtr= BT_rx_data;
        tm_status=bt_gatt_notify(NULL, &ccbg_serv.attrs[1], sPtr ,ble_buff_len);
        if(tm_status == 0)
          Ack_len = sprintf(AckMent,"{\"ack\":[0]}");
          UARTQueueData(&AppInstance.UartQTx, uartDev,AckMent,Ack_len);
          sprintf(buff_size,"pkt_data_size:%d",ble_buff_len);
          UARTQueueData(&AppInstance.UartQTx, uartDev,buff_size,sizeof(buff_size));
          return 0;
          Ack_len = sprintf(AckMent,"{\"ack\":[-1]}");
          return -1;
    prj.config:
    CONFIG_BT_BUF_ACL_RX_SIZE=251
    CONFIG_BT_L2CAP_TX_MTU=247
    CONFIG_BT_BUF_ACL_TX_SIZE=251
    CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
    this is my configuration code:
    if i transmitt more then 20 bytes its returning -1
    please help me to solve this issue
    regards,
    bharath.m
  • hello edvin,
    thank you for quick response,
    still i ma facing same issue with bt_gatt_notify API.
    still am getting return type"-128" from "tm_status=bt_gatt_notify"   if i send 20 bytes it successfully notifying the data.   any other configuration need to change?
    regards,
    bharath
  • Did you call bt_gatt_exchange_mtu(), like it is done in the throughput example found in ncs\nrf\samples\bluetooth\throughput?
    And also, I see that you are using bt_gatt_notify(NULL, &ccbg_serv.attrs[1], sPtr ,ble_buff_len); that is, without the connection handle. Can you please try to use the connection handle instead of NULL when you are trying to send the data? I suspect that when you don't specify a specific connection, you can't use an MTU larger than the default MTU size. At least it is a quick check whether it works changing that.
    Edvin
