Tools for production programming nRF53 FLASH and external QSPIFLASH
We are starting to work on a production tester which will need to program a DUT based on the nRF5340.  Both cores will need to be programmed and an external QSPIFLASH memory.  Our current methods for programming during development have been to use the nrfjprog tool and the qspiloader.py Python script with the Segger JLINK emulator.  The QSPIFLASH on the DUT is powered from a switched +3V supply requiring some micro pin preinitialization code to run on the micro to enable the supply.  Is it possible to preconfigure the micro using nrfjprog?  What tool do you suggest using for programming QSPIFLASH using the Segger JLINK?
Thanks
