I am currently developing a project using ultrasonic sensor for measuring level. So I was migrating library from development kit to nrf sdk code. I am using Keil uVision to develop the code.
So in my case, there are 2 structs that connected together in the library and 1 is list-of typedef that using those structs.
This is the first typedef.
//! API function pointer typedefs. typedef uint8_t (*ch_fw_load_func_t)(ch201_device *dev_ptr); typedef uint8_t (*ch_get_config_func_t)(ch201_device *dev_ptr, ch_config_t *config_ptr); typedef uint8_t (*ch_set_config_func_t)(ch201_device *dev_ptr, ch_config_t *config_ptr); typedef uint8_t (*ch_set_mode_func_t)(ch201_device *dev_ptr, ch_mode_t mode); typedef uint8_t (*ch_set_sample_interval_func_t)(ch201_device *dev_ptr, uint16_t sample_interval); typedef uint8_t (*ch_set_num_samples_func_t)(ch201_device *dev_ptr, uint16_t num_samples); typedef uint8_t (*ch_set_max_range_func_t)(ch201_device *dev_ptr, uint16_t max_range); typedef uint8_t (*ch_set_static_range_func_t)(ch201_device *dev_ptr, uint16_t static_range); typedef uint32_t (*ch_get_range_func_t)(ch201_device *dev_ptr, ch_range_t range_type); typedef uint16_t (*ch_get_amplitude_func_t)(ch201_device *dev_ptr); typedef uint32_t (*ch_get_frequency_func_t)(ch201_device *dev_ptr); typedef uint8_t (*ch_get_iq_data_func_t)(ch201_device *dev_ptr, ch_iq_sample_t *buf_ptr, uint16_t start_sample, uint16_t num_samples, ch_io_mode_t io_mode); typedef uint16_t (*ch_samples_to_mm_func_t)(ch201_device *dev_ptr, uint16_t num_samples); typedef uint16_t (*ch_mm_to_samples_func_t)(ch201_device *dev_ptr, uint16_t num_mm); typedef uint8_t (*ch_set_thresholds_func_t)(ch201_device *dev_ptr, ch_thresholds_t *thresh_ptr); typedef uint8_t (*ch_get_thresholds_func_t)(ch201_device *dev_ptr, ch_thresholds_t *thresh_ptr);
This is the first struct
//! Chirp sensor device structure.
typedef struct ch201_device {
ch_mode_t mode;
uint16_t max_range;
uint16_t static_range;
uint16_t sample_interval;
uint16_t rtc_cal_result;
uint32_t op_frequency;
uint16_t bandwidth;
uint16_t scale_factor;
uint8_t i2c_address;
uint8_t app_i2c_address;
uint16_t i2c_drv_flags;
uint16_t part_number;
int8_t oversample;
uint8_t sensor_connected;
uint8_t io_index;
uint8_t i2c_bus_index;
uint16_t max_samples;
uint16_t num_rx_samples;
uint32_t rtc_cal_pulse_ms;
const char *fw_version_string;
const uint8_t *firmware;
const uint8_t *ram_init;
void (*prepare_pulse_timer)(struct ch201_device *dev_ptr);
void (*store_pt_result)(struct ch201_device *dev_ptr);
void (*store_op_freq)(struct ch201_device *dev_ptr);
void (*store_bandwidth)(struct ch201_device *dev_ptr);
void (*store_scalefactor)(struct ch201_device *dev_ptr);
uint8_t (*get_locked_state)(struct ch201_device *dev_ptr);
uint16_t (*get_fw_ram_init_size)(void);
uint16_t (*get_fw_ram_init_addr)(void);
ch_api_funcs_t api_funcs;
} ch201_device;
This is the second struct
typedef struct {
ch_fw_load_func_t fw_load;
ch_set_mode_func_t set_mode;
ch_set_sample_interval_func_t set_sample_interval;
ch_set_num_samples_func_t set_num_samples;
ch_set_max_range_func_t set_max_range;
ch_set_static_range_func_t set_static_range;
ch_get_range_func_t get_range;
ch_get_amplitude_func_t get_amplitude;
ch_get_frequency_func_t get_frequency;
ch_get_iq_data_func_t get_iq_data;
ch_samples_to_mm_func_t samples_to_mm;
ch_mm_to_samples_func_t mm_to_samples;
ch_set_thresholds_func_t set_thresholds;
ch_get_thresholds_func_t get_thresholds;
} ch_api_funcs_t;
In keil, I have to put the position for definitions first. But as you can see each part is connected at all. I mean in the list-of-typedef, it is calling each item on the first struct. In the first struct, it is calling several item in second struct.
Do you have any idea to arrange this position or is there any configuration so I don't have to do this allignment? because I thought in OOP, arrangement doesn't matter for definition.
Thanks.
