Power Profiler Kit II: source voltage (VCC) higher than recommended
I am currently using the PPK2 for current measurements.
According to the datasheet, the PPK2 supports a maximum source voltage of 5 volts. However, my device requires a bit more (about 5.2-5.4 volts). I tried it anyway and things work as they should.
But now I wondered if there could be an effect on the measured values. Are such effects known? Should I still use the PPK2?
Kevin
