nRF Cloud - Not able to connct to it.
I'm currently using an nRF9160DK with an NB-IoT sim, and the problem I am currently having is that I cannot establish a connection with the nRF cloud.
What have I tried?
1. I tried the following: https://infocenter.nordicsemi.com/pdf/nRF9160_DK_Getting_Started_Guide_v1.1.pdf section "Provisioning the nRF Connect for Cloud certificate" by opening the nRF connect, deselecting automatic requests, removed the sim card, entering AT+CFUN?4 to put the modem to offline state (and checked the state of the modem to ensure that it is off). I have loaded the JSON certificate and ensured that the security tag is set to "16842753" and then updated the certificate. The log message states "certificate updated completed.
2. Then I tried to power cycle the nRF9160DK and then inserted the SIM card to let the automatic requests run. It seems like it tries to connect to the nRF cloud but fails. I am not quite sure why this happens.
3. I also tried to add the LTE device to the nRF connection, but this was not working
The image that I have flashed to the board is nrf9160dk_asset_tracker_v2_nbiot_2022-06-02_880c82db.
Additional things that I have tried
1. The SIM card supports NB-IoT, and there is coverage within my area.
3. I have tried another NB-IoT-supported IoT device to test out the sim card by doing a ping test to ensure that the connectivity is not the problem, and this seems to work fine.
4. It seems like the nRF9160DK is able to connect to the eNB, and connect to the network, so that is not the problem. It seems to receive an IP address successfully, so this is not a problem.
3. I have tried to re-flash the nRF9160DK
  • Hey,
    Thanks for reaching back to me.
    I have attempted to ping 8.8.8.8, and it did not appear to be an issue, therefore I do not believe that connectivity is an issue. I'd also like to highlight that I have tried another microcontroller that supports NB-IoT to confirm that the setup is operating properly.
    I'm currently running nrf9160dk_asset_tracker_v2_nbiot_2022-06-02_880c82db.hex which is flashed to the microcontroller.
    You also mentioned an IBasis sim card; however, there is no coverage in my city, only in another city, so I don't believe that will work. Regarding a local SIM card, I do not have one to test.
    Thanks.
  • We will need to see a modem trace in order to verify if the issue is in the nRF9160. Can you please provide .bin file from the trace collector?
    What test setup are you connecting to? Are you working with a CMW500 or similar? Please procure a SIM from a local vendor to verify that your device is actually working. Where are you based? From the logs you provided I am assuming Norway. Please contact Telenor or Telia for an NB-IoT SIM.
    From the logs e.g.
    modem_info_params: Link data not obtained: 20 -5
    This indicates that there is an issue with the network connection. What other microcontroller did you test with?
  • Also, please provide full .pcap along with modem trace
  • I'll have to check that out. Regarding the modem trace, I am looking at the documentation right now, Is it possible to run the LTE link monitor and the modem tracer simultaneously?
    No, but it is quite similar. I'll try to see if I can get a local NB-IoT sim card for testing. In terms of the other microcontroller, it is one with a BG96 modem. (Not Nordic).
    If it is indeed the network connection, I will need to investigate further. Previously, I mentioned that when it connected to the network, attempted to establish a connection to the cloud, and then failed, it would automatically disconnect from the network.
    Thanks for the help so far.
    Yes, this is possible. The modem trace uses it's own UART port. You can program the nrf9160dk_asset_tracker_v2_debug_nbiot_2022-06-02_880c82db.hex, which has modem trace enabled.
    After doing that you can open Trace Collector v2 from nRF Connect for Desktop
    After clicking start, make sure to reset you nRF9160DK, then you should see the size of the file increase as it tries to connect.
    Please note that BG96 is not the same as nRF9160 as the latter does not support EDGE and GPRS. Did you verify that you connected via NB-IoT and not EDGE or GRPS?
    As you are on a test network, please verify your setup in the gateway.
