I've created the samples for Socket Echo Client https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.0.2/zephyr/samples/net/sockets/echo_client/README.html#sockets-echo-client-sample
and Socket Echo Server https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.0.2/zephyr/samples/net/sockets/echo_server/README.html#sockets-echo-server-sample
I've done this as a starting point to try and get BLE and native 802.15.4 working with our existing devices. Using https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.0.2/nrf/samples/nrf5340/multiprotocol_rpmsg/README.html#multiprotocol-rpmsg-sample is my plan eventually, but because the multiple images section is currently confusing me I'm just using the echo samples.
I have two nrF5340 DKs for the client I've built it with the overlay-802154.conf, for the server I have built it with the overlay-802154.conf and overlay-bt.conf
The server runs on it's own, but when the client is switched on it crashes:
uart:~$ *** Booting Zephyr OS build v3.1.99-ncs1 ***
[00:00:00.264,038] <inf> ieee802154_nrf5: nRF5 802154 radio initialized
[00:00:00.266,479] <wrn> net_if: You have 1 IPv6 net_if addresses but 2 network interfaces
[00:00:00.266,510] <wrn> net_if: Consider increasing CONFIG_NET_IF_MAX_IPV6_COUN T value.
[00:00:00.308,563] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:00:00.308,563] <inf> bt_hci_core: HW Variant: nRF53x (0x0003)
[00:00:00.308,593] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0 x00) Version 242.24551 Build 4087489391
[00:00:00.313,049] <inf> bt_hci_core: Identity: CB:43:E9:71:1B:D9 (random)
[00:00:00.313,049] <inf> bt_hci_core: HCI: version 5.3 (0x0c) revision 0x21a7, m anufacturer 0x0059
[00:00:00.313,079] <inf> bt_hci_core: LMP: version 5.3 (0x0c) subver 0x21a7
[00:00:00.316,833] <inf> net_config: Initializing network
[00:00:00.425,842] <inf> net_config: IPv6 address: 2001:db8::1
[00:00:00.426,086] <inf> net_echo_server_sample: Run echo server
[00:00:00.426,116] <inf> net_echo_server_sample: Waiting network to be connected
uart:~$
[00:00:09.739,410] <err> os: ***** USAGE FAULT *****
[00:00:09.739,440] <err> os: Stack overflow (context area not valid)
[00:00:09.739,471] <err> os: r0/a1: 0xaaaaaaaa r1/a2: 0xaaaaaaaa r2/a3: 0x0003ff54
[00:00:09.739,471] <err> os: r3/a4: 0x01000000 r12/ip: 0x00000001 r14/lr: 0x00000000
[00:00:09.739,471] <err> os: xpsr: 0x00000000
[00:00:09.739,501] <err> os: Faulting instruction address (r15/pc): 0x00000000
[00:00:09.739,501] <err> os: >>> ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0
[00:00:09.739,532] <err> os: Current thread: 0x20004040 (rx_q[0])
[00:00:09.820,648] <err> fatal_error: Resetting system
I'm not sure why this is crashing. I've built the client on a nrF52840 as well and the server still crashes. I have made no edits to any of the code.
