Zigbee Stack interference with TWIM
During development, I am seeing a strange behavior when enabling zigbee.
When the application's PRJ file does not enable zigbee, I2C functions as expected. The peripherals can be read and responses are received (as shown in the attached picture)
Without the zigbee/networking processor active, this is what things look like in yellow below:
1. Raising edge I2C transaction started
2. Falling edge I2C transaction completed
The purple  line indicates edges (falling and raising) are a trigger to start an I2C transaction
PRJ.conf (zigbee not enabled)
CONFIG_FPU=y
CONFIG_SERIAL=y
CONFIG_EVENTS=y
CONFIG_I2C=y
CONFIG_NEWLIB_LIBC=y
CONFIG_AUDIO=y
CONFIG_CMSIS_DSP=y
CONFIG_CMSIS_DSP_TRANSFORM=y
CONFIG_AUDIO_DMIC=y
CONFIG_NRFX_TIMER1=y
CONFIG_MPU_ALLOW_FLASH_WRITE=y
CONFIG_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_JESD216_API=y
CONFIG_SPI=n
CONFIG_SPI_NOR=n
CONFIG_NORDIC_QSPI_NOR=y
CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
CONFIG_FILE_SYSTEM=y
CONFIG_FILE_SYSTEM_LITTLEFS=y
#CONFIG_APP_WIPE_STORAGE=y
CONFIG_APP_LITTLEFS_STORAGE_FLASH=y
# CONFIG_LOG=y
# CONFIG_LOG_BACKEND_UART=n
# CONFIG_LOG_MODE_MINIMAL=y
# CONFIG_LOG_DEFAULT_LEVEL=0
CONFIG_HEAP_MEM_POOL_SIZE=8192
CONFIG_REBOOT=y
When Zigbee configurations are enabled (w/o even initializing Zboss) All comms on i2c3 time out.
CONFIG_FPU=y
CONFIG_SERIAL=y
CONFIG_EVENTS=y
CONFIG_I2C=y
CONFIG_AUDIO=y
CONFIG_AUDIO_DMIC=y
CONFIG_HEAP_MEM_POOL_SIZE=32768
CONFIG_ZIGBEE=y
CONFIG_ZIGBEE_APP_UTILS=y
CONFIG_ZIGBEE_ROLE_END_DEVICE=y
# Enable DK LED and Buttons library
CONFIG_DK_LIBRARY=y
# This example requires more workqueue stack
# Enable API for powering down unused RAM parts
CONFIG_RAM_POWER_DOWN_LIBRARY=y
# Networking
CONFIG_NET_IPV6_MLD=n
CONFIG_NET_IPV6_NBR_CACHE=n
CONFIG_NET_IPV6_RA_RDNSS=n
CONFIG_NET_IP_ADDR_CHECK=n
CONFIG_NET_UDP=n
CONFIG_LOG=y
CONFIG_LOG_DEFAULT_LEVEL=1
CONFIG_IEEE802154_DRIVER_LOG_LEVEL_INF=y
CONFIG_NRF53_SYNC_RTC=n
CONFIG_ASSERT=y
CONFIG_SPIN_VALIDATE=y
CONFIG_LOG_MODE_MINIMAL=n
CONFIG_MAIN_STACK_SIZE=2048
# Use software cryptography on nRF5340
CONFIG_ZIGBEE_USE_SOFTWARE_AES=y
# Networking
CONFIG_MPSL=n
CONFIG_NUM_COOP_PRIORITIES=20
CONFIG_NUM_PREEMPT_PRIORITIES=30
CONFIG_CMSIS_DSP=y
CONFIG_AUDIO_DMIC=y
CONFIG_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_SPI=n
CONFIG_SPI_NOR=n
# CONFIG_LOG=y
CONFIG_REBOOT=y
Is there a known interaction between zigbee and I2C that prevents all I2C peripherals from bein used?
  • I see.
    What NCS version are you using btw?
    And could you again try changing the i2c instance and see if you still face the same issue? And could you provide a minimal example that would reproduce this on a DK?
    Elfving
  • > could you again try changing the i2c instance and see if you still face the same issue?
    I don't follow this request. All of the I2C instances are being used by other I2C peripherals and therefore I'd effectively be moving the problem from one peripheral to the other. Am I misunderstanding your request?
    I don't currently have a a project/example that can run on the dev-kit. I can try to slim down the project and create a configuration that runs on a dev-kit.
    However I'd like to repeat that I can see this issue disappear by simply removing the kconfig settings related to the zigbee stack which leads me to believe it's a network core configuration/inclusion issue
    Right, though moving the issue around is not the goal - I just want to see if that is indeed what happens.
    Thank you, that would be great.
    Elfving
  • Here is a very crude and quick example showing how I have i2c 3 working with a Zigbee light bulb sample. This project is from NCS 2.1.2.
    zigbee_light_bulb_i2c3_scaner_nrf5340dk_cpuapp.zip
    Is it showing you the same issues on your side?
    Note the configs that are enabled in this sample, can you get your project working with only these enabled?
    Which NCS version where you using again?
    Elfving
