Inaccurate synthesized LF clock
During the validation of our device, we found that the RTC (synthesized from HFCLK) was quite a bit off. Instead of the expected 32.768kHz, we measured 33.047kHz.
Do you know if we made a mistake somewhere in our tests or RTC configurations?
Hardware:
  • MCU: nRF52833 QDAAA0
  • HFCLK: External 32MHz clock, tolerance: 10ppm, stability: 15ppm
  • LFCLK: Synthesized from HF clock
Firmware:
Connect RTC to GPIOTE output with PPI. On every RTC tick, toggle a GPIO.
  • NCS version: V2.1.0
  • RTC settings:
    • RTC inst: RTC2
    • RTC configs: default config (pre-scaler: 0, reliable: false)
    • Frequency: 32768
  • GPIOTE setting
    • Pin: 1.09
    • Drive: H0H1
    • Input connect: disconnect
    • pull: no-pull
  • Relevant setting:
    • CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH=y
Test setup:
The device toggles its pin every RTC pin, which creates a square wave with a frequency of LFCLK/2 (target: 16.384kHz). A frequency counter measures this signal for one hour. The frequency of the RTC is double the measured frequency.
Test result:
We measured a frequency of 16.5237 kHz, which means that the RTC has a frequency of 33.0474kHz. The frequency deviation from this signal is 297.4Hz or 8527ppm. This deviation is much higher than expected.
  • Do you know what could have caused this issue?
  • Did we make a mistake in our LFCLK settings?
  • Did we make a mistake in our test?
With kind regards,
Tim
