\examples\peripheral\UART code not working on BT832x module custom board (RX - P0.12, TX - P0.11)
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include "app_uart.h"
#include "app_error.h"
#include "nrf_delay.h"
#include "nrf.h"
#include "bsp.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
//#define ENABLE_LOOPBACK_TEST  /**< if defined, then this example will be a loopback test, which means that TX should be connected to RX to get data loopback. */
#define MAX_TEST_DATA_BYTES     (15U)                /**< max number of test bytes to be used for tx and rx. */
#define UART_TX_BUF_SIZE 256                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256                         /**< UART RX buffer size. */
void uart_error_handle(app_uart_evt_t * p_event)
    if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
    else if (p_event->evt_type == APP_UART_FIFO_ERROR)
#ifdef ENABLE_LOOPBACK_TEST
/* Use flow control in loopback test. */
#define UART_HWFC APP_UART_FLOW_CONTROL_ENABLED
/** @brief Function for setting the @ref ERROR_PIN high, and then enter an infinite loop.
static void show_error(void)
    bsp_board_leds_on();
    while (true)
        // Do nothing.
/** @brief Function for testing UART loop back.
 *  @details Transmitts one character at a time to check if the data received from the loopback is same as the transmitted data.
 *  @note  @ref TX_PIN_NUMBER must be connected to @ref RX_PIN_NUMBER)
static void uart_loopback_test()
    uint8_t * tx_data = (uint8_t *)("\r\nLOOPBACK_TEST\r\n");
    uint8_t   rx_data;
    // Start sending one byte and see if you get the same
    for (uint32_t i = 0; i < MAX_TEST_DATA_BYTES; i++)
        uint32_t err_code;
        while (app_uart_put(tx_data[i]) != NRF_SUCCESS);
        nrf_delay_ms(10);
        err_code = app_uart_get(&rx_data);
        if ((rx_data != tx_data[i]) || (err_code != NRF_SUCCESS))
            show_error();
    return;
#else
/* When UART is used for communication with the host do not use flow control.*/
#define UART_HWFC APP_UART_FLOW_CONTROL_DISABLED
    uint32_t err_code;
    const app_uart_comm_params_t comm_params =
          RX_PIN_NUMBER,
          TX_PIN_NUMBER,
          RTS_PIN_NUMBER,
          CTS_PIN_NUMBER,
          UART_HWFC,
          false,
          NRF_UART_BAUDRATE_115200
#else
          NRF_UARTE_BAUDRATE_115200
                         UART_RX_BUF_SIZE,
                         UART_TX_BUF_SIZE,
                         uart_error_handle,
                         APP_IRQ_PRIORITY_LOWEST,
                         err_code);
#ifndef ENABLE_LOOPBACK_TEST
    printf("\r\nUART example started.\r\n");
    while (true)
        uint8_t cr;
        while (app_uart_get(&cr) != NRF_SUCCESS);
        while (app_uart_put(cr) != NRF_SUCCESS);
        if (cr == 'q' || cr == 'Q')
            printf(" \r\nExit!\r\n");
            while (true)
                // Do nothing.
#else
    // This part of the example is just for testing the loopback .
    while (true)
        uart_loopback_test();
Above is the code that im using.
Module - BT832x
Debugger - Segger J-link
IDE - Segger IDE
SDK - nRF5_SDK_17.0.2_d674dde (Downloaded from nordic website)
Program used - \nRF5_SDK_17.0.2_d674dde\examples\peripheral\uart\pca10040\blank\ses\uart_pca10040
TXD pin - P0.11 (BT832x module)
RXD pin - P0.12 (BT832x module)
The UART example SDK code uses #define RX_PIN_NUMBER 8 and #define TX_PIN_NUMBER 6 but in my custom board Im using TX pin as P0.11 and RXD as P0.12.
So I changed the Pin numbers as 12 and 11 in the pca10040.h and tried executing the UART doesnt responds.
Then I tried to change in the main.c under "const app_uart_comm_params_t comm_params" as well its still not responding.
Is there anything else am I missing ? Please help me out. Im totally new to nRF.
Below is the schematics for the BT832x module.
Thank you in advance
