ble_nus_data_send sending the wrong data
I am writing a program that sends numbers counting up sequentially from my dev board to my phone on 500ms intervals. I used the ble_app_uart example as my base. I am trying to use the command ble_nus_data_send(&m_nus, up_counter, &length, m_conn_handle); to send the data to my phone. When I start the process, I can successfully send the string "Counting up." to my phone, but the counting numbers do not display properly. Instead, some unreadable text shows up on my phone; it looks like a problem when a device cannot interpret an ascii code. Does anyone know why I might be encountering this problem? For reference, my code and a screenshot of the output are posted below; the problem is on line 903.
 * Copyright (c) 2014 - 2021, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup ble_sdk_uart_over_ble_main main.c
 * @ingroup  ble_sdk_app_nus_eval
 * @brief    UART over BLE application main file.
 * This file contains the source code for a sample application that uses the Nordic UART service.
 * This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include <time.h>
#include "nrf_delay.h"
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
//#include "app_scheduler.h"
#include "nrf_drv_clock.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_cli.h"
#include "nrf_cli_rtt.h"
#include "nrf_cli_types.h"
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
#define UP_HIGH_LIM 255
#define UP_LOW_LIM 0
#define UP_DELAY_TIME 50
#define DN_HIGH_LIM 1000
#define DN_LOW_LIM 1
#define DN_DELAY_TIME 500
#define DELAY_TIME 500
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
APP_TIMER_DEF(m_repeated_timer_id);
APP_TIMER_DEF(m_single_shot_timer_id);
uint8_t timer_flag = 0;
static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
/**@brief Function for assert macro callback.
 * @warning This handler is an example only and does not fit a final product. You need to analyse
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for initializing the timer module.
static void timers_init(void)
/**@brief Function starting the internal LFCLK oscillator.
 * @details This is needed by RTC1 which is used by the Application Timer
 *          (When SoftDevice is enabled the LFCLK is always running and this is not needed).
static void lfclk_request(void)
    ret_code_t err_code = nrf_drv_clock_init();
/**@brief Timeout handler for the repeated timer.
static void repeated_timer_handler(void * p_context)
    //nrf_drv_gpiote_out_toggle(LED_1);
    //nrf_delay_ms(500);
    //app_timer_stop(m_repeated_timer_id);
    //timer_flag = 1;
    count_up();
/**@brief Timeout handler for the single shot timer.
static void single_shot_timer_handler(void * p_context)
    //nrf_drv_gpiote_out_clear(LED_2);
    timer_flag = 1;
/**@brief Create timers.
static void create_timers()
    ret_code_t err_code;
    // Create timers
    err_code = app_timer_create(&m_repeated_timer_id,
                                APP_TIMER_MODE_REPEATED,
                                repeated_timer_handler);
 *          the device. It also sets the permissions and appearance.
APP_SCHED_INIT(SCHED_MAX_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
    uint32_t                err_code;
                                          strlen(DEVICE_NAME));
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_evt       Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
    NRF_LOG_DEBUG("NUS data handler.");
    uint8_t data_array[BLE_NUS_MAX_DATA_LEN];
    uint8_t b[BLE_NUS_MAX_DATA_LEN];
        uint32_t err_code;
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
            //b[i] = app_uart_get(&data_array[i]);
            do
                err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
            } while (err_code == NRF_ERROR_BUSY);
        if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
            while (app_uart_put('\n') == NRF_ERROR_BUSY);
        if((memcmp(p_evt->params.rx_data.p_data,"0x01", p_evt->params.rx_data.length) == 0))
            NRF_LOG_DEBUG("Sending response.");
            char a[BLE_NUS_MAX_DATA_LEN] = "Counting up.";
            int length = BLE_NUS_MAX_DATA_LEN;
            ble_nus_data_send(&m_nus, a, &length, m_conn_handle);
            uint32_t time_err_code;
            static uint32_t timeout = 0;
            NRF_LOG_DEBUG("TX data ready.");
            for(int i = 0; i <= 255; ++i)
                timeout += 500;
                time_err_code = app_timer_start(m_repeated_timer_id, APP_TIMER_TICKS(timeout), NULL);
                //count_up((uint8_t *)i);
        }else if((memcmp(p_evt->params.rx_data.p_data,"0x02", p_evt->params.rx_data.length) == 0))
            char a[BLE_NUS_MAX_DATA_LEN] = "Counting down.";
            //ble_nus_data_send(&m_nus, a, &length, m_conn_handle);
    uint32_t           err_code;
    ble_nus_init_t     nus_init;
    // Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
    uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
    // Prepare wakeup buttons.
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
volatile uint8_t m_last_successful_conn_handle = 0;
    uint32_t err_code;
    NRF_LOG_INFO("BLE event handler.");
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            NRF_LOG_INFO("Disconnected");
        /*case BLE_GATTS_EVT_HVN_TX_COMPLETE:
                timeout += 500;
        } break;*/
            NRF_LOG_INFO("PHY update request.");
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
            // Pairing not supported
            NRF_LOG_INFO("Pairing not supported.");
            NRF_LOG_INFO("No system attributes have been stored.");
        case BLE_GATTC_EVT_TIMEOUT:
            NRF_LOG_INFO("Timeout from client.");
        case BLE_GATTS_EVT_TIMEOUT:
            NRF_LOG_INFO("Timeout from server.");
            // No implementation needed.
/**@brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                  p_gatt->att_mtu_desired_central,
                  p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
 * @param[in]   event   Event generated by button press.
    uint32_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        case BSP_EVENT_WHITELIST_OFF:
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
    static uint8_t index = 0;
    uint32_t       err_code;
    NRF_LOG_INFO("UART event handler.");
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            NRF_LOG_INFO("Data is ready.");
            index++;
            if ((data_array[index - 1] == '\n') ||
                (data_array[index - 1] == '\r') ||
                (index >= m_ble_nus_max_data_len))
                if (index > 1)
                    do
                    } while (err_code == NRF_ERROR_RESOURCES);
                index = 0;
            NRF_LOG_INFO("App UART communicatino error.");
        case APP_UART_FIFO_ERROR:
            NRF_LOG_INFO("App UART FIFO error.");
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = NRF_UART_BAUDRATE_115200
#else
        .baud_rate    = NRF_UARTE_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
    ble_advertising_init_t init;
    init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
        nrf_pwr_mgmt_run();
static void cli_process(void)
#if CLI_OVER_USB_CDC_ACM
    nrf_cli_process(&m_cli_cdc_acm);
#if CLI_OVER_UART
    nrf_cli_process(&m_cli_uart);
    nrf_cli_process(&m_cli_rtt);
void write_response(char message);
void count_up(void);
static void count_dn();
    if (message == '0x01')
        count_up();
    }else if (message == '0x02')
        count_dn();
    }else
        printf("%c\n", message);
        NRF_LOG_INFO("Your message is: %c",message);
void count_up(void)
    for(int i = UP_LOW_LIM; i <= UP_HIGH_LIM; ++i)
        NRF_LOG_DEBUG("%d", i);
        sleep(2);
    for(int i = DN_HIGH_LIM; i >= UP_LOW_LIM; --i)
        printf("%d", i);
        //delay(DN_DELAY_TIME);
void delay(int number_of_milliseconds);
    // Storing start time
    clock_t start_time = clock();
    // looping while required time is not achieved
    while(clock() < start_time + number_of_milliseconds)
void count_up();
uint8_t up_counter = 0;
void count_up()
    ble_conn_state_conn_handle_list_t conn_handles = ble_conn_state_periph_handles();
    uint32_t err_code;
    //uint32_t time_err_code;
    //static uint32_t timeout = 0;
    for (uint8_t i=m_last_successful_conn_handle; i<conn_handles.len; i++)
        err_code = ble_nus_data_send(&m_nus, up_counter, &length, m_conn_handle);
        NRF_LOG_DEBUG("%d", up_counter);
        if(err_code == NRF_SUCCESS)
            m_last_successful_conn_handle++;
        else if (err_code == NRF_ERROR_RESOURCES)
            // Queue is full. Break the loop, and countinue with the m_last_successful_conn_handle after TX_COMPLETE
    if (m_last_successful_conn_handle == conn_handles.len)
    if(up_counter == 255)
        up_counter == 0;
    } else
        up_counter++;
/**@brief Application main function.
    bool erase_bonds;
    // Initialize.
    uart_init();
    log_init();
    timers_init();
    lfclk_request();
    create_timers();
    //app_sched_execute();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    // Start execution.
    advertising_start();
    // Enter main loop.
    for (;;)
        idle_state_handle();
        if(timer_flag)
            // Run code previously in timeout handler
            //timer_flag = 0;
Thank you
    Your up_counter is an uint8_t, starting from 0. So you are sending raw numbers, not ascii characters. When the receiver prints these as if they were ascii characters, that will result in a lot of strange charcters and is expected. I assume what you want to do is send an ascii representatnion of th enumber? If so, use snprintf() or itoa() or similar to convert it to a string before sending it with ble_nus_data_send().
  • Thank you for answering. I have tried to implement the itoa function, but it doesnt seem to be working. The output to my phone still looks the same. I even tried to look at the output in the debugger, and it's also incorrect. I posted my code and the debugger output below. Do you see whether I did something wrong?
    void count_up();
    int up_counter = 0;
    void count_up()
        uint32_t err_code;
        char counter_char[sizeof(int)*8+1];
            itoa(up_counter, counter_char, 10);
            NRF_LOG_DEBUG("Converted String: %c", counter_char);
            err_code = ble_nus_data_send(&m_nus, counter_char, &length, m_conn_handle);
            up_counter == 0;
        } else
            up_counter++;
    Thank you.
    Edit: removed a line from the code that was obviously wrong. The output is still the same, unfortunately.
  • I think I have it solved now. In the line ble_nus_data_send(&m_nus, counter_char, &length, m_conn_handle), length was set to BLE_NUS_MAX_DATA_LEN, which is some large number. I set length to 4 (the program should terminate before the counter reaches 1000), and the output is correct as far as I know. My code is posted below for reference.
    void count_up();
    volatile int up_counter = 0;
    void count_up()
        //int length = BLE_NUS_MAX_DATA_LEN;
        int length = 4;
        uint32_t err_code;
        char counter_char[20];
            //NRF_LOG_DEBUG("Integer: %d   Converted String: %c\n", up_counter, counter_char);
            //err_code = ble_nus_data_send(&m_nus, up_counter, &length, m_conn_handle);
            up_counter == 0;
        } else
            up_counter++;
    Thank you for your help.
