nRF9160 - Modem Delta Firmware Update V1.3.3 - Modem error 22
I am currently developing an LTE/LwM2M application on a custom board using the nRF9160 and NCS version 2.1.0.We are almost finished with our application and the final open milestone is the modem firmware update implementation.
I used the "http_update/full_modem_update" sample and the "http_update/modem_delta_update example" as a starting point to implement both options for the modem update, however I am updating the firmware over LWM2M instead of HTTP. I first got the FMFU working using external flash, then I started working on the delta updates, expecting it would be far easier, however I ran into some errors. The modem firmware is currently updated to the latest version (1.3.3) and I am trying to update the firmware using the delta image "mfw_nrf9160_update_from_1.3.3_to_1.3.3-FOTA-TEST.bin". As can be seen in the image below, the write operation failed with the error code 22. I've look up this error code: "NRF_MODEM_DELTA_DFU_ERROR_INTERNAL_04" and have no idea what it means. Could someone elaborate on this and suggest a solution? Is it a bug in the modem or am I missing something?
Below you can find the "prj.conf" I am using:
# Copyright (c) 2020 Nordic Semiconductor ASA
# General config
CONFIG_NEWLIB_LIBC=y
CONFIG_CBPRINTF_FP_SUPPORT=y
CONFIG_ASSERT=y
CONFIG_REBOOT=y
# DEBUGGING
CONFIG_SERIAL=y
CONFIG_UART_CONSOLE=n
CONFIG_RTT_CONSOLE=y
CONFIG_USE_SEGGER_RTT=y
# Logging
CONFIG_LOG=y
CONFIG_ELEO_LOG_LEVEL_DBG=y
# Network
CONFIG_NETWORKING=y
CONFIG_NET_NATIVE=n
CONFIG_NET_IPV6=n
CONFIG_NET_IPV4=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_OFFLOAD=y
# LwM2M
CONFIG_LWM2M=y
CONFIG_LWM2M_COAP_BLOCK_SIZE=512
CONFIG_LWM2M_COAP_MAX_MSG_SIZE=1024
CONFIG_LWM2M_ENGINE_MAX_OBSERVER=100
CONFIG_LWM2M_ENGINE_MAX_MESSAGES=20
CONFIG_LWM2M_ENGINE_MAX_PENDING=20
CONFIG_LWM2M_ENGINE_MAX_REPLIES=20
CONFIG_LWM2M_ENGINE_VALIDATION_BUFFER_SIZE=128
CONFIG_LWM2M_ENGINE_DEFAULT_LIFETIME=30
CONFIG_LWM2M_DNS_SUPPORT=y
CONFIG_LWM2M_SERVER_DEFAULT_PMIN=0
CONFIG_LWM2M_SERVER_DEFAULT_PMAX=120
CONFIG_LWM2M_CLIENT_UTILS=y
CONFIG_LWM2M_DTLS_SUPPORT=y
CONFIG_LWM2M_SECURITY_KEY_SIZE=33
CONFIG_LWM2M_SHELL=y
# LwM2M 1.1
CONFIG_LWM2M_VERSION_1_1=y
CONFIG_LWM2M_RW_SENML_CBOR_SUPPORT=y
CONFIG_ZCBOR=y
CONFIG_ZCBOR_CANONICAL=y
CONFIG_LWM2M_RW_SENML_CBOR_RECORDS=35
CONFIG_LWM2M_COMPOSITE_PATH_LIST_SIZE=10
CONFIG_LWM2M_RW_OMA_TLV_SUPPORT=y
# Disable unused object supports
CONFIG_LWM2M_PORTFOLIO_OBJ_SUPPORT=n
CONFIG_LWM2M_CLIENT_UTILS_SIGNAL_MEAS_INFO_OBJ_SUPPORT=n
# CoAP
CONFIG_COAP_INIT_ACK_TIMEOUT_MS=4000
CONFIG_COAP_EXTENDED_OPTIONS_LEN=y
CONFIG_COAP_EXTENDED_OPTIONS_LEN_VALUE=40
# LTE link control
CONFIG_LTE_LINK_CONTROL=y
CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
CONFIG_LTE_NETWORK_MODE_LTE_M_NBIOT_GPS=y
# Modem library
CONFIG_NRF_MODEM_LIB=y
CONFIG_NRF_MODEM_LIB_SYS_INIT=n
CONFIG_MODEM_INFO=y
CONFIG_MODEM_INFO_ADD_DATE_TIME=n
CONFIG_MODEM_KEY_MGMT=y
CONFIG_FMFU_FDEV=y
# Crypto (used for full modem update)
CONFIG_OBERON_BACKEND=y
CONFIG_NORDIC_SECURITY_BACKEND=y
# Disable all non-used crypto
CONFIG_NRF_SECURITY_RNG=n
CONFIG_MBEDTLS_AES_C=n
CONFIG_MBEDTLS_CHACHA20_C=n
CONFIG_MBEDTLS_POLY1305_C=n
CONFIG_MBEDTLS_ECP_C=n
CONFIG_MBEDTLS_RSA_C=n
CONFIG_MBEDTLS_DHM_C=n
CONFIG_MBEDTLS_SHA1_C=n
CONFIG_MBEDTLS_SHA384_C=n
CONFIG_MBEDTLS_SHA512_C=n
CONFIG_MBEDTLS_GCM_C=n
# This is the one we need
CONFIG_MBEDTLS_SHA256_C=y
# Enable settings storage
CONFIG_SETTINGS=y
CONFIG_FCB=y
CONFIG_SETTINGS_FCB=y
# DFU Target
CONFIG_DFU_TARGET=y
CONFIG_DFU_TARGET_STREAM=y
CONFIG_DFU_TARGET_FULL_MODEM=y
# Allow FOTA downloads using download-client
CONFIG_DOWNLOAD_CLIENT=y
CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096
CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_1024=y
CONFIG_FOTA_DOWNLOAD=y
CONFIG_LWM2M_FIRMWARE_UPDATE_OBJ_SUPPORT_MULTIPLE=y
CONFIG_LWM2M_FIRMWARE_UPDATE_OBJ_INSTANCE_COUNT=3
# Heap and stacks
CONFIG_HEAP_MEM_POOL_SIZE=20480
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_LWM2M_ENGINE_STACK_SIZE=4096
CONFIG_AT_MONITOR_HEAP_SIZE=1024
## PSM
CONFIG_LTE_PSM_REQ_RPTAU="00000011"
CONFIG_LTE_PSM_REQ_RAT="00100001"
## eDRX
CONFIG_LTE_EDRX_REQ=y
CONFIG_LTE_EDRX_REQ_VALUE_LTE_M="1001"
# GPS
CONFIG_GNSS_PRIORITY_ON_FIRST_FIX=n
CONFIG_GNSS_SEARCH_TIMEOUT=120
CONFIG_GNSS_SEARCH_INTERVAL_TIME=180
CONFIG_SUPL_CLIENT_LIB=y
# Application Event Manager
CONFIG_APP_EVENT_MANAGER=y
CONFIG_APP_EVENT_MANAGER_LOG_EVENT_TYPE=y
CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_INF=y
CONFIG_APP_EVENT_MANAGER_SHOW_EVENTS=y
# Set SPM as default secure firmware
CONFIG_BUILD_WITH_TFM=n
CONFIG_SPM=y
# GPIO
CONFIG_GPIO=y
# SPI
CONFIG_SPI=y
CONFIG_SPI_NRFX=y
CONFIG_SPI_NOR=y
CONFIG_SPI_NOR_SFDP_RUNTIME=y
CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
CONFIG_SPI_NRFX_RAM_BUFFER_SIZE=32
# FLASH
CONFIG_FLASH=y
CONFIG_STREAM_FLASH=y
CONFIG_STREAM_FLASH_ERASE=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_JESD216_API=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_MPU_ALLOW_FLASH_WRITE=y
# MCUBOOT
CONFIG_BOOTLOADER_MCUBOOT=y
# Image manager
CONFIG_IMG_MANAGER=y
CONFIG_IMG_ERASE_PROGRESSIVELY=y
# WDT
CONFIG_WATCHDOG=y
CONFIG_WATCHDOG_WINDOWN_MIN=0
CONFIG_WATCHDOG_WINDOWN_MAX=90000
# Partition Manager
CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y
CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y
# Date-Time library
CONFIG_DATE_TIME=y
CONFIG_DATE_TIME_UPDATE_INTERVAL_SECONDS=86400
    I think modem trace would be useful for identifying the cause. Just follow these instructions infocenter.nordicsemi.com/.../collect_modem_trace.html
  • Hi Hakon,
    I followed your guide and enabled Modem Tracing. However, interestingly, the delta modem succeeds when modem tracing is enabled... As soon as I disable Modem tracing, it fails again.
    After some more debugging I did however found out that when performing the update for a second time (without reboot or re-flashing in between), the delta firmware update does succeed. It looks like this is very consistent, as I tried it multiple times.
    It is not an option to have modem tracing enabled in production, since it takes up almost 10% of SRAM, which barely fits (total 97% when enabled).
    So unfortunately it seems that I cannot get modem traces when the error occurs. Any other ideas?
  • Modem team has responded;
    If the error 22 is DFU_FIFO_NOT_ALLOCATED, which is defined in dfu.h, it means that DFU has not yet allocated its FIFO buffer from system RAM. I have seen this happening a few times in my tests, INIT_REQ is called and immediately after that delta image fragment is sent. The fragment send occurs so quickly that the FIFO allocation has not yet completed. This is because INIT_REQ response is sent before FIFO allocation is guaranteed to have completed. Resending the fragment then succeeds as FIFO allocation has completed.
    Same error should occur if the delta fragment is sent without INIT_REQ.
    I am using 0.2s delay in my tests after INIT_REQ before starting the fragment sending.
    Would this make sense in this case also? On error 22 retry after a short delay.
