Just see the screen shot - PPK2 is OFF yet it shows 200mA
There is a new update out that should address your issue. Can you see if you're able to reproduce the issue with v3.5.3?
regards
Jared
Just upgraded successfully, will let you know while using if there problem continues
However, do we need the bold lines? Do we need to be traced even while using the PPK2?
just asking ;-)
2022-12-12T13:10:49.039Z DEBUG Application data folder: /Users/papio/Library/Application Support/nrfconnect/pc-nrfconnect-ppk
2022-12-12T13:10:50.513Z INFO Using nrf-device-lib-js version: 0.4.15
2022-12-12T13:10:50.513Z INFO Using nrf-device-lib version: 0.12.8
2022-12-12T13:10:50.514Z WARN Unable to detect version of nrfjprog DLL.
2022-12-12T13:10:50.514Z WARN Unable to detect version of JLink.
2022-12-12T13:10:51.443Z DEBUG App pc-nrfconnect-ppk v3.5.3 official
2022-12-12T13:10:51.443Z DEBUG App path: /Users/papio/.nrfconnect-apps/node_modules/pc-nrfconnect-ppk
2022-12-12T13:10:51.443Z DEBUG nRFConnect 3.12.1, required by the app is (^3.12.0)
2022-12-12T13:10:51.444Z DEBUG nRFConnect path: /Applications/nRF Connect for Desktop.app/Contents/Resources/app.asar
2022-12-12T13:10:51.444Z DEBUG HomeDir: /Users/papio
2022-12-12T13:10:51.444Z DEBUG TmpDir: /var/folders/l2/q1yr15k169z43pw_hczk1ckw0000gn/T/
2022-12-12T13:10:51.453Z INFO Installed JLink version does not match the provided version (V7.66a)
2022-12-12T13:10:51.509Z ERROR Failed to get the library versions
2022-12-12T13:10:54.064Z DEBUG Client Id: 0a3f2266-b63b-4861-8c30-a70bc0ded668
2022-12-12T13:10:54.563Z DEBUG Google Analytics for category pc-nrfconnect-ppk has initialized
2022-12-12T13:10:57.983Z INFO Validating firmware for device with s/n CB22E7EA07AA
2022-12-12T13:10:57.993Z DEBUG Device has DFU trigger interface, the device is in Application mode
2022-12-12T13:11:00.931Z DEBUG CB22E7EA07AA on /dev/tty.usbmodemCB22E7EA07AA2 is now in DFU-Bootloader...
2022-12-12T13:11:01.015Z DEBUG Starting DFU
2022-12-12T13:11:01.033Z INFO Entering programming state: 0%
2022-12-12T13:11:02.133Z INFO Done entering programming state: 100%
2022-12-12T13:11:02.134Z INFO Opening serial port for SDFU programming: 0%
2022-12-12T13:11:02.618Z INFO Opening serial port for SDFU programming: 100%
2022-12-12T13:11:02.621Z INFO Uploading image through SDFU: 0%
2022-12-12T13:11:06.066Z INFO Uploading image through SDFU: 100%
2022-12-12T13:11:06.923Z INFO All dfu images have been written to the target device
2022-12-12T13:11:06.923Z DEBUG DFU completed successfully!
2022-12-12T13:11:06.924Z DEBUG Will wait for device CB22E7EA07AA
2022-12-12T13:11:16.928Z DEBUG Timeout when waiting for attachment of device with serial number CB22E7EA07AA
2022-12-12T13:11:16.930Z DEBUG DFU failed: Timeout while waiting for device CB22E7EA07AA to be attached and enumerated Error: Timeout while waiting for device CB22E7EA07AA to be attached and enumerated
2022-12-12T13:11:16.947Z ERROR Error while setting up device CB22E7EA07AA: Error: Timeout while waiting for device CB22E7EA07AA to be attached and enumerated
2022-12-12T13:11:16.947Z INFO Deselecting device
Have you disabled usage statistics in the settings menu?
regards
Jared
happy new year to you guys
unfortunately it is completely not reliable - please see attached
Is this happening with the same frequency as before? Do you see it after restarting the application?
Do you see it when you lower the supply voltage from the PPK2?
regards
Jared
