Just see the screen shot - PPK2 is OFF yet it shows 200mA
1- frequency: I did not use PPK2 since the last time we spoke - I just opened it today since then
2- when I restart the app all is OK (until next time)
3- I am not sure about voltage: I used today many values between 3.3V and 5V - when it happened I was at max=5V, the current drawn by my project is anything between 30uA and 300mA
Ok, thanks for the description.
And you're still getting this readings if the PPK2 is not connecting to anything else than the Mac?
Please update this case if you have more new observation regarding this issue.
regards
Jared
I don't have anything else but Mac
I will keep you posted but as far as I understand there is no specific request from you to me such as log or so? I am happy to help you guys to solve the issue of course as I need a reliable system for my "thingis" ;-)
zyghom said:I don't have anything else but Mac
I meant to say that the PPK2 isn't connected to any device such as the ESP32 that you mentioned earlier? I can tell from the picture you shared last that PPK2 is set to source mode with the power supply enabled. I was wondering if you can disconnect the PPK2 from any DUT and just let it be connected to your Mac and see if the current consumption is still high.
regards
Jared
you mean: disconnect the DUC and just let PPK2 run with power turned ON without the load?
