Hi Everyone,
I am wondering if anyone have done FFT with a nRF9160. I found discussion about FFT on nRF52, but nothing on nRF9160. Can it be done? An example would be nice. Thank you in advance.
Cheers,
Floyd
Hi Everyone,
Cheers,
Floyd
Hi Floyd,
I haven't seen it done so far, but it's certainly possible!
Among the nRF52-related discussion you found, you might have seen references to the CMSIS-DSP Library, which supports performing FFTs. The CMSIS libraries are available for many Cortex-M devices, including the Cortex-M33 in the nRF9160.
The CMSIS-DSP library had to be added manually before, but is now distributed with Zephyr.
First off, add the following to your prj.conf (taken from this case):
CONFIG_CMSIS_DSP=y CONFIG_NEWLIB_LIBC=y CONFIG_FPU=y #if printf should be able to print float CONFIG_NEWLIB_LIBC_FLOAT_PRINTF=y
And then include:
#include "arm_math.h"
To make the functions available for use.
To keep space requirements low, some of the DSP functions might require setting additional Kconfig flags. You can browse those here: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/kconfig/index.html#!CMSIS_DSP
For examples on how to perform FFT using the DSP library, I found the following links:
Practical FFT on microcontrollers using CMSIS DSP
ARM CMSIS DSP FFT Library - Youtube
https://www.keil.com/pack/doc/CMSIS/DSP/html/arm_fft_bin_example_f32_8c-example.html (example from the library itself)
Hope that helps!
Raoul
Thank you. Will give that a try.
