boilerplate.cmake not found because ZEPHYR_BASE isn't set
I'm very confused by this error.
I have a project with the following CMakeLists.txt file
cmake_minimum_required(VERSION 3.20.0)
include($ENV{ZEPHYR_BASE}/cmake/app/boilerplate.cmake NO_POLICY_SCOPE)
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
project(bike_finder)
target_sources(app PRIVATE src/main.c)
//... more target sources
# NORDIC SDK APP END
zephyr_library_include_directories(.)
When the project is tried to be built at the startup of VScode, I get the following error message
When I open a terminal, I ran echo $ZEPHYR_BASE, but it came out empty.
Therefore, I go into the nRF Connect SDK folder that I'm using (v2.2.0-rc1), run source zephyr/zephyr-env.sh and then the terminal finally recognizes where ZEPHYR_BASE is.
To rebuild, I just do a dummy modification to the file (use :w since I'm using vim within vscode), and then application tries to rebuild again, but I keep the same error.
If I go to the nRF Connect extension section, I see my folder under applications, but it's followed by "no build configurations", because of this problem.
What should I do?
  • Ok, I managed to fix the boards problem. It seems that removing the cmake extension allowed me to work through it.
    However, now I'm having still one more problem, the following lines in my main.c are failing due to not being able to locate these files:
    #include<zephyr.h>
    #include<sys/printk.h>
    Again, opening the terminal from the toolchain manager outputs the correct location for the zephyr folder:
    /home/ernesto/ncs/v2.2.0-rc1/zephyr
    And I have made sure that both files exist in said directory.
    In the compilation command, I see the following directory included with -I (besides many others, ofc):
    -I/home/ernesto/ncs/v2.2.0-rc1/zephyr/include
    Now, the zephyr.h is in .../zephyr/include/zephyr
    So I wonder whether the -I statement up to .../include is enough, or should it be extended up to zephyr as well? If so, how can I include that?
    Regarding the board name, I am sorry for the confusion. You mentioned nRF52832-DK, so it could be that you meant either nRF52-DK (which has nRF52832) or you mistyped nRF52833-DK.
    Could you send log output of the build process?
    Dejan
  • I see, my bad.
    This is the output log of the building process:
     *  Executing task: nRF Connect: Build: bike_finder/build (active)
    Building bike_finder
    west build --build-dir /home/ernesto/ncs/bike_finder/build /home/ernesto/ncs/bike_finder
    [1/198] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
    [2/198] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
    [3/198] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
    [4/198] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
    [5/198] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
    [6/198] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
    [7/198] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
    [8/198] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [9/198] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [10/198] Building C object CMakeFiles/app.dir/src/main.c.obj
    FAILED: CMakeFiles/app.dir/src/main.c.obj
    ccache /home/ernesto/ncs/toolchains/v2.2.0-rc1/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DKERNEL -DNRF52832_XXAA -DUSE_PARTITION_MANAGER=0 -D__PROGRAM_START -D__ZEPHYR__=1 -I../. -I/home/ernesto/ncs/v2.2.0-rc1/nrf/drivers/mpsl/clock_control -I/home/ernesto/ncs/v2.2.0-rc1/zephyr/include -Izephyr/include/generated -I/home/ernesto/ncs/v2.2.0-rc1/zephyr/soc/arm/nordic_nrf/nrf52 -I/home/ernesto/ncs/v2.2.0-rc1/zephyr/soc/arm/nordic_nrf/common/. -I/home/ernesto/ncs/v2.2.0-rc1/zephyr/subsys/bluetooth -I/home/ernesto/ncs/v2.2.0-rc1/nrf/include -I/home/ernesto/ncs/v2.2.0-rc1/nrf/lib/multithreading_lock/. -I/home/ernesto/ncs/v2.2.0-rc1/nrf/subsys/bluetooth/controller/. -I/home/ernesto/ncs/v2.2.0-rc1/modules/hal/cmsis/CMSIS/Core/Include -I/home/ernesto/ncs/v2.2.0-rc1/modules/hal/nordic/nrfx -I/home/ernesto/ncs/v2.2.0-rc1/modules/hal/nordic/nrfx/drivers/include -I/home/ernesto/ncs/v2.2.0-rc1/modules/hal/nordic/nrfx/mdk -I/home/ernesto/ncs/v2.2.0-rc1/zephyr/modules/hal_nordic/nrfx/. -I/home/ernesto/ncs/v2.2.0-rc1/modules/debug/segger/SEGGER -I/home/ernesto/ncs/v2.2.0-rc1/modules/debug/segger/Config -I/home/ernesto/ncs/v2.2.0-rc1/zephyr/modules/segger/. -I/home/ernesto/ncs/v2.2.0-rc1/modules/crypto/tinycrypt/lib/include -I/home/ernesto/ncs/v2.2.0-rc1/nrfxlib/mpsl/include -I/home/ernesto/ncs/v2.2.0-rc1/nrfxlib/mpsl/include/protocol -I/home/ernesto/ncs/v2.2.0-rc1/nrfxlib/softdevice_controller/include -isystem /home/ernesto/ncs/v2.2.0-rc1/zephyr/lib/libc/minimal/include -isystem /home/ernesto/ncs/toolchains/v2.2.0-rc1/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/include -isystem /home/ernesto/ncs/toolchains/v2.2.0-rc1/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/include-fixed -fno-strict-aliasing -Os -imacros /home/ernesto/ncs/bike_finder/build/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/home/ernesto/ncs/toolchains/v2.2.0-rc1/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros /home/ernesto/ncs/v2.2.0-rc1/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=/home/ernesto/ncs/bike_finder=CMAKE_SOURCE_DIR -fmacro-prefix-map=/home/ernesto/ncs/v2.2.0-rc1/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/home/ernesto/ncs/v2.2.0-rc1=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir/src/main.c.obj -MF CMakeFiles/app.dir/src/main.c.obj.d -o CMakeFiles/app.dir/src/main.c.obj -c ../src/main.c
    /home/ernesto/ncs/bike_finder/src/main.c:7:10: fatal error: zephyr.h: No such file or directory
        7 | #include <zephyr.h>
    compilation terminated.
    [11/198] Building C object CMakeFiles/app.dir/services/buzzer_service.c.obj
    FAILED: CMakeFiles/app.dir/services/buzzer_service.c.obj
    ccache /home/ernesto/ncs/toolchains/v2.2.0-rc1/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DKERNEL -DNRF52832_XXAA -DUSE_PARTITION_MANAGER=0 -D__PROGRAM_START -D__ZEPHYR__=1 -I../. -I/home/ernesto/ncs/v2.2.0-rc1/nrf/drivers/mpsl/clock_control -I/home/ernesto/ncs/v2.2.0-rc1/zephyr/include -Izephyr/include/generated -I/home/ernesto/ncs/v2.2.0-rc1/zephyr/soc/arm/nordic_nrf/nrf52 -I/home/ernesto/ncs/v2.2.0-rc1/zephyr/soc/arm/nordic_nrf/common/. -I/home/ernesto/ncs/v2.2.0-rc1/zephyr/subsys/bluetooth -I/home/ernesto/ncs/v2.2.0-rc1/nrf/include -I/home/ernesto/ncs/v2.2.0-rc1/nrf/lib/multithreading_lock/. -I/home/ernesto/ncs/v2.2.0-rc1/nrf/subsys/bluetooth/controller/. -I/home/ernesto/ncs/v2.2.0-rc1/modules/hal/cmsis/CMSIS/Core/Include -I/home/ernesto/ncs/v2.2.0-rc1/modules/hal/nordic/nrfx -I/home/ernesto/ncs/v2.2.0-rc1/modules/hal/nordic/nrfx/drivers/include -I/home/ernesto/ncs/v2.2.0-rc1/modules/hal/nordic/nrfx/mdk -I/home/ernesto/ncs/v2.2.0-rc1/zephyr/modules/hal_nordic/nrfx/. -I/home/ernesto/ncs/v2.2.0-rc1/modules/debug/segger/SEGGER -I/home/ernesto/ncs/v2.2.0-rc1/modules/debug/segger/Config -I/home/ernesto/ncs/v2.2.0-rc1/zephyr/modules/segger/. -I/home/ernesto/ncs/v2.2.0-rc1/modules/crypto/tinycrypt/lib/include -I/home/ernesto/ncs/v2.2.0-rc1/nrfxlib/mpsl/include -I/home/ernesto/ncs/v2.2.0-rc1/nrfxlib/mpsl/include/protocol -I/home/ernesto/ncs/v2.2.0-rc1/nrfxlib/softdevice_controller/include -isystem /home/ernesto/ncs/v2.2.0-rc1/zephyr/lib/libc/minimal/include -isystem /home/ernesto/ncs/toolchains/v2.2.0-rc1/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/include -isystem /home/ernesto/ncs/toolchains/v2.2.0-rc1/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/include-fixed -fno-strict-aliasing -Os -imacros /home/ernesto/ncs/bike_finder/build/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/home/ernesto/ncs/toolchains/v2.2.0-rc1/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros /home/ernesto/ncs/v2.2.0-rc1/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=/home/ernesto/ncs/bike_finder=CMAKE_SOURCE_DIR -fmacro-prefix-map=/home/ernesto/ncs/v2.2.0-rc1/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/home/ernesto/ncs/v2.2.0-rc1=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir/services/buzzer_service.c.obj -MF CMakeFiles/app.dir/services/buzzer_service.c.obj.d -o CMakeFiles/app.dir/services/buzzer_service.c.obj -c ../services/buzzer_service.c
    /home/ernesto/ncs/bike_finder/services/buzzer_service.c:5:10: fatal error: sys/printk.h: No such file or directory
        5 | #include <sys/printk.h>
    [12/198] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [13/198] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
    [14/198] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
    [15/198] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/mpsc_pbuf.c.obj
    [16/198] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_cache.c.obj
    [17/198] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
    [18/198] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_mgmt.c.obj
    [19/198] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_core.c.obj
    FATAL ERROR: command exited with status 1: /home/ernesto/ncs/toolchains/v2.2.0-rc1/usr/local/bin/cmake --build /home/ernesto/ncs/bike_finder/build
     *  The terminal process failed to launch (exit code: 1).
    Is this output log from VS Code or from the terminal which is started using Toolchain Manager?
    Dejan
  • from VS Code after I press build on the nrf connect extension.
