boilerplate.cmake not found because ZEPHYR_BASE isn't set
I'm very confused by this error.
I have a project with the following CMakeLists.txt file
cmake_minimum_required(VERSION 3.20.0)
include($ENV{ZEPHYR_BASE}/cmake/app/boilerplate.cmake NO_POLICY_SCOPE)
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
project(bike_finder)
target_sources(app PRIVATE src/main.c)
//... more target sources
# NORDIC SDK APP END
zephyr_library_include_directories(.)
When the project is tried to be built at the startup of VScode, I get the following error message
When I open a terminal, I ran echo $ZEPHYR_BASE, but it came out empty.
Therefore, I go into the nRF Connect SDK folder that I'm using (v2.2.0-rc1), run source zephyr/zephyr-env.sh and then the terminal finally recognizes where ZEPHYR_BASE is.
To rebuild, I just do a dummy modification to the file (use :w since I'm using vim within vscode), and then application tries to rebuild again, but I keep the same error.
If I go to the nRF Connect extension section, I see my folder under applications, but it's followed by "no build configurations", because of this problem.
What should I do?
    Could you try using "west build" command from the terminal opened from Toolchain Manager?
    Dejan
  • I just tried "west build --build-dir /home/ernesto/ncs/bike_finder/build /home/ernesto/ncs/bike_finder" from the terminal opened from the toolchain manager. I did it from /home/ernesto/ncs/bike_finder/.
    Got the same errors I copied above. Yet, doing echo $ZEPHYR_BASE still outputs .../v2.2.0-rc1/zephyr, which is correct.
    You could try to do pristine build. If the same error appears, try removing build folder first and then do pristine build again.
    Dejan
  • If I do pristine build from Vs code, I get the same error.
    If I delete the build directory and run the west command from terminal opened from the toolchain manager, then I get the original error I mentioned previously:
    WARNING: This looks like a fresh build and BOARD is unknown; so it probably won't work. To fix, use --board=<your-board>.
    Note: to silence the above message, run 'west config build.board_warn false'
    -- Application: /home/ernesto/ncs/bike_finder
    -- Using NCS Toolchain 2.2.0-rc1 for building. (/home/ernesto/ncs/toolchains/v2.2.0-rc1/cmake)
    -- Found Python3: /home/ernesto/ncs/toolchains/v2.2.0-rc1/usr/local/bin/python3 (found suitable exact version "3.8.2") found components: Interpreter
    -- Cache files will be written to: /home/ernesto/.cache/zephyr
    -- Zephyr version: 3.2.99 (/home/ernesto/ncs/v2.2.0-rc1/zephyr)
    CMake Error at /home/ernesto/ncs/v2.2.0-rc1/zephyr/cmake/modules/extensions.cmake:2520 (message):
      BOARD is not being defined on the CMake command-line, in the environment or
      by the app.
      /home/ernesto/ncs/v2.2.0-rc1/zephyr/cmake/modules/boards.cmake:52 (zephyr_check_cache)
      /home/ernesto/ncs/v2.2.0-rc1/zephyr/cmake/modules/zephyr_default.cmake:108 (include)
      /home/ernesto/ncs/v2.2.0-rc1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
      /home/ernesto/ncs/v2.2.0-rc1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
      CMakeLists.txt:6 (find_package)
    FATAL ERROR: command exited with status 1: /home/ernesto/ncs/toolchains/v2.2.0-rc1/usr/local/bin/cmake -DWEST_PYTHON=/home/ernesto/ncs/toolchains/v2.2.0-rc1/usr/local/bin/python3.8 -B/home/ernesto/ncs/bike_finder/build -GNinja -S/home/ernesto/ncs/bike_finder
    Ok, looks like I was right.
    If instead of "#include <zephyr.h>" I write "#include<zephyr/zephyr.h>" then I get a different warning about this header file being deprecated and that I should use <zephyr/kernel.h> instead.
    This is happening because the build command, as I said in a previous response to you, is only including the zephyr directories up to .../include, which is the reason why all my headers work now if I prepend an extra "zephyr/" in my includes.
    However, I got a lot of includes, so my final question to you is:
    How can I add the directories up to .../include/zephyr so that I don't have prepend "zephyr/" in each of my includes? Is there a way to set this in VS Code?
