Add a cluster based on the matter/template example in ncs2.1.2. When I run the " scripts\tools\zap\run_zaptool.sh ..\..\..\nrf\samples\matter\sensor\src\template.zap "command, the following window appears.
After waiting a while, the above window exits and the Zigbee Cluster Configurator window does not run. I can't see the log message in the window because the window exits too quickly when the message appears. I used the same method two days before the test is normal, today I tried again and failed, too strange.
My tool version information is as follows:
What is the cause of this condition?
