If possible, could you provide information why you would need 6 BIS streams and what would they be used for?
Dejan
The main idea is to demonstrate the BLE Audio capabilities of nRF5340; the use-case is: multiple audio-streams will be distributed in a room to multiple listeners, and each will choose their active stream.
For now 2 streams will be from I2S (left and right from audio stereo), while the channels #3 to #6 will be generated sinewaves.
On long-term, minimum 16 channels should be broadcasted; most-likely the LC3 encoding should be done on a more powerful MCU, so nRF5340 will remain just to handle LE Audio stack and decoding (only on the receiving kit).
Would broadcasting 16 BIS (without LC3 encoding, 48kbps each stream (probably 2 retransmissions min), so this is 96KB/sec audio-data for all streams) is achievable for nRF5340 and BLE Audio stack?
Thank you!
As there is theoretical limit for 2M Phy of around 1.4 Mbps, that would enable support for less than 10 streams (with 48 Kbps) with 2 retransmissions each. Even with only 1 retransmission, maximum number of streams would be 14. However, these are only theoretical considerations, since audio controller currently supports maximum 4 BISes.
Dejan
Any news on releasing a new BL Controller with 6 or 8 BIS streams?
thanks,
Catalin
It is not supported at the moment. For any other information related to future plans and releases please contact your regional sales manager.
Dejan
