Dear Nordic team,
I'm evaluating nRF5340 Audio DK for the use-case of broadcasting multiple streams.
Until now I've succeeded in broadcasting 4 streams (LC4 bitrate set up to 48kbps) and I would like to to increase to 6. I've increased all the configuration parameters to support 6 streams, but I receive an error in initializing the broadcast source.
I'm attaching the whole debug log, but the main error is here:
GW [00:00:02.445,953] <wrn> bt_hci_core: opcode 0x2068 status 0x0d
GW [00:00:02.445,953] <dbg> bt_iso: bt_iso_big_create: Could not create BIG -5
Opcode 0x68 is BT_HCI_OP_LE_CREATE_BIG.
The status code 0x0D is BT_HCI_ERR_INSUFFICIENT_RESOURCES, and I've added warn log messages to all the C-code returning this value, but it's not printed. So I suspect this could be in the LE Audio controller from the Network Core (binary release). Most of the code is indeed in the BT Controller (C:\ncs\v2.2.0-rc1\zephyr\subsys\bluetooth\controller).
I'm attaching the prj.conf with the modified configuration values, of the nRF5340 Audio application.
I'm using the nRF Connect SDK v2.2.0-rc1.
I understand the LC3 encoding processing requirements are quite high, but as it takes 6 milisec for 4 streams (10milisec PCM slice, 32kbps), I suppose there is time for 6 streams @32kbps.
Please let me know if there's any more configuration values that needs to be tuned, in order for the 6 (or maybe 8) streams to be broadcasted, or maybe some timeouts increased.
Thank you!
